Question about JVC TH-A75R System
When put surround sound on keeps saying overload
2 Suggested Answers
yuzik58
  • 18 Answers
SOURCE: my jvc rx-6010v is OVERLOADING?
Disconnect your less dominant speaker or switch from DVD to CD etc. Just had this problem and it fixed it
Posted on Nov 01, 2016
Amp keep's sating overload
Have you tried disconnecting all the speakers and inputs and turn it on?
If it still shuts off you have an internal problem, if it stays on, connect one item at a time until it shuts off and that is the problem.
Jan 13, 2013 | Panasonic Technics Sa-gx690 Av Control...
My ht-z31 dvd surround sound turns on and immidiatly says protect and shuts down. what do i do?
the protect means a circuit overload check that you dont have any wires for your speakers touching or backwardly installed if those are all fine you may have blown a fuse inside the receiver.
May 07, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
No display on my receiver and no sound coming out of speakers except for surround sound
with out anymore info. i would say you overloaded the plug which is on the back of your receiver, this inturn blew a circuit of fuse.
Mar 20, 2011 | Sony STR-G3 Receiver
Overloading
hi mate, ive had the same problem before with this amp. i bought it new aout 6 years ago and bought another new one about 1 year ago, new, for £70!
on the first amp there was a problem with the surround sound aspect, it kept overloading when turned up even a fraction, it would tick 4 times and power off. Eventually the surround sound stopped working all together and whenever selected made a VERY VERY loud hissing/crashing noise through all my speakers, blowing one of them, SO BE VERY CAREFULL.
when that happened i assumed was broken so bought another one, and had same overload trouble when i got a new speaker package.
Im pretty dam sure it was the ohmage ratings being different on 2 of the surround sound speakers that srewed the 1st one, so id suggest you check theyre all ok, as well as the speaker watt-age.
what are the specs on all your speakers (ohms and watts RMS)??
do you listen to LOUD music through the 5.1 option??
hope this helps, if all else fails buy a new one mate, theyre so cheap. go into panasonic shops and see if they have any left.
Apr 23, 2008 | Panasonic SA-HE7 Receiver
JVC Surround Sound System
The click will be a relay to protect the main amp overloading. In many ways you are driving the amp to hard, unless there is a fault on the main amp which means it can't take the full load that it should handle. One cause of this for example would be a speaker that is either the wrong ohms, or of a lower wattage than what the amp can put out. Or in some cases a faulty speaker, or if the wiring is not good shorts when the speaker shakes when a very loud noise comes from it.
Things to check:
1 That no speaker is lower ohms than the amp.
2 That no speaker is lower in watts (RMS) than the amps total output for that channel it is on. Remember not all surround amps have the same volume on each channel.
It is of course possible to use smaller wattage speakers. But if you have an amp that can output say 200w. Connecting an 80w speaker to it would really limit the amount the volume control could be raised to.
3 Each speaker is working right. Plus all connections are neat with NO possibility of shorting.
If all of these are good then you have a fault on the main power amp. Probably one or more of the output device(s)
May 09, 2017 | JVC SP-PW100 Subwoofer
My jvc rx-6010v is OVERLOADING?
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (JVC - and others - say SIX ohms, but 8 is the "standard" you should use.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: The internal overload protection system you mention is designed to help prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized JVC service center must do this. Note, though, that if you have attempted to "cheat" the system several times, damage CAN be done that requires servicing.] But, before you take the unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 10, 2007 | JVC RX-6010V Receiver
Dvd played one day and hasn't since
the belt is broken for the carocel (the disc can not change) it is plobabely stuck b/tween discs therefore it keeps opening and closing saying error . eventually it turns off. can be fixed with a small elastic goody hair tie w/o metal clasp
Feb 11, 2007 | kawasaki SVP500 Multi-disc DVD Player
JVC TH-A75R System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
