Question about Samsung N110-12P Notebook
Forgotten bios password and windows password - Samsung N110-12P Notebook
Unlock password
windows or bios password?
if windows the download a windows password changer bootable cd, if bios then remove bios battery for 10 minutes and replace it.
Aug 25, 2013 | Dell Inspiron 1200 Notebook
Tip
Four Most Common Password Reset Solutions for Lenovo ThinkPad
<span> <p><img src="lenovo-thinkpad.jpg" />Lenovo ThinkPad Laptop password reset or recovery solution varies depending on which password you have forgotten. The hassle of<span> </span><a href="http://www.passwordunlocker.com/knowledge/reset-lenovo-thinkpad-password.html">Windows password reset</a><span> </span>process will range from simple inconvenience to total valuable data loss. For this, we have collected the most used Lenovo Computer password lost troubles and satisfactory solutions for you.<br /><b>Types of passwords for Lenovo ThinkPad Laptop</b><br />There are four kinds of passwords we will talk about Lenovo ThinkPad computer and the password reset solutions:<br /> <ul> <li>1&gt; Windows logon Password (Administrator, Domain and User account)</li> <li>2&gt; Supervisor Password</li> <li>3&gt; Hard Disk Password (Master and User)</li> <li>4&gt; Power-On Password</li></ul><br /> 1&gt;Windows logon Password for Lenovo ThinkPadWindows logon password for Lenovo ThinkPad is used to keep personal information private and we are always create some administrator or user accounts on Windows 7/Vista/XP PC and also domain admin or AD accounts on Windows Server 2000/2003(R2)/2008(R2). It will be a big besetment when you lost or misplaced the passwords of those accounts. However, with some easily password recovery ways, it is possible to re-access your Windows system with no damage of the data.<br /><b>Reset Lenovo ThinkPad Password with Password Reset Disk</b><br />If you are a cautious user, then you should have created a password reset disk for your Lenovo ThinkPad. So you just need to insert the password reset disk to<span> </span><a href="http://www.passwordunlocker.com/knowledge/reset-windows-7-password.html">reset Lenovo ThinkPad password</a><span> </span>directly.<br /><b>Reset Lenovo ThinkPad Password with Available Windows Administrator Account</b><br />If you can log on as an administrator for your Lenovo ThinkPad with a right password, then you can reset any other passwords of your lost or forgotten Windows logon accounts directly.<br /><b>Reset Lenovo ThinkPad Password with Windows Password Recovery Program</b><br />If you have not created a password reset disk previously, or cannot log on as an administrator with a right password, and for this situation, like me, you still have option to reset lost password for Lenovo ThinkPad PC with third-party software.<span> </span><b>Windows Password Unlocker</b><span> </span>is such a powerful Windows password recovery tool which enables resetting windows 7, Vista, XP, 2000, 2003 and 2008 password as blank with 4 easy steps:<br />1. Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker</a></b><span> </span>from its official site with an available PC<br />2. Burn a bootable CD/DV or USB flash drive<br />3. Reboot your locked Windows computer from CD/DV or USB flash drive<br />4. Reset lost or forgotten Windows password for Lenovo ThinkPad with easy<br /><b>Reinstall Windows OS</b><br />Reinstall Windows operating system for your Lenovo ThinkPad will be the last choose if you can reset Lenovo ThinkPad password successfully with those workable solutions that have mentioned above.<br /> 2&gt; Supervisor Password for Lenovo ThinkPadA Supervisor password protects the system infor stored in the BIOS. The user must input the Supervisor password in order to get access to the ThinkPad BIOS Setup Utility in order to alter the system configuration. If the Supervisor password is lost there is no way to recover it to enter the BIOS configuration.<br /><b>Reset Forgotten Supervisor Password</b><br />A forgotten Supervisor password will prevent access to the ThinkPad BIOS setup utility. To get access, you need reset the BIOS password with some solutions like locate the jumpers or solder beads, or just contact the computer manufacturer or motherboard manufacturer for resetting forgotten Supervisor password.<br /> 3&gt; Hard Disk Password for ThinkPad ThinkPadThere are two Hard drive passwords: a user Hard drive password for the user and a master Hard drive password for the system administrator. The administrator can use the master password to get access to the hard drive even if a user has changed the user Hard drive password.<br /><b>Reset Forgotten Hard Drive Password</b><br />If the user's Hard drive password has been forgotten, check whether a master Hard drive password has been set. If it has, it can be used for access to the hard drive. If no master Hard drive password is available, or if the administrator forgets the master Hard drive password, then the hard drive must be replaced. For this instance you just need ask help from your computer manufacturer to reset forgotten HDD password.<br /> 4&gt; Power-On Password for Lenovo ThinkPadAn Lenovo ThinkPad Power-on password protects the system from being powered on by an unauthorized person. When it has been set, a prompt will appear during the system start up, and the Power-on password must be entered before an operating system can be booted.<br /><b>Reset Forgotten Power-on Password</b><br />If the Power-on password is forgotten and the Supervisor password is known, simply go into the ThinkPad BIOS setup utility and reset the Power-on password, otherwise try the following:<br />1.Power off the Lenovo ThinkPad computer<br />2.Remove the battery pack<br />3.Remove the backup battery<br />4. Please power on the computer and wait till the POST ends. If the password prompt does not appear then the Power-on password has been reset.<br />5.Reinstall the backup battery and the battery pack.<br /><b>Note:</b><span> </span>Some ThinkPad systems have the ability to reset the Power-on passwords in the ThinkPad BIOS setup utility if a Supervisor password has been set.<br /></span>
on Apr 19, 2011 | Computers & Internet
Ive forgotten my password on my digihome dtr80,what should i do?
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
Apr 22, 2012 | Computers & Internet
My computer system, #8wp2cl1-595b, is protected by a password authentication system
You can create a Windows password reset bootable CD/DVD or USB flash drive to reset forgotten Windows password, i have created a bootable USB flash drive with the tool Windows Password Breaker and reset my administrator password successfully.
Jan 10, 2011 | Dell Inspiron Notebook
I have forgotten power on password now what can i do
I think you must format your Notebook.
What password ?? BIOS?
If it is BIOS password then try this-Swith off your Notebook and remove it's battery carefully and keep it without the battery about 10 minutes.Then again put your battery to Notebook and switch on.
Dec 20, 2010 | NEC Versa SXi Notebook
I forget my administrator password. please help me
It is said that Windows Password Recovery Tool is the best Windows Password hacker expecially on Toshiba computer. It takes only 4 minutes to hack computer password
More interest, feel free to read this helpful post:
http://www.windowspasswordsrecovery.com/hack-computer-login-password.htm
Jan 11, 2010 | Toshiba Portege 3505 Tablet PC
Crack bios password on compaq nc6320 - please
You can crack dell bios password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Oct 09, 2009 | HP Compaq nc6320 Notebook
How to get my computer unlocked have forgotten
If you've forgotten the BIOS password you need to short the CMOS by setting the jumpers or remove the battery.
If you've forgotten your Windows password you can download a program here and burn it to disc and follow the instructions.
Sep 23, 2009 | Computers & Internet
My dell latitude d820 laptop wont let me in cuz i dont know the admin password. I bought it at a swap meet and i cant use it
If you have forgotten the Windows password:
A forgotten windows password can be problematic.
If you have windows XP HOME edition, boot to the SAFE MODE (Press F8 during boot to get startupmenu) select the ADMIN account (Password should be blank) Once inwindows, go to Control Panel, User Accounts and reset the password onthe effected account.
If you cannot perform the above, then this link has the best listing of recovery suggestions I've found:
http://www.tech-faq.com/lost-windows-password.shtml
If you need to change a forgotten BIOS password, you will need to contact Dell Technical Support for a BIOS Master Password.
Jan 12, 2009 | Dell Latitude D820 Notebook
Henrry
Dec 05, 2008 | Dell Inspiron 1501 Notebook
Samsung N110-12P Notebook Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
