Question about Ariens Garden
How to remove the auger gearcase on ariens 924121 snow blower
  • 509 Answers
SOURCE: Only one blade turns automatically on Ariens snow blower.
There is a bolt that goes through the center of the shaft that shears off if you hit something. You will need to line up the holes of the internal shaft with the auger tube and install a new bolt.
Posted on Feb 11, 2010
SOURCE: unable to remove hub 02438900
I also had this problem. I actually pulled the ears off of the hub using 2 different pullers. I ended up heating the hub and hiting the shaft through the hub with a small sledge. It took 45 minutes. Then I tried to remove the impeller from the shaft. Not a chance! Both pins out but it would not budge. This is a customers machine and it needed a gearbox. I'm going to end up putting an impeller on it as I can't get it off the old shaft.
Posted on Dec 07, 2010
  • 1509 Answers
SOURCE: I have an issue with
Spray all the insides of the chutes and blowere area with a sislacone spray. this will keep the snow from clogging and make sure the engine is running fast so it clears good there is clutches that keep it from breaking the pins and the moe often you slip them the easier they slip. After awhile it'll get bad enough that you'll need to change the clutches.
Posted on Dec 19, 2010
ToolBoxHero
  • 171 Answers
SOURCE: I have an Ariens 926LE
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Posted on Jan 10, 2011
Testimonial: "Have not tried the trouble shooting steps yet. I does make sense to me and will try them when I get home. Hope it works. Getting a lot of snow."
  • 483 Answers
SOURCE: ariens st350 snow blower wont blow snow, augers wont spin
there is a bolt that goes thru auger and spinning shaft (look for a hole where it once was) holds the augers to the spinning shafts, it is called a shear pin, it is a safety feature, and made of softer metal, so if you pick up something too hard with the auger, it wont lock up the engine, or break engine crank shaft.find an ariens repair shop to purchase the shear pin so you get the right softness of metal.
Posted on Mar 05, 2013
Snowblower....auger takes time to get going...like five minutes...it will struggle to start spinning then eventually warms up and is fine....whats the issue?
It is most likely your auger drive belts. There are two of them, and they need to be replaced periodically. Your manual should describe in detail as to how to replace the belts. Always start by removing the spark plug wire.
Improper gearcase lubricant could also cause problems. Your manual should tell you specifically what to use in the gearcase, and how to fill it. Also look for grease fittings on the auger and use a low-temp grease to service those fittings.
Lastly; behind the auger is the impeller shaft. Reach in and see if it wiggles. If it does, then have your impeller bearing replaced.
Feb 13, 2015 | Craftsman Snow Blower / Snowblower Bottom...
How do you put it in neutral
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
May 13, 2014 | Rotary Snow Blower Parts Replaces Ariens...
932 ariens shuts engine down as clutch is engaged to throw snow
Your problem would be in a safety shutdown switch.
some Ariens blowers have a two handed safety switch whitch is located on back of blower right lower side (inside of body)
You have to remove 4 transmission pan bolts to see it.
The other location is under the metal face plate between the handle bars.
Some of them have a third handel on right side of handle bars that has to be depressed to run auger .
Mar 01, 2014 | Ariens Garden
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Ariens st350 snow blower wont blow snow, augers wont spin
Mar 05, 2013 | Garden
Feb 09, 2010 | Ariens 34 In. Zoom Series Riding Mower
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
18 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
