Question about Sanyo Split System Air Conditioner
Operation light blinking compressor not operating
Toyota 2004 A/C compressor clutch seizing
need PUC unlocked
sim TF64SIMC4
# 7064316017
Apr 18, 2013 | 2004 Toyota Sequoia
Fujitsu AST12LSACW - The green timer light is blinking on the indoor unit. The unit is in cooling mode but the compressor dosent come on and only the indoor fan operates. There is power to the outdoor unit...
Compressor contactor relay struck or relay not activated. Remove L1 and L2 wires and jumper with L1 with T1, L2 with T2 and check now. Be careful. It's only checking. When compressor starts, switch off and replace contactor relay.
Jan 27, 2011 | Refrigerators
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts...
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Jan 19, 2011 | Heating & Cooling
Lights are blingking
thermostat command to out door unit not there . Check your PCB
Jul 14, 2010 | Samsung AS18A6RB Air Conditioner
I have a fujitsu asta18lcc when you turn it on there is no operation. The louvers open and the timer and operation lights blink 5 times then there is a 6-7 second pause then the cycle repeats
Below is an extract straight from the fujitsu service manual:
Compressor location error
The compressor speed does not synchronze with the control signal. (Including start up failure of the compressor).
> permanent stop.
[Diagnosis Point]
Check if 2-way valve or 3-way valve is left open.
Check the compressor (Winding resistance value, loose lead wire).
Refrigeration cycle defective (Refer to after mentioned "refrigerant cycle diagnosis")
May 13, 2010 | Fujitsu 18C1 Air Conditioner
Where is the low pressure switch for my Honda Odyssey 2003 AC ?
The A/C pressure switch is located in the high pressure line (the skinny one) on the passenger side of the engine compartment just under the fuse/relay box. The switch has three functions: <28 psi, the switch opens to protect the compressor from lack of lubrication. >220 psi, the switch shifts the radiator and compressor fan to high speed. >455 psi, the switch opens to protect the compressor seals. Check to see if you have any powertrain DTC's first. A faulty engine coolant temp sensor can cause problems with the compressor clutch relay. If the radiator and compressor fan come on with the A/C on but the compressor clutch does not operate, check the compressor clutch relay. You can also obtain Heater control panel diagnostic trouble codes (DTC's) by turning the ignition switch on. Then turn fan switch off. Press recirc button to select recirc air. Press and hold recirc to turn off recirc air but this time continue to hold the button down until recirc light comes on for two seconds and then goes off. If there is any trouble, the recirc light will then blink a code (if no trouble, the light will remain off) 1 blink = problem in air mix control motor circuit. 2 blinks = a problem in mode control motor circuit. 3 blinks = a problem in evaporator temperature sensor circuit. (this one could be a factor in your case) Turn the ignition switch off to end the test.
Mar 16, 2009 | 2003 Honda Odyssey
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Sanyo  Split System Air Conditioner Logo
24 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
