Question about KMD PS3 - Controller - Wireless - Shock-Wave - MR6 - 2.4GHZ - Red KMD
How to connect kmd ps3 wireless controller - KMD PS3 - Controller - Wireless - Shock-Wave - MR6 - 2.4GHZ - Red KMD
How to adjust the ice thickness for Hoshizaki KMD-410MAH ice machine.
http://www.hoshizaki.com/docs/manuals/KMD-410M_H_serv_LTR.pdf
Try this site for a manual. The ice thickness is controlled by the float switch. Most all Hoshi machines have adjustable floats. It starts the harvest as the water level drops.
Jun 23, 2017 | Hoshizaki Freezers
Will this controller work for xbox 360?
No because the memory is bigger in the controller than the other controlloers
Dec 07, 2013 | Komodo BLACK Shockwave Wireless Controller...
How to hook up KMD talkback Pro universal gaming headset for ps3
Did you plug the red and white into audion out or audio in on your tv?
Feb 16, 2013 | Komodo KMD-P3-5747 Sony PS3 Wired Gaming...
My mad catz controller will not configure to my ps3.How can i do it wireless?
sir good day there are two way on how to configure your wireless controller to your ps3 console.... the automatic pairing and a manual pairing
first way an automatic pairing
1.turn on your ps3..
2.Connect the smaller end of the included USB cable to the PS3 controller.
3.Connect the opposite end into either USB port on the front of the PS3.
The pair light on the PS3 will flash. When it stabilizes, you can disconnect the USB cable
and use the controller wirelessly.
second way a manual pairing
1.. turn your ps3..
3.Connect the opposite end into either USB port on the front of the PS3. Press the "PS" button on the center of the PS3 controller. The pair light on the controller will flash. When it stabilizes, you can disconnect the USB cable and use the controller wirelessly.
you can try that 2 way on how to configure your controller to your ps3 console if this help you please rate me thank you sir..
Jun 12, 2011 | Mad Catz Call of Duty Black Ops...
PS3 Wireless Controller for PlayStation 3: cannot connect my psyclone wireless controller to ...
There should be a sync button on the top back side of the remote. It's a little pin hole that you hold in for a few seconds with the system on. Please let me know if you're having further issues.
May 05, 2010 | Psyclone PS3 Wireless Controller for...
Its a big ben wireless controller with no usb how do i connect it to my ps3
plug the usb thingy in the pc then connect the bigben controller then take out usb thing plug it into ps3 conct the controller and itz done
Jan 18, 2010 | Sony Wireless Controller for PS3
Ps3 controller
Turn your ps3 on and plug in your controller with the usb cable provided with the ps3 and then press the ps button while it is plugged in and it will connect. Then unplug the controller and it should wirelessly connect.
Jun 14, 2009 | Sony Wireless Controller for PS3
KMD PS3 - Controller - Wireless - Shock-Wave - MR6 - 2.4GHZ - Red KMD Logo
49 people viewed this question
Top KMD Video Game Consoles & Games Experts
James Wishart
Are you a KMD Video Game Console and Game Expert? Answer questions, earn points and help others
