Question about GE GTS22WCP Top Freezer Refrigerator
Weak magnet top seal
When you shut the bottom door the top door opens slightly and dont always shut by it self. is it the magnetic seal around the top door that is weak?
  • timberme Oct 30, 2007
    this worked perfectly. thanks for your on target advise... if you ever need any adivise on buying a car or leasing one. i was in the business with a reputation of taking care of the customer first.. thanks again, bob
  • GE Master
  • 4,655 Answers
Click the link below and go to line 7 and then line 33, Thanks Sea Breeze
http://www.applianceaid.com/refrigerator.html
Posted on Oct 27, 2007
  • John Tripp
    John Tripp Oct 30, 2007
    Thank You, Bob!
Sea Breeze, why do you tell everyone to go to this website? Is this your website and are you advertising for it on fix ya? Sounds like you are directing traffic rather than solving problems. Are you really an expert?
Posted on Nov 03, 2007
Water drops under top door always!
That is strong indication that the magnets inside of the door gasket(s) are weak and aren't holding tight to the door to seal it. The door gasket(s) need to be replaced.
Gene
Aug 05, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Every time the top frig door is closed the bottom freezer door opens sometimes only 10 or 15mm so that the alarm does not detonate. The reverse also happens, ie top door opens when the bottom door is...
There is an air duct that connects the fridge to the freezer. When the opposite door is closed air is trapped and forced out the other door pushing it open.
The door seals contain a magnetic strip that hold the door to the fridge, these magnetic strips have lost their strength, to test this use a shhet of paper. Open the door, place the sheet of paper across where the door closes, shut the door, then slide the paper out. If the paper comes out without any resistance then the door seal needs to be replaced.
Mar 31, 2011 | Fisher and Paykel E522BRXFD Stainless...
Freezer door pops open when the Refrigerator door is being closed
My new freezer did the same thing. I contacted the company and they went into the whole leveling thing. What it has to do with is the magnetic seal. The magnets are not strong enough to keep the freezer door from popping open when closing the big fridge door. They share the same duct. I level my doors on the fridge and freezer so they swing shut by themselves after opening. Just the force of the big door when it swung closed cracked open the freezer door about a quarter of an inch and if left unnoticed created a puddle and made the fridge run overtime. I solved the problem by placing strong magnets inside the fold of the magnetic seal at the handle end of the door. This is the flap on the outside the door seal. I used six magnets on the top and six on the bottom. The magnets were from discarded Sonicare tooth brush heads. They are very flat and super strong. You can find something on ebay. My freezer door doesn't budge problem solved. I did call the company and told them I solved the problem and they still insisted it was the leveling. Good luck, Art Knapp
Jan 08, 2011 | Refrigerators
When we close the refrigerator door the freezer door pops open. It seems like a vacum problem?
Dec 24, 2010 | LG Refrigerators
Every time the refrigerator door is closed, the freezer door pops open. How can we better secure the seals?
Dec 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator door does not stay closed. When the freezer door is closed the refrigerator pops open.
The fridge and freezer share their airspace, so when you close one there is a slight increase in pressure in the other unit. (Much like opening a window can cause a door open/close in your house due to pressure change/air movement) The magnet in your seal of the door is weak and unable to resist the pressure change. The seal should be changed.
Could also be that the door is not shutting properly in the first place due to sagging or skewed hinges that need adjustment/replacement and while shutting just may not be getting a complete seal that it should be.
Sep 02, 2010 | Refrigerators
Intergrated fridge door no longer shtting tightly
some refrierators have magnets at the bottom of the door. some times the magnets get moved out of place and the door no longer makes contact with them. try looking for the magnets with a steel screwdriver and inspect to see if they are in the correct place.
Aug 01, 2009 | Refrigerators
Fridge Door not shutting/sticking
the fridge door stays shut only by strip magnets inside the door seal. cause is possibly that the hinges are out of line or the cabinet distorted. try levelling the fridge and tilt slightly backwards
Apr 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
GE GTS22WCP Top Freezer Refrigerator Logo
441 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
