Question about Hitachi C21 F800S TV
Only 1 channel has sound pin 18 has sound pin 15 no sound on ic tda 9859 please help
Has changed ic
    Problem Solver:
  • 11 Answers
Is that stereo sound? try adjusting the balance control in the remote control...
Posted on Jan 20, 2015
My tv don`t have sound,yesterday i change the ci TDA7056, BUT ONLY HAVE SOUND ONE HOUR THEN NO SOUND NO MORE
TDA 7056 Audio IC
3 W mono BTL audio output
amplifier
Many things to consider:
Supply voltage on pin 2 , nominal 11V
Speaker should have 16 ohms impedance
Insure that it is mounted properly on the heatsink
check the solder joints
check for additional components around it.
http://pdf1.alldatasheet.com/datasheet-pdf/view/19422/PHILIPS/TDA7056.html
Aug 27, 2012 | Samsung TXH1370 13" TV
Tip
Replace the kkz-12 power amp ic on kenwood car stereos
replace the kkz-12 ic[difficult to find expensive!]with the tda 7560!first desolder the kkz .have 27 pins.take the tda and cut the pins 1 and 25.replace the kkz with the tda now.let the pcb positions 1-2 and 26-27 pin empty.solder the ic put htc in the heat sink tight screws and check the unit!
on Mar 08, 2010 | Car Audio & Video
Description of all pins in ic TDA11105PS/N3/3/AE1
5 supply Volt missing in IC TDA 11105ps/N3 used in beston tv
May 13, 2011 | Televison & Video
Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Jul 01, 2009 | Philips 32PW6506 32" TV
Ic used in which section of philips TV kit
tv set no sound coming.i replce sound out put ic but not hasbeen coming .i think 9370/1665 ic in side a/f out put line is gone i have a this curcuit daigarm not avilable so pl help this point
Oct 10, 2008 | Televison & Video
TDA 8364
Look it up at nteinc.net
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
Hitachi C21 F800S TV Logo
65 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
