Question about Electrolux Twin Clean Bagless Canister Vacuum
WHEN ON CUTS OUT AUTOMATICALLY
WHAT CAN CAUSE MY CLEANER TO AUTOMATICALLY CUT OUT WHILE ON. I HAVE CLEANED THE FILTERS
How can I get my DC26 working?!
They can cut out due to overheating. Although you say you have 'cleared' the filters, they should ideally be washed as they can clog with very fine dust and cause overheating due to lack of air flow. Once a machine cuts out due to overheating it can take maybe half an hour (or longer) to cool down enough to work again.
Aug 27, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
How to clean
There are 2 Filters that should be washed every 3 months. they are labeled as filter A and Filter B. They only neet to be washed with water. if you use any type of soap or cleaner it will actually damage the filters and they will need to be replaced.
Another part of the vacuum that can be cleaned is the clear bin assembly. REMOVE it from the cyclone before cleaning it. DO NOT get the cyclone wet. it will damage the machine. but again just water and a rag on the bin assy will work great any type of cleaner will actually cause the bin to get foggy.
The only other part to be cleaned is the roller brush. what i would recommed is to take a box cutter, and to cut the length of the roller. all of the hair and fibers on there. then turn the roller brush 180 degrees and cut it again. then turn the vacuum on and vacuum with it for a minute and the debris from the roller brush should be gone.
Sep 17, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Electrical supply cuts out after a few minutes use
Sounds like the motor is overheating and cutting out. The motor has a protection device that automatically resets when the motor cools down.
The most common cause of overeating is blocked or dirty filters. Don't be fooled by Dyson's "lifetime filters". They need to be cleaned and/or replaced regularly.
If after cleaning/renewing filters it still does it, you need a new motor as the trip device is not available separately. New motors can be found on eBay quite cheaply but it requires some special tools and good DIY skills to do it. Have a look at www.dysonmedic.com to see if you you think you can do it, but if not it's time to call a repair shop or the Dyson helpline.
Oct 29, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hi,my dyson animal cuts out and wont restart until it has sat for a period of time,please help thanks
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Oct 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
After using the unit for a few minutes it cuts off.
Apr 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07. Problem:- switch the hoover on and it cuts out after approximately 1 second. Any ideas please?
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Nov 24, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Motor overheats and shuts off
The priamry cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Once a motor starts to overheat, it has already been damaged and even after the filters have been cleaned, may well still overheat and cut-out. The motor has a built in over-current trip to protect itself (and you if it seriously overheated). This normally automatically resets itself, however if the motor has just about had it, the moemnt it is switched on, it just trips again.
Oct 17, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum cuts out.
You wont believe it, but that problem is very common and it is only the LG vacume cleaner that im seeing with this problem . Cant offer any solution like relocating Temp. Th/stat on motor to another position as this is non standard. (do not bridge out as motor does get warm).
Sep 20, 2009 | LG Electronics Premalite Vacuum Bagless...
Sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Jun 22, 2008 | Sebo X4 Bagged Upright Vacuum
Electrolux Twin Clean Bagless Canister Vacuum Logo
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
