Question about Frigidaire Affinity AEQ6000WH Dryer
Where are the select and option buttons on my frigidare afinity
Why do the headlights. Come on when any door is opened on my 2008 trailblazer
The Headlamps On at Exit and Perimeter Lighting modes can be adjusted using the steering wheel controls to select the wanted function as displayed in the driver information center. The Headlamps On at Exit selection will allow the driver to customize the period of time that the headlamps remain illuminated upon exiting the vehicle. This period can be adjusted from 0 seconds to 180 seconds. The Perimeter Lighting feature allows the driver to select if they want the headlamps and backup lamps to illuminate when the door UNLOCK button on the key fob is activated. This feature can be turned ON or OFF by using the driver information center steering wheel control buttons.
programming Features with the Driver Information Center (DIC)
To enter programming with the driver information center (DIC), perform the following actions:
Turn the ignition to RUN.
Place the vehicle in PARK.
Press the Personalization button on the steering wheel to enter personalization programming.
Automatic Door Locks
Continue with the following steps in order to personalize the automatic door locks:
Press the Select button in order to enter the menu. The first choice seen is the current setting.
Press the Select button in order to scroll through the following options:
• LOCK DOORS: IN GEAR
• LOCK DOORS: WITH SPEED
Press the Personalization button in order to advance to the next option.
• UNLOCK DRIVER: IN PARK
• UNLOCK DOORS: IN PARK
• UNLOCK DOORS: AT KEY OUT
• UNLOCK DOORS: MANUALLY
Remote Activation Verification
Continue with the following steps in order to personalize the remote activation verification feature:
• LOCK FEEDBACK: BOTH
• LOCK FEEDBACK: OFF
• LOCK FEEDBACK: HORN
• LOCK FEEDBACK: LAMPS
• UNLOCK FEEDBACK: BOTH
• UNLOCK FEEDBACK: OFF
• UNLOCK FEEDBACK: HORN
• UNLOCK FEEDBACK: LAMPS
Delayed Lighting
Continue with the following steps in order to personalize the delayed lighting feature:
• HEADLAMP DELAY: 10 SEC
• HEADLAMP DELAY: 20 SEC
• HEADLAMP DELAY: 40 SEC
• HEADLAMP DELAY: 1 MIN
• HEADLAMP DELAY: 2 MIN
• HEADLAMP DELAY: 3 MIN
• HEADLAMP DELAY: OFF
Perimeter Lighting
Continue with the following steps in order to personalize the perimeter lighting:
• PERIMETER LIGHTS: OFF
• PERIMETER LIGHTS: ON
Mar 13, 2017 | 2008 Chevrolet Trailblazer
Stop the beeping noise when a print job is done
Here is how to do this :
1.Login as the System Administrator or Key Operator.
2.Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed.
3.Select the [Tools] tab on the Touch Screen.
4.Select the [System Settings] button.
5.Select the [Common Service Settings] option from the Group section.
6.Select the [Audio Tones] option from the Features section.
7.Select the required option to configure or modify, and then select [Change Settings] button.
8.Select the required audio tone. Audio tone options include: [Off], [Soft], [Normal], [Loud].
9.Select the [Save] button.
10.If necessary, repeat steps 7 - 9 to configure each option.
11.Select the [Close] button.
12.Press the [Log In / Out] button on the Control Panel. An "Are you sure you want to logout?" message will be displayed.
13.Select the [Logout] button on the Touch Screen.
Sep 04, 2014 | Xerox Workcentre 5335/p 5335 Mono Advanced...
Can you add a bookmark?
How to use the GoGear bookmark feature in Audio books:
Adding a bookmark
  • During play, press "Option" button.
  • Select "Bookmark".
  • Select "Add bookmark".
  • Press "Play" button to save bookmark.
Accessing a Bookmark
  • Select "Go to bookmark".
  • Select bookmark from the list you want.
  • Press "Play" button to play the selected bookmark.
Removing a Bookmark
  • Select "Delete bookmark".
  • Press "Play" button to delete the selected bookmark.
Oct 10, 2013 | Philips Gogear SA2RGA04KS Mp3 Video Player
Frigidare affinity turns on but wont start
Suggestion: Besides the big power button, there is another start button almost similar. First you press the big button, then you select your water level, time, load, etc. When this is done you press the smaller button with a vertical mark, something like an exclamation mark. Then machine then starts your job.
Mar 02, 2013 | Washing Machines
When playing Halo Reach online I cant hear any friends in custom playlist. This is both in game and in lobby. If we join a chat party then we can hear each other fine though. When in matchmaking I can hear...
Depending on which type of chat session you are connected to... everyone needs to be in the same chat menu. Sometimes when switching from game chat to party chat you might still be stuck in game chat while others are in private chat or visa versa.
To talk to only players in your game: Press the Guide button, then select Party, Party Options, Chat Channel, and Game Chat.
To talk to only members of the party: Press the Guide button, then select Party, Party Options, Chat Channel, and Party Chat.
To mute an individual: Press the Guide button, then select Party, the player's gamertag, and Mute.
It is a possibility that you are not in the same chat session with your friends. they might be in a party chat with others while you are in game chat. (note you can only have a max of 8 people in one party chat) Or you might still be in a party chat (that everyone else has left) and they are in game chat.
To... Do this... Talk to only players in your game Press the Guide button, then select Party, Party Options, Chat Channel, and Game Chat. Talk to only members of the party Press the Guide button, then select Party, Party Options, Chat Channel, and Party Chat. Mute an individual Press the Guide button, then select Party, the player's gamertag, and Mute.
Key Points
  • Online safety and privacy settings may block access to Xbox LIVE chat.
  • To use Xbox LIVE parties and chat, Voice and Text must bet set to Friends or Everyone
To... Do this... Talk to only players in your game Press the Guide button, then select Party, Party Options, Chat Channel, and Game Chat. Talk to only members of the party Press the Guide button, then select Party, Party Options, Chat Channel, and Party Chat. Mute an individual Press the Guide button, then select Party, the player's gamertag, and Mute. To... Do this... Talk to only players in your game Press the Guide button, then select Party, Party Options, Chat Channel, and Game Chat. Talk to only members of the party Press the Guide button, then select Party, Party Options, Chat Channel, and Party Chat. Mute an individual Press the Guide button, then select Party, the player's gamertag, and Mute.
Aug 11, 2011 | Microsoft Xbox 360 Console
ITS A NEW FRIGIDARE IT WILL NOT COLD TO FREEZE
Possibly stuck on defrost... locate the defrost timer and turn the timer dial... the fridge should come on.... but you still need to replace the timer
Jul 19, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Thoshiba satellite l 300 model no PSC B8E 06M00 HAR.i want to get all drivers of this model laptop.how i will get that.
Here is a link that will help you: http://www.toshibadirect.com/td/b2c/afin.to?stt1=Laptop+PCs&stt2=Qosmio&sttSeries=Qosmio^X305&cm_mmc=explore-_-accessories-_-unavailprod-_-Qosmio%20X305&src=EXPL#1296631706508
Select Satellite Pro-->L300-->you have to select one of the models from the list.
Also check the other link: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Click on Download-->Laptop-->Satellite Pro-->L300-->you have to select one of the models from the list.
If you have further questions or need further assistance regarding this issue, just leave a comment. Thank you for using FixYa. Cheers
Feb 02, 2011 | Toshiba Satellite Pro L300 Notebook
I need to know how to turn off the top two perascopes on a xtr 255
See the steps below from the XTR-255 owner's manual:
OPTION SELECT MODE
Option Select Mode (XTR-255/260/330)
Press the Menu button to enter Option Select
Mode. Each press of the Menu button changes
to the next selectable feature.
The Dark (D) button and the Quiet (Q) button
turns the feature ON/OFF or Blinking. The decimal
point illumination indicates whether a feature
is on or off. A button must be pressed within
20 seconds or Option Select Mode will automatically
be exited.
The fisrt option is VG-2, the second option is the Periscops (which you want to turn off) and hte third is the blue LEDs in the display.
Nov 06, 2010 | XTR-520 Radar Detector
Unable to lock door!
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
Step 6 save all PDF files to a new folder name it FRIGIDARE for easy availbility for printing and viewing.
Thank you and good luck.
Jun 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Show Hidden radio button are not selecting???
The most likely reason is that you're not logged in as an Administrator of that machine.
May 29, 2008 | Microsoft Windows XP Professional for PC
Frigidaire Affinity AEQ6000WH Dryer Logo
14 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
