Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Fisher and paykel E521TRT fridge now making noise after 2 years
Fridge noise
  • 30 Answers
SOURCE: Fisher Paykel fridge stopped working
sounds to me like your thermostat has gone,or if its a electronic model ,it would be the power supply down by the compressor.. Masters5
Posted on Jul 31, 2008
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
  • 26 Answers
SOURCE: Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
Posted on Mar 10, 2009
SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
Posted on Mar 31, 2009
reddyanantha
  • 205 Answers
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Posted on Sep 14, 2009
Testimonial: "which temerature censor ( there are three )"
My 10 year old fridge is making a racket of a noise. I am defrosting it, what next?
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Jan 29, 2011 | Fisher and Paykel Refrigerators
Fisher and Paykel fridge is making a noice sounds like the fan
heatman101
Jan 22, 2011 | Fisher and Paykel Refrigerators
3 year old fisher and paykel active and smart fridge tripping safety switch . checked other appliances etc different power points, fridge seems to do a sort of computer chatter noise from white electrical...
This is the main relay that is chattering and it can be due to the failrue of the relay if your compressor is cooling the fridge alright.
it will also be good to remove relay and check the contact, ,if bad replace. Also check the main capacitor of the motor and it can be faulty lead to poor starting and making the relay chattter..
Sep 23, 2010 | Fisher and Paykel Refrigerators
Noisy and fridge not cold
well i rember that guy??? that was when i had hair!!!!!!!!!!! sadly its gone now? along with my "get up and go" that got up and went!!!
your fridge,,, come on now,,its 10 years old,, dont you think you have had your moneys worth out of it yet?,,it needs a re-gas, pricy job that is, also maybe a thermostat as well,,,do yourself a faver dont spend money on it, its well past it,,bit like me now! save your cash and get a nice new fridge,,,just so you can show it off to all your palls,,, the old Dr who???happy days "A"?
May 05, 2010 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel fridge buttom freezer with water dispenser
Please advise where the dispenser is leaking? If it is dripping out the front of the door, then I suggest you run the water dispenser to flush about 3 liters of water. Does the noise stop when you open the fridge door?
Jul 01, 2008 | Fisher and Paykel Active Smart® E522BR...
youre meant to if moved, let it sit for atleast an hour before turning on because moving it disrupts the gas inside. Did you do that?
Nov 28, 2007 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
26 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
