Question about Bosch WTMC3500UC Gas Dryer
How to get at the lint under the lint filter on a bosch wtmc3500uc dryer
Want to remove the accumulated lint in the front panel and under the lint filter on a bosch wtmc3500uc dryer
5 Suggested Answers
  • 4102 Answers
SOURCE: Will not start
are you sure the switch on the door is working properly has this been checked properly if so the probelm could be with the motor as the build up of lint could cause it to over heat therefore blowing something on the board this will need to be checked you will need to check that you have got power going to the motor and the correct amount of power myself i would have said replace the switch on the door but if you are sure you have checked this then the problem could be the motor or the board that powers the motor check all conectionsand look to see if you can see any areas that look like it has over heated if you have a resistance testor you could check the board if not you will need to go to a repair shop and get them to test the board and motor for you hope this is some help
Posted on Nov 19, 2007
SOURCE: bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Posted on Mar 30, 2009
  • 615 Answers
SOURCE: After one load, dryer stopped working. lint
With the exhaust clear, you need to be sure that air is actually moving. It could be a bound or bad exhaust blower.
Posted on Mar 28, 2010
Testimonial: "Thanks for you info. How can I check on a bad exhaust motor when I can't get the dryer turned on?"
SOURCE: dryer will not heat. lint filter is clean. dryer
I think this is all good advice. I have a Bosch that was not drying well at all. I called for repair, and the guy showed me that the problem was my lint filter. I grew up with very coarse, metal lint filters. I am not used to these super fine German mesh jobs. So, even though I thought I was cleaning the filter, over time there was a fine build-up of lint that created a blockage. He showed me this by removing the lint screen and running water on it. The water just pooled on the surface. What you need to do is run hot water and soap through it, getting it extremely clean until it is transparent. Then the dryer worked fine again. My dryer was putting out heat (I could feel the back of the machine getting hot), but the blocked lint filter (which looked clean, but wasn't) triggered some sort of sensor that ended the cycle prematurely. Everything works fine now, and the solution was only hot soap and water. You should only have to do this once in a awhile.
Posted on Aug 09, 2012
Wtmc3500uc-bosch front load dryer -lint light preventing the dryer from working
You may very likely have to take the machine all apart and clean the inside lint tubes, as they may be plugged up.
If this is the problem, it is because the lint inside the machine is so bad that to continue to run it could cause it to catch fire.
I have cleaned 6 machines in the last 2 years that were so bad I got a shoe box of lint out of each machine.
God bless your efforts.
May 19, 2016 | Dryers
How do ou get to the heating element in a Bosch WTVC533SCN/09
These heaters, and safety thermostats are accessed from the rear of the unit by unplugging the dryer from the wall, and removing all the screws that hold the rear silver panel on after removing the main top. The heater is located in the lower right corner. While the heaters are less likely to fail, you do have a red button reset thermostat that often is the reason for no heat. These resettable thermostats trip for a reason, and become easily strained when tripped even on the first time, a real cause of failure should be discovered regardless what part has gone bad. Home vent systems should be checked by a reputable vent company. Remove the lint filter, and using a flashlight, you should be able to see a tiny probe in the lower left bottom area of the lint filter housing, if it's covered with lint, or even partially covered, this housing needs to be completely cleaned. Additionally the Bosch lint filters themselves are very fine filters, and are subject to congestion by both lint, and residue from dryer sheets. It's advisable these filters should be cleaned with warm water, and a de-greaser like pine-sol or similar to ensure they are breathing properly. Pleazer Appliance...
Apr 11, 2014 | Bosch Vision 500 Series Front-Load Washing...
Need to take off front panel to remove accumulated lint below lint filter. I took out as much as I can but there is a lot more. We do clean the filter with each use.
Use a putty knife to release the top
Remove the screws holding the front and get it out yer way. Take the back service panel off and release the idler from the belt and lift out drum using the belt to help you.
HOW TO VIDEOS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 09, 2010 | Frigidaire GLGR331A Gas Dryer
Hello I need to get to the belt on my dryer how do i get to it?
Unplug the dryer.
Remove the 2 screws under the lint filter lid.
Remove the lint filter.
Use a putty knife to push in on the 2 clips on the right and left front between the lid and the front panel.
Raise the top lid and move it to the back of the dryer.
Look inside the right and front corners and remove the 2 screws holding the cabinet case to the front panel.
Remove the wires from the door switch.
Pull up and out on the front panel.
You are now in the dryer.
May 24, 2010 | Maytag MED5700TQ Electric Dryer
Mar 28, 2010 | Bosch WTMC3500UC Gas Dryer
How do you replace a belt on model 11060622990
Unplug the dryer.
Remove the 2 screws at the lint filter opening.
Use a putty knife between the top lid and the front panel to release the clips.
They are about 2 inches in from right and left sides where the top meets the front panel.
Lift the lid towards the rear of the dryer.
Look inside the top right and left corners of the front panel and remove the screws holding the front to the cabinet. Remove the door switch wires and set the door aside.
Place the new belt over the drum,ribbed side towards the drum.
Look under the drum for the belt tensioner. It is S shaped with a wheel on it.
Place the base of the tensioner in the slots below the motor pulley.
Feed the right side of the belt through the opening under the wheel with the smooth side of the belt touching the wheel.
Place this side of the belt over the motor pulley with the ribbed side touching the pulley.
Replace the front panel.
Hook up the door switch wires.
Replace the panel screws.
Reattach the top lid and lint filter screws. Replace the lint filter.
Plug in the dryer.
Jan 03, 2010 | Kenmore Dryers
How do I change the drive belt?
Unplug the dryer.
Plug in the dryer.
I recently had an ventless Bosch dryer installed (WTE8600US) and I keep receiving this message F:03 which the manual says "check hose for condensation outlet". any advice?
For the F:03 problem on the Bosch Axxis (WTE86300US) do all the things mentioned in Solution #1 above. Sometimes the lint in the condensation filter channels (those that run from front to back)can be quite stuck. Use a pipe cleaner to get in there or a garden hose with a spray nozzle. However there is one more crucial step not mentioned in the manual or in Solution #1. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver and gently pop it open. Under the panel is a small chamber where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place. This should fix your problem.
Dec 13, 2009 | Bosch Dryers
Bosch WTMC3500UC gas dryer runs but does not heat
my dryer does not put out lint, rather thru the front.
Aug 22, 2009 | Bosch Dryers
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Bosch WTMC3500UC Gas Dryer Logo
81 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
