Question about Samsung DV331AEW Dryer
Powers on but will not start, control qppears to be running but it will not start
I have aa 2007 chev her with 2.22 liter some of the fuses don't get power and some do on the fuse box block under hood everything to start and run car is dead
2007 Chevy her ? HHR ? 2.2L 4cylinder , check the run/crank relay ! Relay # 51 in the under hood fuse/relay box.
Power to many of this vehicle?€™s circuits are controlled by the module that is designated the power mode master (PMM). This vehicle?€™s PMM is the body control module (BCM). The PMM controls which power mode (Run, Accessory, Crank, Retained Accessory Power, or Off) is active.
Run/Crank Relay The run/crank relay control circuit is connected to a constant ground and is switched by the ignition 1 circuit or the body control module (BCM). The BCM, will in lieu of the ignition switch position, activate the Run/Crank relay during a remote start event. The Run/Crank relay supplies a power signal to the following circuits, when the a Run or Crank power mode is selected:
Automatic transmission shift indicator
Automatic transmission (A/T)
Switched power feeds to the BCM
Electronic brake control module (EBCM)
Electronic ignition module (spark control)
Electronic power steering module (EPS)
Fuel injectors
Powertrain control module (PCM)
Park neutral position (PNP) switch
Dec 22, 2015 | Cars & Trucks
03 Saturn ion brake lights won't go off and sumtimes engine want start and sumtimes it start run 5 secondsand quit
Hi Travis , lets see if we can help you ! First off here is a description of how the brake light circuit works , you need a good understanding of how it works before you can fix it.
Stop Lamps
The 15-amp STOP fuse located in the body control module (BCM) supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to both left and right stop lamp assemblies and the center high mounted stop lamp (CHMSL), through the BCM. The stop lamps are grounded at G401 and G403.
Do you know what a BCM is ? The body control module ! An electronic module .Just like the PCM/ECM - engine computer but for the body thing's ,light's , anti-theft system ,power door lock etc..
The body control module (BCM) has a bussed electrical center integrated into the housing. Body control relays and fuses are installed directly on the BCM which simplifies wiring and junction blocks on the vehicle. The body control system consists of the BCM and its associated controls. Battery positive voltage is provided to the BCM from the instrument panel (I/P) BATT 2 fuse in the Underhood fuse block. The module grounds are wired to ground G201 and G301. The BCM is wired to the Class 2 serial data communication bus as well as discrete input and output terminals to control the functions of the vehicles body .
With starting problems an the brake lights problem you may have a BCM problem , could have DTC's - diagnostic trouble codes stored in the BCM . This would have to be checked at a GM dealer or some other independent repair shop with a professional grade scan tool .
The ignition switch is an input to the BCM , when it receives a start input the BCM energizes the run / crank relay an other things !
Relay Controlled Power Mode
The BCM uses the discrete ignition switch inputs Off/Run/Crank, Accessory and Run/Crank to distinguish the correct power mode. These circuits are also routed to the Run/Crank and Accessory relays for relay controlled power feeds during the appropriate power mode.
Run/Crank Relay The relay uses a Hot At All Times B+ power source derived from the underhood electrical center. The Run/Crank relay supplies a power signal to the following circuits when the a Run or Crank power mode is selected:
Backup lamp circuit
Engine control module (ECM)
Ignition control module (ICM)
Park neutral position switch
Transmission circuit 1 and 2
This is not something for a do it yourselfer , this is dealer or like I said a independent ASE certified repair shop .
Nov 24, 2015 | Saturn Cars & Trucks
I need a diagram for a 2001 VW Cabrio relay. I thought number 6 was for the blinkers/hazards but it's not and its empty. 413 is in there and blinkers and hazards just stopped one day. I don't know if I...
A2Resource
a great vw resource site
Relays:
Num.Relay Arrangement and Pinout (with control number stamped on relay)
1A/C Relay (13 or 140)
1A/C Switch
2Radiator Cooling Fan
3Fan Switch High Speed
4Battery, Fuse 23
5A/C Clutch (via pressure and temperature switches)
6Main Fusebox Battery Power, Fuse 19
7Main Fusebox Ground
8Fresh Air Fan
2Rear Wiper Relay (72)
1Main Fusebox Ground
2Main Fusebox Run Power, Fuse 4
3Rear Wiper Motor
4Wipe/Wash Signal from Switch
3Digifant Control Unit (30 or 32), Motronic OBD1 Control Unit (109)
2Tachometer
3Main Fusebox Start/Run Power
4Main Fusebox Battery Power
5To ECU (relay ) (1990 G60, ABA/VR6 OBD1 only)
6To ECU and Engine Electronics
4Load Reduction Relay (18)
1From Ignition Switch Run Power
2To Main Fuse Box Run Power
3Main Fusebox Battery Power
4Main Fusebox Ground
5Low Coolant Level Control Unit (43)
1Main Fusebox Start/Run Power
2Low Coolant Level Sensor
3Coolant Temperature Sensor, Gauge
6Flashers (21)
2Flasher Output
3Flasher Input/Power
4X/6 (Trailer Light)
7Headlight Washer (33)
1Main Fusebox Ground (B/4 to C/3 to Ground)
2Headlight Washer Pump
3Headlight Switch Pin 56 (headlights) (B3 to D4 to light power)
4Main Fusebox Battery Power (B/5 to Y/2)
5Windshield Washer Pump (B/1 to B/2 to washer pump power)
8Wash/Wipe/Intermittent Relay (19 for standard relay, 99 for variable intermittent module)
2Intermittent Switch
3Main Fusebox Run Power, Fuse 5
4Park/Low Signal (ground when parked, positive when on low speed)
5Wiper Motor Low Speed Output
6Wash Switch (positive for front wash)
9Seat Belt Warning Control Unit (4 or 29)
2Seat Belt Switch
3Door Switch
4Seatbelt Light
5"Key In" Power from Ignition Switch
6Main Fusebox Start/Run Power
7Automatic Shoulder Belt Controller
9Radio/Lights Buzzer (36)
1Main Fusebox Ground (not used)
2A1/4 (Left Parking Lights)
3Vehicle Speed Sensor
4Seatbelt Light (not used)
6Main Fusebox Start/Run Power (not used)
7A2/2 (Right Parking Lights)
10Fog Light Relay (110 for fog lights with low beam headlights only, 53 for parking light/high beam fog lights)
1Parking Light Power
2Headlight Switch Headlight Power (Low/High)
3Fog Light Switch Power, Fuse 10
5Main Fusebox Ground
6Low Beam Headlight Power
11Horn (53)
2To Horns
3Main Fusebox Ground
4From Horn Button
12Fuel Pump Relay (80, 67 or 167)
1Main Fusebox Starter Power (not used)
2Main Fusebox Start/Run Power
3To ECU (Fuel Pump )
4To Fuse 18, Fuel Pump, Oxygen Sensor Heater
5G2/6 (not used)
6Main Fusebox Battery Power From 30B
7G2/7, T1 (not used)
8Main Fusebox Ground (not used)
9M/4, U1/8, G2/5 (not used)
12Glow Plug Relay (102 or 104)
3Engine Temp Sender (preheat)
4Glow Plugs (Z1)To Fuse 18 (not used)
5G2/6 (not used)
9Water Separator, Glow Plug Light
remember to check out the website below for more help
http://www.xjamiex.com/mk2resource/electrical/CE2.html
Dec 30, 2014 | Cars & Trucks
No power going to ignition control module, what would cause this?
Yes, the pink wire to the ICM and from the run/crank relay should have battery voltage in run or start. If not, check fuse 11, a 10 amp fuse in the Fuse Block-Underhood. Also check fuses 38- a 30 amp fuse supplying power to the run/crank relay, and fuse 9- a 10 amp fuse between the run/crank relay and the ECM. All of these fuses are in the underhood fuse block.
Fuse 38-the 30 amp fuse, the power feed for the run/crank relay- will be hot at all times. Fuses 9 and 11 will be hot in run or start. Check for power at the fuses. If the relay is not turning on and sending power to those fuses and to the ICM, and the ECM, (and to the injectors through fuse 16 - a 10 amp fuse), then work back to the ignition switch and the body control module. Wish I didn't have to say that, but yes, the BCM is between the ignition switch and the run/crank relay.
Good luck, Michael.
May 27, 2014 | 2003 Saturn ION
Grundfos runs intermittently and needs power cycle to get going again
What type of pressure switch or pump controller on pump? Could be capacitor check. with power on try spinning fan at rear if starts probably cap. Have it checked. Could be controller faulty.
Jan 27, 2013 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
2007 HHR Has no power, replaced shifter assembly, still no power.
Check all main power feeds to all fuse centers (boxes) ! Do you know what a electrical distribution diagram is ? How to use a DVOM - digital volt ohm meter to test electrical circuits ?
Has no power, replaced shifter assembly ???? No power where ??? And why would you replace shifter assembly ???? What happens when you turn the key to on ? not start ,just on ? Insturment cluster lights up ?
Is the battery good ? Connections an cables ? Your going to need to check power at the battery ,fuse boxes etc.... Confirm there is B+ voltage somewhere !
Your best bet , take it to a qualified repair shop . You have no idea of the complexity of this vehicle ! Everything is contolled by computer ! The ignition switch is a input to the BCM - body control module , by these inputs the BCM will control the vehicle .
The body control module (BCM) has a bussed electrical center integrated into the housing. Body control relays and fuses are installed directly on the BCM, which simplifies wiring and junction blocks on the vehicle. The body control system consists of the BCM and its associated controls. Battery positive voltage is provided to the BCM from IBCM BATT 1 fuse and the IBCM BATT 2 fuse in the underhood fuse block. The module grounds are wired to ground G201, G203 and G305. The BCM is wired to the GMLAN High speed serial data buss, and the GMLAN Low speed serial data buss, as well as discrete input and output terminals to control the functions of the vehicle's body .
Serial Data Gateway
The body control module (BCM) in this vehicle functions as a translator between the High and Low speed GMLAN busses. The 2 communication protocols use the BCM to translate communicated serial data messages between the control modules over the 2 serial data busses.
Power Mode Master
This vehicles body control module (BCM) functions as the power mode master (PMM). Refer to Power Mode Description and Operation for a complete description of power mode functions.
Power to many of this vehicle's circuits are controlled by the module that is designated the power mode master (PMM). This vehicle's PMM is the body control module (BCM). The PMM controls which power mode (Run, Accessory, Crank, Retained Accessory Power, or Off) is active.
Serial Data Power Mode Master
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle, the PMM is the body control module (BCM). The PMM receives 3 discrete ignition switch signals to differentiate which power mode will be sent over the Serial Data circuits. The 3-wire Ignition Switch table below illustrates the state of these inputs in correspondence to the ignition switch position:
The body control module (BCM) uses the discrete ignition switch inputs Off/Run/Crank, Accessory, and ignition 1, to distinguish the correct power mode. The ignition 1 circuit is also routed to the Run/Crank relay for relay controlled power feeds during the appropriate power mode. The BCM, after determining the desired power mode, will activate the appropriate relays for that power mode.
Run/Crank Relay
• Automatic transmission shift indicator
• Automatic transmission (A/T)
• Switched power feeds to the BCM
• Electronic brake control module (EBCM)
• Electronic ignition module (spark control)
• Electronic power steering module (EPS)
• Fuel injectors
• Powertrain control module (PCM)
• Park neutral position (PNP) switch
Do yourself a favor an take it to a qualified repair shop !
Jun 03, 2017 | 2007 Chevrolet Chevrolet HHR LT
Kohler 12res installed 06/06, replaced controller in Dec 10, has worked fine since . This past weekend with storm, generator started and has run for 3 days , generator shut down with SCFO code - which...
SCFO is either what is displayed just before it cranks or when it is first powered up. Sounds like the controller may have forgotten what engine its running or is getting a bad run signal from the start switch. In either case a 1 year old controller should not be doing this. I would try having a local dealer doing a firmware update as there were quite a few for this controller and if this doesn't fix the problem I would start talking warranty with whoever replaced the controller.
Sep 01, 2011 | Kohler 12 kW Emergency Power System -...
My tv buttons wont work.. it just shows a sales thing on the screen. says this is why you should by this tv and starts showing all the tv has to offer. none of the buttons on the tv will work. not even the...
It would qppear the TV is in the "Shop" instead of "Home" mode. If you are unable to access the on screen menus to select the factory re-set option, then the best advice is to contact your dealer to have a service engineer carry out a "cold start-up", which usually requires a special service remote control to be used, this should re-set it back to normal operations.
Aug 22, 2009 | Televison & Video
Fuse blows repeatedly
The auto speed control is failed. Keep it manual and see how it does...It will run at full throttle even when no load is running. Then fix the throttle control when able.
Aug 09, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Printer will not print document coming from PC
On your WINDOWS desktop, left click the START button. LEFT click on CONTROL PANEL, then left click on PRINTERS. On the PRINTERS screen, check for an icon of your Canon printer. If it is there, right click on it, and from the drop-down menu, left click PROPERTIES. On the PROPERTIES page, check if SET AS DEFAULT is checked. If it is your default printer, left click on the PRINT TEST PAGE button and see if it prints. If not, try following the onscreen instructions to correct the problem. If your Canon printers icon does NOT qppear on the PRINTERS page, the driver is not there, Go to www.usa.canon.com ,and left click on the DOWNLOADS tab. Follow the onscreen instructions and download and install the driver. You may have to do this on both computers, or set up one computer to SHARE the Canon with the other. Follow the INSTALL WIZARD'S instrictions, and you should then be able to print again.
Jul 23, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Samsung DV331AEW Dryer Logo
41 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
