Question about Tablets & eReaders
My tablet adtab 7 is asking me to boot in recovery mode so I hold down vol up and power key and no lying down android appears just says are you sure system recovery press power button so I do and then is says recovery confirmed and underneath that apears a new message saying boot into system recovery and thats it no menu no lying down android no options at all and pressing buttons and touchin screen does nothing PLEASE HELP ME IM GOING MAD HERE
SOURCE: Screen Rotation
you have to drop the device back to its native resolution 800x420 for the rotate function to work
Posted on Jan 09, 2008
SOURCE: Gateway Tablet, BSOD unmountable_boot_volume
you have to go to gateway and download the driver for the SATA controller then save it to floppy or cd then hit F6 durning install then it will ask you for the driver. This Tablet will not see a non-gateway cd if you have the one that came with the tablet then you are good, but if not you will need to do this for the current drive or if yo upgrade to newer drive. Hope this get you started, I had this same problem and I thought it was my motherboard was bad because it would not see the hard drive during installation. This fixed my issue with the drive not being seen during installation of the OS.
Posted on Nov 26, 2008
anjana03
  • 361 Answers
SOURCE: tablet pc rotation
u can use once time alt+ctrl+ any type arrow to roated screen
Posted on Jun 13, 2009
  • 15 Answers
SOURCE: i dropped my android tablet
You will need to replace the screen, it has whats called a "digitizer"(it is what take the input from you finger and selects the corresponding selection on the screen), I would presume this is damaged.
Posted on Mar 02, 2011
em_br_dj3
SOURCE: I HAVE A PANDIGITALSTAR ANDROID TABLET WHEN I TURN IT ON IT STAYS ON THE WHITE SCREEN AND SAYS PANDIGITAL WITH THE BLUE DESIGN BUT I HAVE NO ICONS AND WHEN I PRESS THE BUTTONS AT THE BOTTOM NOTHING HA
had same problem. I figured it out. While pressing the home key on the bottom of the tablet, press the on/off button until a black screen appears with green words on the side, which says upgrading...please wait...wait. It should take you to the Pandigital screen with a small bar underneath it with green going across. It should work.
Posted on Jan 18, 2012
Forgot my pattern on Chinese android tablet when i connect to my laptop cannot be recognized.Any one help to hard reset the tablet
see if there is a reset button where the sd card. usually it will say reset. if no reset button, you can try booting to recovery. it depends on the tablet so trial and error. press and hold up vol , home button and power at the same time and release power when you feel it vibrates. if you see android logo with exclamation point then your in recovery. if not try again. you can try " up vol + down vol + power button " or " down vol + home button + power button " when you get to recovery, just use up or down vol keys to navigate and pressing power button to select it. "wipe data/factory reset"
Apr 08, 2016 | Tablets & eReaders
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
How do I reset my Zeepad 7.0 tablet to factory settings?
1. Power of the device.
2. Now,Hold down both volume+ and power button simultaneously, you should get an android on its back opened.
3. Press both volume + or - to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
Aug 10, 2014 | ZeepadTM 7" Zeepad 7.0 Andoid 4.0...
Ematic 7" QUAD CORE TABLET EGQ307 FORGOT PASSWORD HOW TO RESET IT CANT GET ON ANYTHING WITHOUT IT
I have also take help from this helpline number 1-888-551-2881..
before sometime i have also same problem like you, i forgot my password of my Gmail account and that account contain important data,,I just call this number 1-888-551-2881..& get best solutions
related website: Gmail Password Recovery
Jan 08, 2014 | Ematic Eb104 eBook Reader
Unlock dot pattern lock android
Normal way for Android is to power down and then hold the power button and the volume Up button.
Way 2 is to hold power, vol up and vol down.
You have to hold until the recovery console appears, so about 20 seconds.
Only a few have a reset button inside a hole.
However, yours is different to all the rest :>)
Just completed this procedure and repeated to confirm: Klu by Curtis 7035-j
1. Make sure tablet is off.
2. Press and hold the "Volume Down" key and `Power` key
3. When "Klu by Curtis" splash screen shows release the power key 4. A laying down android with cover open and a red triangle with an exclamation point will appear.
5. Rock the `Volume Down` and `Volume Up` and press the `Power` keys to dislplay the BIOS screen.
6. Use the `Volume Up/Down` keys to navigate choices (wipe data/factory reset) and the `Power` key to select the choice.
7. The following screen will ask you to confirm your choice and warn you that this cannot be undone. Repeate step 6 to select your choice.
8. When wiping all data is complete, select `reboot system now` to restart tablet. Done!
Read more: How to perform a factory reset on a Curtis Klu LT7035-J tablet? - How to perform a factory reset on a curtis klu lt7035 j tablet :: Ask Me Fast at http://www.askmefast.com/How_to_perform_a_factory_reset_on_a_Curtis_Klu_LT7035J_tablet-qna6954204.html#q6015781
Curtis Klu 7 inch Touch Screen Google Search
Apr 23, 2017 | Curtis Klu 7-inch Touch Screen Mobile...
Mid7035 only booting to coby logo
Try this wipe option.
Hold up vol up then press power button in 6 secs. while holding vol up, release power until recovery mode appear.Press power button then vol up and you'll see wipe options.
Feb 28, 2013 | VG Silver Gray Hydei Edition Nylon...
How do i reset my kurio 7 tablet my daughter forgot the password
factory reset true Recovery mode
vol+/- homebutton last power key
realease home key and - vol when boot
in recovery mode select "FACTORY RESET" enter
"ERASE CACHE" enter
REBOOT DEVICE-
Done
Jan 08, 2013 | Techno Source Kurio Kids Tablet With...
Tablets & eReaders Logo
76 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
