Question about Home
Cannot get pendelem to work
Will not keep moving
  • 277 Answers
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling.
http://usedclockparts.com/8-clock-movement-repairs/39-how-to-easily-clean-and-or-fix-your-clock-movement
Posted on Oct 03, 2016
Metamec spring driven pendelem clock won't chime how can I resolve this problem
Mine won't chime any more and a repair man tells me a part has worn out and needs replacing. Over time they all wear out.
Jun 12, 2017 | Chime Home
Why did this tablet stop working the day after my son was on?
Try this first Diana
How to solve the Tablet PC Keep Moving Forward problem
and there are also Video fixes..https://www.google.ca/search?q=+Tablet+PC+Keep+Moving+Forward&sourceid=ie7&rls=com.microsoft:en-US:IE-ContextMenu&ie=&oe=&gfe_rd=cr&ei=p5GAVtrbKqai8we67JyAAw#q=Tablet+PC+Keep+Moving+Forward&tbm=vid
Dec 28, 2015 | Tablets & eReaders
I recently moved my melodies in motion clock back one hour for daylight savings time and now the clock is not keeping time. I suppose I should not have moved it backwards but now what do I do to get the...
By moving the clock back one hour you changed from DST to standard time, not as you stated. Some clocks require you to rotate the hands clockwise to set the time back. Your clock may have been damaged beyond repair.
Nov 05, 2013 | Seiko Melodies in Motion Clock
Have a Seth Thomas Banjo clock - estimated to be @ 60-70 years old - was working perfectly for many years - recently moved and movers took off pendelem weight so not to lose it - now clock will not run...
Is it spring wound or weighted with pine cones? I have a feeling the movers wound it up for you and over wound it. you can release the tension on the spring by carefully letting the key unwind while you hang on to the catch, I just got a clock from somebody, it was way over wound, took about 10 full turns out of it and got it running, it has been going for about a week without touching the spring. I haven't got the chimes back yet.,,, Now if it is a weighted mechanism, the chain may have jumped the track. Check that out. Other than that, I can't see why it shouldn't work. Hope this helps.
May 22, 2010 | Seth Thomas St. Thomas Creations 6006.130...
I moved a small refrigerator from one room to another, worked fine in first room, but now it will not get cold at all. Power does work, as the light is on inside. I am in Kuwait, so this a 240v model.
Possibly the fridge was moved horizontally instead of keeping it vertical. (Always keep fridges upright when moving them!) This can transfer liquid refrigerant into areas of the system in which the refrigerant is supposed to be a gas. Try unplugging it and leaving it to settle for a few days, hopefully the liquid refrigerant may drain back to where it should be. Otherwise, you may be up for a new compressor.
Mar 01, 2010 | LG Refrigerators
Blackberry trackball wont work
I have the Blackberry Tour.......I work in all kinds of environments....so I get dust, dirt, and debris in my trackball......every 3-4 weeks I cannot move the trackball.......all you gotta do is get AIR DUSTER, the same you use for your computer keyboard etc. and keep it about 3-4 inches away and spray the air at your trackball and move it around......just keep spraying it for about 1-2 seconds at a time and move the ball around after every spray and you are good to go!!!!!
Nov 09, 2009 | Lands Phones
Cassette doesn't load and move down into machine
I had the same problem. With the camera on, keep taking the battery off and putting it back on. Start to close the door and then open it. Eventually you should hear it try to move. Keep doing it and it should move down all the way.
Jun 01, 2009 | Sony DCR-HC38 Mini DV Digital Camcorder
Freezing
I have the same problem with my genesis. Most likely it freezes if you make the cartridge move any, which is hard to avoid on these older consoles. Same goes for any cartridge based console i.e. NES,SNES,N64 sega
Theres a cheap way to keep the cartridge from moving though, heres what i do; As your inserting the game, wedge something like a quarter, or a small piece of cardboard with the game. It keeps the game from moving, and thus keeping it from freezing.
hope this works for you!!
Nov 20, 2008 | Sega Genesis Console
Scanner is not working
Hello! greetings of the hour. I'm having problem with mine printer Hp psc 2210 all in one,the is that when ever in pluge it in it does'nt work at all .all it does was the light inside moves just an inch and stay OR hold in one place and beings to make some niose but the motor will keeps moving the belt but not the pannel that carrys the light and of cause the light it self will be also on .
so please tell me what might be the problem. i repect the whole mechine will be on but the pannel that moves from one end to another end will be just still as if some thing was holding him not to move.
Thanks and i'm looking forward to hear from you. bye......Rui
Dec 13, 2007 | Lexmark X2250 All-In-One InkJet Printer
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
