Question about Microsoft Xbox 360 Console
I took my xbox 360 slim apart to clean the fan heat sinks etc and put all the connections back into the disc reader and put the whole xbox back together but now the controller will not connect. the controller will blink but not sync it wont even sync when the play and charge cord is attached and the xbox works perfectly fine the lights around the sensor blink as well. but no connection the the controller how do i fix this
    New Friend:
  • 3 Answers
I havn't had the chance to work on a Slim yet, but from my experience with Phat 360s, you should clean out the connectors for the Ring of Light board with alcohol before reattaching it to the motherboard.
Posted on Feb 15, 2014
SOURCE: xBox 360 wireless controller won't connect or charge
Guys, you really need to calm down... I have the same problem like you.
I'll tell you step by step why the Xbox 360 Wireless Controller won't work.
1. The controller will automatically disconnect during the gameplay, and the charging kit won't charge.
Solution: This is true what I'm saying now... Where you guys brought your wireless controllers in the stores, there was a Frequently Asked Questions book inside the kit. It told you about the importance of the charging of your wireless controller, because Microsoft informed that it's VERY important to empty your battery before charging it, because the charging kit will no longer charge your battery, and the same thing happened to me. So, if you have any questions of your wireless controller, then contact me at my gamertag, NussKarte. I'll give you new information how to fix your wireless controller.
Posted on Mar 14, 2009
  • 6 Answers
SOURCE: XBOX 360 WIRELSS CONTROLLERS JUST BLINK WONT CONNECT
Did you try to press the sync button on both the XBOX and the controller? This should make them connect after they take a second to find out that their searching for eachother. If this doesn't work then you should call into Microsoft and talk to them because the sync system might be faulty. Try the controllers on another XBOX before calling just to make sure though.
Posted on Dec 30, 2008
SOURCE: xbox 360 wireless control pad wont connect
have you tried to pair it... the little white button on both the controller and the 360? works just like the wii remote
Posted on Feb 07, 2009
  • 3 Answers
SOURCE: xbox 360 controller won't connect to console
If your controller is not assigned a position, and pressing the sync buttons on both the console and the controller don't fix it (i.e. they both spin for a bit, but then the console's lights turn off and the controller's return to a pulsing pattern), the the problem is actually likely to be your TV, believe it or not. The issue is HDMI -- it's a secure connection between the Xbox 360 and the TV, and if there's an issue with that connection, the Xbox won't even be able to turn on since it'll be unaware of the TV's resolution, color capabilities, etc. Try turning off the TV and then turning off the Xbox. Keep the TV off and turn the Xbox console back on. You'll see the same behavior; but now turn the TV back on and you should see the controller get assigned a position. As soon as the Xbox is aware of what it's connected to via HDMI, things start to work again.
Posted on Feb 23, 2009
  • 3 Answers
SOURCE: xbox 360 sync problem - controllers will not connect
maybe the only way is take it a part and see if the sync button is not broken some how. therefore i advise you to buy a new controller maybe even a used 1 if you dont want to spend more than $20.
Posted on Mar 31, 2009
Alright, So I have 2 xbox's witht he rrod. I took them apart. and accidently put the wrong disc drives back in the system. so i swapped it out, and now the original disc drive doesnt work with it either....
If you replace the same drive with the same P.C. board back in
the original console you should be good .Provide that the drive is
or was good before you took it apart ( read games) also when
attempting a generic fix it kit ( washers and screws ) and over
heating G.P.U. you can create new problems .What ever you do
DO NOT GO ON LINE with a different drive or your console you
will be band for LIFE !! If you wear successful with your repair
your drive should boot right up . a good drive in the wrong console
will post a white screen to put a 360 game in the console.
Did you just replace the heat sink compound or do a full x clamp
mod ??
Rob
Mar 13, 2011 | Microsoft Xbox 360 Console
How to fix xbox 360 "red rings of death"??
How to Fix Red Ring of Death - A Step by Step Action Plan
Remember to rate me a 4 out of 4 thumbs up thanks
1) Disassemble Xbox 360 Case
Obtain your case separately. By a fine tip screwdriver, poke the grayed out holes and back of poke the small rectangle holes. Get the Faceplate Off and move the latch up on the DVD drive up as you remove it. Unscrew metal case which is under the plastic case.
Following is the image of video (How to disassemble xbox 360 case) which comes with James Dean's Professional Xbox 360 repair guide. If you are not comfortable with instruction you can use this video to disassemble your Xbox 360 case.
Click On Above Video Image To Watch Video On How To Your Repair Xbox 360
2) How To Remove Motherboard Safely
Unplug all cables connected to motherboard and associated small devices and take DVD drive out. After DVD, get the fan and motherboard out of the xbox 360 case. Make sure you do this gently.
Following is a quality video which can show how you can remove motherboard safely.
3) Crucial Motherboard Disassembles.
Turn the mother another side, using the screwdriver snoop off the X-clamp which you can find under heat sink. Check out following an image of a video which came with Xbox 360 repair guide which will make your process easy of "snoop off the X-clamp".
I will suggest you to do this step very gently if you are not comfortable doing this refer following video which comes with James Dean's 360 repair guide.
4) Heat Sink Unscrewing.
After snoop of X-clamp you have to unscrew heat sink to obtain CPU and GPU.I will advice you don't hurry to finish this work, please follow all steps else it will damage your xbox 360. If you are not confident do use Professional Xbox 360 repair guide.
5) GPU And CPU Cleaning.
Next step is to clean GPU (graphic processing unit) and CPU (central processing unit) If you do this step right it will help to stop xbox 360 freezing. This is very important and critical step so just make sure you do it right.
6) Appling Arctic Silver
Now you have to apply arctic silver thermal compound gently over GPU.
You will get this arctic silver thermal compound in any computer hardware shop for $1-$2.
Set it for 15 to 20 minutes then place 2 nylon washers on each screw on the heat sink then place the screws back in motherboard then add two more nylon washers to screws.
Then,
Place the heat sink on the peak of screws then push them down slight, finally screw them up. Try to make it reasonably tight.
Get everything back together and see everything is fitted properly. Now, Turn your Xbox 360 on.
I always like to educate people so I tried to describe a whole process in my words, Videos can make this whole process lot easier. I will suggest you to check out James Dean's Xbox 360 repair guide(Click Here To Visit) which will surely help you out to fix your XBOX 360. Also I have done a detail review of James Dean guide below, so don't forget to check it out if you need a pro help. please rate me high thanks
Jan 04, 2011 | Microsoft Xbox 360 Console
After playing 15 minutes two red lights flash and xbox shuts down
the xbox 360 is overheating. Try to clean the vents and have it elevated off carpet or anyhtign that will not allow it to get a airflow.
Check the fans in the back of the 360 to be sure they are running ok and not blocked up.
May 16, 2010 | Microsoft Xbox 360 Console
My xbox 360 wont play discs - keeps repeating open tray, I can play demos and xbox live but not discs or movies, any tips?? Thanks!
I just found a post on this and it worked for me. My warranty is past. So I took matters in my own hands. I took it apart which was fairly simple cleaned the lens and surrounding areas but it didn't work. But this is what I found out its not reading the disk because the disk isn't spinning. With the box apart and drive open I put it back in the system and turned on the power I noticed the drive would spin slowly I then while the disk was trying to load I spun the disk by hand to help it along and wala it started spinning I powered down put it back together and as of 10:45 2night my gaming nightmare is over. I hope this was helpful. Good luck all!!
Jul 14, 2009 | Microsoft Xbox 360 Console
Well when i play my xbox 360 for about 15mins the back of the console where you connect the cables to the console gets very hot and then if left after about another 15mins there is a message on the screen...
I suggest getting a proper X clamp mod that takes
care of the real problems. A external fan will do little
if nothing , because the thermal transfer point at the surfaces of
the G.P.U. chip set is not making enough contact
with the heat sink , so it doesn't mater how cool you get
the heat sink the chip will still over heat.
Rob
www.all-xboxrepair.com
Jun 13, 2009 | Microsoft Xbox 360 Arcade
Rrod no fan cd wont eject
well for the cd not ejecting theres only a couple manual ways to eject it. these can be found at http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=906935&lcid=1033&category=hardware
Apr 14, 2009 | Microsoft Xbox 360 Console
Xbox 360 Error Code 0021
So, you took apart the Xbox 360?
The Xbox 360 has serious cooling problems; compressed air usually does wonders for the Xbox.
You'll "brick" your Xbox tampering with the fan and heat sink; soft mods are always a bad idea if you don't have any recourse for fixing the system.
Hard Mods/Mod Chips are the best way to go because you have dual boot capabilities; you can boot to the original Xbox OS or the Mod Chip firmware.
Currently, Microsoft is being sued for the number of Xbox 360 consoles experiencing the "Red Rings of Death."
Microsoft is making amends by fixing the Xbox 360 at no charge.
Taking the Xbox apart yourself may void your warranty; you might start by uses an Ohm Meter to check the heat sink and fan connections.
Also make sure there is not a gap between the heat sink and the processor; this space should be filled with the thermal compound.
Furthermore, the fan might be damaged and not reporting the fan speed through the variable resistance wire; only way to determine this is by powering the fan with +5v / -5v and checking the variable resistance wire with an Ohm meter.
Mar 08, 2009 | Microsoft Xbox 360 Console
My xbox wont read my game disc
if you can't send the xbox back to Microsoft this worked for me.
The 360 would spin the game up and say reading but than stop and do nothing.
I took the case apart, took out the cd drive, took that apart so i could get to the laser.
put a little big of very clean water on a q-tip, wipe the laser lens down and use the dry side to dry it off.  put it somewhat back together and test, this worked fine for me, it read a disk no problem.
Feb 21, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont load any games.
It has happened to me twice and unfortunately the only way to solve it is sending the device to msoft. You can do this either through the phone or using the xbox.com site.
The second time it happened to me the machine was out the warranty, they offer me to pay 87 € to fix it and extended the warranty for an extra year after it.
At the end when I send it the second time they just sent me a refurbished one to avoid the problem to happen in the future.
Sep 24, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
61 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
