Question about Samsung Televison & Video
Samsung tv made loud noise and will not power up
LN55B650
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Sounds like capacitor exploded. Check power supply area. Flat panel tv's use cheap capacitors. Most likely this capacitor is in the power supply area. The top will be popped, they're made to pop when they go bad. Have professional fix it.
Posted on Feb 15, 2014
Samsung lcd tv made loud noise and now will not power up
Check power supply for blown or burnt parts, also make visual check of all PCBs for any blown/burnt parts & any signs of overheating.
Feb 14, 2014 | Samsung LN55B650 55 in. LCD HDTV
My Samsung LN55B650 has problems with the picture. The pixels will flicker in and out. It is not a constant problem, but when it heats up it gets worse. I have video of the problem as well. manufactured in...
it is the screen driver on the back of the screen over heating it will fail and need to be replaced. you can get them on line or bay from around 15-65 pound. make sure you get the same number as the board off your tv even the (ver) number. hope this helps you.
Oct 01, 2013 | Samsung LN55B650 55 in. LCD HDTV
Whats wrong with my Samsung 55" LN55B650 LN55B650T1F tv?
These are not meant to be repaired, just boards replaced.
Follow if you are able the AC voltage into the set and then when it changes to DC follow that---confirm all voltages are present, a total dead set usually means something open not too far from the power cord.
Aug 31, 2012 | Samsung LN55B650 55 in. LCD HDTV
I have a Samsung LN55B650, and cannot use the remote to change channels, hav eto use cable remote. I change to TV mode, and program in channels, but that option is not available once I switch to HDMI2,...
OK the cable box remote is the only one that can change channels in this case. because you are using the tuner in the cable box not the TV.
all you need the TV remote for is to turn the TV on and off and turn the sound up and down. if you used the cable input on the TV then the tv remote would be used to change the channels.
Dec 25, 2010 | Samsung LN55B650 55 in. LCD HDTV
I have a loud humming noise comeing from my tv
Check power supply filter capacitor that goes to Audio IC.
Apr 02, 2010 | Samsung DLP HL-P5663W 56" TV
Why does my Samsung Ln55b650 give me a no signal when I switch to my ps3. Doesn't do it all the time.
It's just HDMI compatibility. Not a major concern, there's nothing wrong with the TV or PS3, they just don't play nicely together. You may want to contact Samsung regarding a firmware update for your TV. You may also find it on Samsung's website with instructions. They are very easy to perform. If this does not resolve the problem, the only solution you have remaining is to use the component cable connections from your TV to PS3.
Mar 15, 2010 | Samsung LN55B650 55 in. LCD HDTV
I just bought a 55 inch Samsung LN55B650. There is a ghostly lines going up the picture when veiwing. What is that?
probably weak signal
how many things do you have hooked up if you have a lot then hook the cable or what ever it is to a separate thing don't go through anything
Aug 16, 2009 | Samsung LN55B650 55 in. LCD HDTV
Black Screen VERY loud noise
Samsung color wheel fix
http://www.jaGet a new cable if everything else works that is your problem
Oct 14, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
43 people viewed this question
Jerry Greenberg
Jerry Greenberg
