Question about Toshiba Satellite A205-S4617 Notebook
Computer will not power up
Will not power up. reset bios by removing cmos battery did not solve problem any suggestions?
    Master:
  • Toshiba Master
  • 788 Answers
You can detach the main battery, and leave it for a week. If next week your laptop still has the same problem, then it means your laptop is dead.
Posted on Feb 18, 2014
3 Suggested Answers
sparky1500
  • 1066 Answers
SOURCE: Toshiba Satellite M45-S169 won't boot
you must restore your bios settings to the correct ones. contact toshiba customer support for the correct toshiba settings.
Posted on Dec 24, 2008
harshit_theg
  • 124 Answers
SOURCE: toshiba satellite l305-s5933 cant access bios and wont boot
If you want to reset the Toshiba BIOS , You can try visiting this web page..
http://web.archive.org/web/20080821232354/http://www.11a.nu/software/bios-pc-bios-security-and-maintanance-toolkit/
: Run the DOS executable ..
: And most of the BIOS password resets are done using the same ..
You can try..
Posted on Jan 06, 2012
No signal on monitor, keyboard num key not on/off CPU is running
some bios problem try reset bios given method
The easiest way to clear the CMOS is to enter the BIOS setup utility and choose to "Reset BIOS Settings" to their factory default levels
Yet another way to clear the CMOS is to reseat the CMOS battery. By removing and then reinstalling the CMOS battery, you remove the source of power that saves your computer's BIOS settings.
apply any method and try
May 19, 2012 | Computers & Internet
I m having trouble with my SONY VAIO (VGN-FE770G). i forgot my bios password. kindly send me a solution.
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 03, 2011 | Computers & Internet
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Toshiba (K000002020) Motherboard
3 year old pushed the z power key and computer went into shutdown mode. Now it has no power. I have unplugged it, and held down power key for 30 seconds as suggested by ACER but still no power
shouuld havee restartd when you hold the power button down release and push to start but try this remove the charger and battery from the laptop
then press and hold thee power button down for about 3seconds
replace the battery and charger(charger should be plug into power source)
push the power button to turn on should start up
May 30, 2011 | Acer Aspire m5640 PC Desktop
Trying to enter BIOS on Gateway 7330GZ and it is requesting a password on a old dos type screen
To reset the bios you must clear the CMOS
There are two ways to approach forcing the Bios/CMOS to be reset to its default values: Option #1: Mechanically, by removing all power to the Bios/CMOS thereby forcing it to reset itself to its stored defaults, which include no password or the default password employed by the Bios manufacturer, and Option #2: Using a program to either locate and identify the password and reveal it to you or erasing the password entirely. These are referred to as password by-pass utilities or cracks.
Let's look at Option #1
By either resetting a jumper on the motherboard itself (referred to as a "clear CMOS" jumper), or by physically remove the power from the computer (disconnecting the power plug) and then removing a battery (used to maintain power to the PROM chip that contains the Bios/CMOS information) from the motherboard.
If the "Clear CMOS" jumpers are not present or not available:
Shut down the computer and disconnect the power plug. Locate, if possible, the instruction booklet for your motherboard. Now identify where the battery is located on the motherboard. It will be approximately 1/2 inch in diameter.Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket. Now plug the power cord back in and restart the computer.
for further information read
http://www.dewassoc.com/support/bios/bios_password.htm
May 02, 2011 | Gateway 7330GZ Notebook
Getting a CMOS checksum bad error when starting my Acer M5640 Desktop with Windows 7 Thanks Daniel
Solutions to CMOS Checksum Bad Error
The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
CMOS Battery may not be functioning properly
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer's manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery's information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Your BIOS may have been updated
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue.
akuma_ryu21 rate it pls!!
Jan 21, 2011 | Computers & Internet
Reset bios password acer Travelmate 2410
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some tutorials. For example the tutorials:
Reset ACER Aspire 3610 BIOS Password - Only 8 Steps
Top 3 methods to crack bios password!
3. Use the bios password recovery tool , but that is not free!
So I would suggest you the 1st method. Hope it helps.
Jan 09, 2011 | Computers & Internet
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Mar 05, 2010 | Microsoft Windows XP Professional With...
I have a tosiba tecra 9100 laptop that when I boot up it ask for a bios password, i bought from a garage sale and noone seems to know the password is there neway i can clear that password and start over...
There is a battery on the motherboard. Removing it for about 1/2 hour should clear the bios. There are several software methods also. Google 'bios password removal' to find one.
Jul 18, 2009 | Toshiba Tecra 9100 Notebook
How can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
how can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
May 04, 2009 | HP OmniBook 500 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
