Question about Maytag CWE4800A Electric Single Oven
How do i check my oven sensor - Maytag CWE4800A Electric Single Oven
On a whirlpool double oven what does F2 error mean and canit be fixed
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. If present, replace control board (clock). For SELF CLEAN models, check door lock operation. Check sensor, sensor harness, and the sensor harness connection at sensor and oven control. Also check for any causes of high resistance in the oven temperature sensor circuit. Remember: The oven control board (clock) measures resistance of sensor circuit, not actual oven temperature.
Nov 23, 2016 | Whirlpool Ovens
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Ge profile f2 error while broiling in upper oven
F2
During
BAKE Control senses oven
temperature above 615F-630F If actual over temperature condition occurred: Look for
welded relay contacts on bake or broil relays. If this happens, replace oven
control (also called clock or ERC).
If no over temperature condition
occurred
: Look for a high resistance connection or any other cause of high
resistance in the oven temperature sensor circuit. Check sensor, sensor harness
and sensor harness connection at sensor and oven control. Replace sensor if
found defective.
Remember: Oven control (ERC) measures resistance
of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above
915F-930F If actual over temperature condition
occurred
: Look for welded relay contacts. If this happens, replace oven
occurred
found defective. Check door lock switches.
(ERC) measures resistance of sensor circuit , not actual oven
temperature.
Jan 24, 2011 | GE Profile JTP56 Electric Double Oven
Error code F2
F2
During
occurred
found defective.
During
CLEAN Control senses oven temperature above 915F-930F
Look for welded relay contacts. If this happens, replace oven control (also
If no over temperature condition occurred:
Look for a high resistance connection or any other cause of high resistance in
the oven temperature sensor circuit. Check sensor, sensor harness and sensor
harness connection at sensor and oven control. Replace sensor if found
temperature.
Dec 30, 2010 | GE JTP15 Electric Single Oven
30 " Convection wall oven
F2 During BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2 During CLEAN C ontrol senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Nov 26, 2010 | GE 27" Built-In Double Electric Convection...
Shutting down with an F2 blinking at us
F2 During BAKE. Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2 During CLEAN . Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
Nov 25, 2010 | GE JTP45 Electric Double Oven
F2 error beeping make it stop
F2
During
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
Nov 22, 2010 | GE Profile JTP56 Electric Double Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
I am getting an F2 with beeping on the display of my double ovens. Any idea what this is?
Hello, here is what the error code F2 refers to for a GE oven: F2
During
During
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. If you have any other questions please feel free to comment. Mike
Nov 19, 2009 | GE Ovens
Older GE oven self clean mode beeping with F2???
HI, this will happen when the oven Control senses oven temperatures above 915F-930F
Jul 24, 2009 | GE Profile JTP56 Electric Double Oven
Maytag CWE4800A Electric Single Oven Logo
16 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
