Question about Roper RGX4634KQ Gas Dryer
Roper Gas Dryer
I have a Roper Dryer that has worked well for about 2 years.  It has stopped heating on the automatic settings ( it will stills blows air and tumbles).  It will heat on the timed settings.  What is the problem?
  • 6 more comments
  • Anonymous Nov 14, 2007
    dryer will tumble but not blow any hot air
  • bar5464 Nov 25, 2007
    I have a 5 year old Roper RGX4634KQ dryer that won't heat. Ventilation has been checked and cleaned. I can get it to heat occasionally for 30-60 seconds. HELP!
  • Anonymous Nov 26, 2007
    BLOWS COLD AIR IT TUMBLES IF I LET IT GO FOR 4 TO 5 HOURS OR MORE IT WILL DRY MY CLOTHES WITH COLD AIR
  • Dave 1246 Dec 22, 2007
    My Roper Gas Dryer Mod. # RGX4634KQ2 turns, but does not get hot .
    I've read it could be one of the two fuses but I don't know where they
    are. Could you help me with finding the location of these fuses?
  • flabby hawk May 11, 2008
    Roper RGX5634KQ2 Gas Dryer
  • Anonymous May 13, 2008
    runs but will not get hot the thermal fuse is ok but the glow igniter will not work either
  • jimbo c Jul 16, 2008
    roper dryer won't light. i removed the plastic peep hole at the front and watched as i started a heating cycle. nothing. it seems that the glow plug is not glowing at all. i assume it needs replacing. is this something the average guy can handle or should i call an expert?
  • ballinpimp24 Jan 03, 2009
    My dryer will not heat up either. On any setting. I looked through the peep hole in the front and i do not see anything glowing. What do I need to do? please help
Taking the back off the dryer towards the bottom in the center there is a white pc.of plastic about 3 inches long and 3/8" wide. Its clipped on the inside panel and has a screw securing it. It has two wires clipped to it.Thats the fuse ! I got a replacement form the local Sears parts store for about $15.00.
Posted on Dec 31, 2007
On the front of the dryer there is a plastic hole cover. Take it off. If, when you start the dryer, you see it try to ignite (glow) but does not flame up, most likely the coils have gone bad. $20.00 online, $40.00 ata local store.
I have a roper changed heating element. Still blowing cool air. Sister didnt tell me it only comes on in cooldown cycle. Wats could this be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 17, 2011 | Roper Dryers
Roper gas dryer has no no heat. not really sure of dryer #. but this is the basic set up.
heatman101[
Mar 24, 2011 | Roper RGX4634KQ Gas Dryer
The dryer blows cold air instead of hot air.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 11, 2010 | Roper RGX4634KQ Gas Dryer
What can make my dryer stop heating or to heat randomly?
heatman101
Jun 29, 2010 | Roper REX4634KQ Electric Dryer
My roper gas dryer doesn't heat and the timer dial does not advance. I recently cleaned out the interior ductwork, it worked fine for a week, and then it seemed like the timer started becoming less and ...
heatman101
May 28, 2010 | Roper REX4634KQ Electric Dryer
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Dryer not drying cloths
http://www.pcappliancerepair.com/model-display.php This shows the screws (#2) that hold the front on. Use a putty knife to push on spring catches (#20) to release the top.
Jan 24, 2009 | Roper RGX4634KQ Gas Dryer
Roper Gas Dryer
hi first thing to do is clean all the venting and try again. thanks the appliance doc
Apr 19, 2008 | Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
1,587 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
