Question about Samsung DV331AEW Dryer
DV350AGW/XAA will power on, but does nothing when you push start
You can hear it click about twice, but does not start
I have a bsch was3274 does the same turns on here the relays click 2 or 3 times and water dosent start going in to the machine
Posted on Feb 16, 2014
Why wont my Samsung DV220AEW/XAA start ?
Hey GOD IS GOOD !!!!
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
GOD IS GOOD !!!!
Sep 04, 2014 | Samsung Dryers
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
The dryer will not start when you push the switch. Have checked the plug and power at the box. It sounds like the clock on the setting is working, but nothing happens when you push the button
Try this simple test. As the door opens or closes you should hear a muffled click of a switch. If you don't hear that click when the door is just ready to close or just opens the door switch or actuating arm has failed.
Jan 22, 2010 | Whirlpool LGB6300 Gas Dryer
My Mac Book will not work i plug in the power cord and turn it on you can hear the fan going but nothing will turn on and i leave it alone and the fan will go on forever without any progress. help please
Have your Mac OS disc handy, start your computer, as it starts, press and hold the power button, this will cause the mac to shut off. Then push the button again, while it is starting push your os disc in the drive. The goal is to get the computer to load the OS disc so you can access the Disk Utility program from the file menu.
If you're having trouble getting past the fan still, restart while holding the commnad, option, p and r keys together. Continue to hold these down until you hear the start up chime. keep holding and let it do this twice. This is "zapping" thie PRAM ... Then start it again... These should help...
k
Sep 06, 2009 | Apple MacBook Mac Notebook
Sony rear projection doesnt turn on
The power supply unit is bad and will need to be replaced. Aroung $150 just for the power supply unit if you can connect it yourself you can save over $200 bucks.
May 25, 2009 | Televison & Video
Dryer won't start when pushing the button it clicks
Could be a broken belt if you hear motor, also can be defective door switch. you can try pushing door switch with finger and press button If motor does not make a sound and pressing door switch does nothing you will need a volt meter and test for power if you hear moter then its broken belt or jambed drum. Try and manually move drum
Jan 14, 2009 | Kenmore 62602 Electric Dryer
Whirlpool LER8648LW0 wont start when you push the button
check your door switch to make sure it is good / if switch is bad it will do that / larryyb
Nov 30, 2008 | Dryers
Powers off by itself
Usually leaky power supply diode and two bad caps-----need service # and chassis # from sticker on back of set .....T.
Jan 22, 2007 | RCA 32V420T 32" TV
Samsung DV331AEW Dryer Logo
231 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
