Question about Viking Professional VGRT362-4G 36 in. Gas Cooktop
I have a viking Proffesional Viking VGRT360-4G or a VGRT362-4G. The four outside burners work fine however the griddle does not get hot. When I turn the dial on the light comes on immdiatly but no heat. Whats up with thiss???
Kgt1962
  • 59 Answers
SOURCE: Only 1 of 5 burners is working on my Viking electric cooktop
By only 1 burner working, I take you mean only 1 ignites, then it sounds as though you have an issue with the spark module being defective. There is usually an access panel on the bottom of the unit, although not on all of them. Remember to disconnect from the electric.
Posted on Mar 05, 2009
Kgt1962
  • 59 Answers
SOURCE: I have a viking cooktop with 4 burners and a
This can be cause dby one of 2 problems.
When you turn the control to turn the Griddle on, does it come immediately or do you have to turn it a long way before it comes on?
If it turns on immediatly then it is more than likely the Ignitor
If you have to turn it a long way you have a defective Thermostat
Posted on Mar 12, 2009
  • 30 Answers
SOURCE: Viking stove right burners won't light
can u see the burner spark if not then ht lead at fault of electrode
Posted on Aug 21, 2009
  • 42 Answers
SOURCE: I have a four burners 31 inch Viking cooktop. I
burner 1 is the tap assembley reqs., greasing with graphite grease.
ignition depending on model this is correct.
Posted on Sep 28, 2009
meztang
  • 112 Answers
SOURCE: viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
The Viking gas stove - 6 burner - clicks constantly -- it won't stop. it has done this for years and usually goes off after a while but now it wont stop clicking. The burner that is not even on click.
The problem is one(or more) of the 6 switches that turn on the spark when that burner is turned on is shorted and stays closed (on) all the time.To determine which one it is the front face has to be removed,with THE POWER OFF a meter set to low ohms rating is used to check each switch by removing the wires to it and see which one has continunity (ZERO OHMS) when its off and that switch that slips on the burner valve shaft is the bad switch(s) and needs to be replaced to keep it from sparking all the time.
Please note though, in a perfectly working cooktop all burners spaks at the same time and only the only one that has the gas flowing to it will ignite,that part is normal.
I hope this helps you to repair your cooktop,
Gene
Aug 08, 2011 | Viking Professional VGRT362-4G 36 in. Gas...
The filter light on my updraft 4 burner gas cooktop is on - is that something I can fix myself and if so, how? Thanks. Kathy
It should mean the air flow is low. you need to change the filter that is what it is trying to tel you. you should be able to do it yourself
Sep 01, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
How do I clean a Viking griddle that hasbeen
I use a product called Greasecutter Plus by ECOLAB, it makes the griddle look brand new, gets everything off. You just spray it on and let it set for a little bit then it wipes clean.
May 13, 2010 | Viking Cooktops
How do you replace the ignition module on stove.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 14, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
Our stove is clicking when we are not trying to ignite it. The clicking comes from the starters of the front three burners. What should we do to fix it?
this cook top uses sw's n eachburner control shaft. one or more than one is bad . i would replace all . all the same . they slide on burner shages and connect to each other . some units are pre wired and you will have to pur the harness with the sitches . not a hard job . the spark moduel could be bad but i don't think so .. mm
Dec 08, 2009 | Viking Professional VGRT362-4G 36 in. Gas...
Aug 21, 2009 | Viking 31 in. VGSU101 Gas Cooktop
I have a viking cooktop with 4 burners and a center griddle. The griddle will not hold heat. It fires up then goes out.
Feb 18, 2009 | Viking VGRT600-6G Gas Cooktop
Viking Professional VGRT362-4G 36 in. Gas Cooktop Logo
85 people viewed this question
Top Viking Cooktops Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
