Question about Digi Zinwell ZAT-970A tal TV Converter Box
The box will not stay on
Box will not stay on
2000 saab 9-5 gearbox light stays on
The warning light will stay on until you rectify the problem with the box. Warning lights are not there to annoy drivers or to be ignored.
Dec 25, 2012 | 2000 Saab 9-5
Dear Sir:
Please reset your code go the next web: www. fitness. manualsonline.com give your model etc, and download for free.
If the problem persist you must call your service company from TV, and ask for the problem, probabley, you must have box faulty. To due 1) variarion in line voltage, or 2)interruption of power frequently.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 20, 2012 | Televison & Video
Got a chipped virgin samsung smt2110c box. I
your signal is down your box will probably be ok but you will find there is a problem with the main junction box
Dec 13, 2009 | Pace Type 30-0060 1121-0369 D1 .060 D2...
A black box stay on the screen covering,
turn on closed captioning. this is the only way we have been able to save the tv. after a few days we were able to turn it off again and the black box was gone.
Dec 05, 2009 | JVC Televison & Video
Closed caption stays on even though the set up menu states the "caption vision" is off
if you are on a cable or dish box caption is coming from the box, on cable turn TV on, box off press menu, get box service menu, turn caption off pretty simple
Aug 09, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My ice box door will not stay closed.
hi, did u checked the door of ur box is it creating prblem because of over loading?
Jul 21, 2009 | Amana ARSE66MB Side by Side Refrigerator
Jacuzzi nova 532 motor run's but won't stay running
If it has the little oval off/on button, it sounds like the control box or off/on button is bad. If you have access to the pump assembly, follow the pump power cord to the little black box (zip tied to a tube up high), this black box has a small cable that goes to the off/on button. unplug the pump from the box and plug the pump into the power outlet. it should run continuously. If it runs, you need a new control box or /offon button. Buy the off/on button first, as this button is prone to water getting into it, and costs less than the control box.
Mar 25, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
X box stays on and telly blurryy but showing the picture?
It sounds like bad soldering, your tv doesn't freeze it's your xbox video/audio output that does. Did you use the towel trick, that is one possible way to have gotten it. You should send it to Microsoft for repair.
Mar 14, 2009 | Microsoft Xbox 360 Console
Little transparent box with 2 in top right hand corner of screen
I found a suggested solution, reboot the cable box (unplugging & replugging) and the mysterious #2 box should disappear.
Jan 03, 2009 | LG 47LG50 47 in. LCD HDTV
Powder box will not stay closed
Hello ,
I have a same problem with different Siemens machine. The dispeser door is opened when the signal comes from control unit. Then wax or bimetall endine opens the door. In my case I can close the box after depowering machine . Immediatly after starting cycle box opened again immedialy.
I posetd request and worry it could be control unit.
regards.
Konstantin
Feb 27, 2008 | Siemens 24 in. SE25T250 Free-Standing...
Digi Zinwell ZAT-970A tal TV Converter Box Logo
49 people viewed this question
Top Digi Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Digi Televison and Video Expert? Answer questions, earn points and help others
