Question about Sony HDE1/B 1TB External USB Hard Drive Standard
Jumper setting for sony hd e1 - Sony HDE1/B 1TB External USB Hard Drive Standard
How to remove write protection from sony hd-e1
PC & MAC use different file systems.
It sounds like your hard disk is formatted as NTFS. NTFS will allow a MAC to read from the disk, but not write to it. You need to re-format it using FAT32 (if your MAC is older) or exFAT(if your MAC is fairly new)..
FAT32 will allow a maximum partition size of 2TB(when formatted from a MAC) and a maximum single file size of 4GB.
exFAT will allow pretty much any file size.
NB:Formatting a hard drive DELETES ALL FILES on the hard drive, so backup whatever is important before you re-format it.
1. Open Applications > Utilities
2. Choose you hard drive from the list on the left
3. Choose the "Erase" tab and choose your desired format (FAT32/exFAT)
4. Type in a new name..Click "Erase"
Apr 10, 2014 | Sony HD-E1 1 TB 2.5" External Hard Drive -...
Sony external hard drive: Error message "USB Device Not Recognized"
It is quite likely the drive is failed. If it is quite new it should still be within warranty. Return it to your place of purchase and get them to confirm it's condition. If the drive prooves faulty they should repair/replace it for you.
Mar 27, 2014 | Sony HD-E1 1 TB 2.5" External Hard Drive -...
I am not able to open hd-e1 to my sony laptop
Is it USB or what? You probably need proper drivers
Feb 08, 2014 | Sony HDE1/B 1TB External USB Hard Drive...
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
How to set jumpers in an old quantum fireball Lct20 HD. The master mode needs to be "jumpered"
Please look on top of your HD and u will see a table that show u the HD jumper setting (Master, Slave or Cable Select).
Then look again the rear side of the HD and u will see some pin that locate beside the power input of the HD, that is the jumper pin.
Now set the jumper according to your requirement refer to the jumper setting table just now. To set it just unplug the jumper (look like a U shape contactor covered with plastic) and plug it back according to the requirement. Sometime u may lost the jumper contactor, nevermind just use what ever conductor cable to roll between the two pin and make sure the pin is connected that all.
YBC (/\)
Oct 06, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Installing 500 GB EIDE HD in a SONY PCV-RX560
what are the jumper setting on the hard drive. make sure the old one is the master and the new one the slave.
Jun 13, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
M825 pcchips amd k7 power on but no video
Here is the website to look it up from. I was trying but you will need your CPU socket number to look it up so you can download a manual which will show all of the contacts and jumpers necessary, for you.ttp://www.pcchips.com.tw/PCCWebSite/Support/Category_Support.aspx?MenuID=3&LanID=0
Feb 15, 2009 | PC Chips M825G Motherboard
How to set timing on 1988 celica?
Under the hood, locate the diagnostic connector. Open the plastic cap, and look under it for the locations of the following pins: T and E1 (TE1 if you have a Calif spec car and E1). Using a paper clip, jump the two pins together. Hook up your timing light and set the timing to 10 degrees BTDC. Then, remove the jumper wire. Easy.
Jul 18, 2008 | 1988 Toyota Celica Liftback
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 15, 2008 | Maxtor Hard Drive
Multi Region Toshiba HD-E1 DVD
RCE Hack.
1) Turn on player
2) Open tray, put disc in tray but don´t close
3) Push T.search on remote
4) Push 1, 3, 9 and "Region number" (e.g. 1 for US discs)
5) Push T. search on remote.
You will see TEST on your player
6) Press PLAY on the remote
When player is turned off, this setting is cleared.
Mar 14, 2008 | Toshiba HD-E1 DVD Player
Sony HDE1/B 1TB External USB Hard Drive Standard Logo
57 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
