Question about Radio Communications
Motorola talkabout p14spa03p2aa
Setting a channel
Neto
  • 123 Answers
SOURCE: Motorola Talkabout T6500 will not transmit.
Are you sure the batteries are ok?, try to change the batery, check the radio battery contacts, verify if when you press the ptt, appear an icon on the display that correspond to TX function. Try to use an audio accesory to TX, if all this fail, you should replace it. Good luck
Posted on Jan 22, 2007
Agent Ken
  • 250 Answers
SOURCE: Will a Motorola TalkAbout T5320 transmit to a Motorola TalkAbout T5530?
Hello Blindmaster,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a “Privacy Code” or “Quiet Code.” The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on your T5530s but is not enabled on your T5320. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code “4” on the Motorola TalkAbout series actually corresponds to code “A” on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Posted on Apr 07, 2008
eradiostore
  • 1654 Answers
SOURCE: what will i do to connect Motorola T5720 and T5728
Set both the frequency and the interference eliminator code to match one another. (The big number and the small number) Here is a link to the owners manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Basic instructions:
Press the Menu Button
The freq number will flash
Use the + or - button to select the frequency.
Press the PTT button to save the channel setting.
To set the code:
Press the menu button until the code starts to flash (the small number)
Press the + or - to select the code.
Press the PTT to save the code setting.
Once you have both radios matching on frequency and code, they should communicate together.
Posted on Aug 21, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola talkabout 200
Here is a link to the TA280 manual, which is similar to the TA200, http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T280_User_Manual.pdf
Funny thing, I haven't found the TA200 manual in English. Here it is in Czech: http://www.cbradio.cz/doc/Motorola/PMR%20TA200/manual.pdf If you do a google search, you can find the page and have it translated. I'll keep looking, and if I find it in English, I'll repost.
Posted on Nov 10, 2008
eradiostore
  • 1654 Answers
SOURCE: how to set interference eliminator code on motorola two way radio
The FV300 does not have the interference eliminator code feature. (Sorry)
Posted on Jun 30, 2009
WHERE A CAN GET THE VOLUME KNOB FOR THE TALKABOUT 250?
Contact Get Support at Motorola Solutions for the part number. If not available direct they might have a repair shop who could provide it.
Mark
Motorola Mobility Support
Mar 03, 2015 | Motorola Talkabout 250 2 Way Frs Radios...
What frequency does my motorola talkabout have
If they're all set to the same "Channel" and "Code" you will be able to talk between them.
Apr 15, 2014 | Motorola Talkabout T5300 (14 Channels)...
I have the motorola talkabout t5300 and I'm trying to find the privacy setting
Sorry. It appears the T5300 does not have privacy settings (interference code eliminator) capability. Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
Best regards.
Aug 23, 2012 | Motorola Talkabout T5300 (14 Channels)...
Motorola Talkabout 200 - how do i set main channel only? i need to set for example channel 1 and subchannel 0 (1-0; 2-0; etc) but i can only set a main channel with subcode for example (1-1; 1-2; 1-38
Here is a link to the user guide for the T289. It is the closest we have fofound to the T200 guide: http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
It may be of assistance to you. Honestly, we were thinking the early model T200 and T250 did not have the interference eliminator code., just 14 channels. However, if you are experiencing other numbers, it is possibly the code.
Best regards.
Jun 10, 2012 | Motorola Talkabout FRS 250 (14 Channels)...
Describe how you call someone with the motorola talkabout 250
Your question is unclear. Call them from where? Using what device?
If they have an FRS phone, set the channel and privacy code and go.
Feb 09, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
I have a Motorola Talkabout T5419 not receiving
motorola has extra security and will not operate with other radio makes very well. It must be locking out the uniden radios.
Oct 27, 2009 | Motorola Talkabout T5420 (14 Channels)...
How to set interference eliminator code on motorola two way radio
Jun 30, 2009 | Motorola Talkabout T5500 (7 Channels)...
Users Manual on how to use
Motorola Walkie Talkie Code and Channel Setting
  1. Push and hold On/Off button. It will tell you Code & Channel
Note: You are now in the change mode
  1. Change Code - Push the talk button till handsets match Code then push monitor button to accept
Note: You are still in the change mode so you can change Channel
  1. Change Channel - Push the talk button till handsets match channel then push monitor button to accept
  2. To check repeat step 1 then push on/off button
Dec 19, 2008 | Motorola Walkie Talkie 2-Way Radio
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Radio Communications Logo
74 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
