Question about Refrigerators
I have a KitchenAid Superba refrigerator, the freeze works well, but the refrigerator don't receive any cold air due to the evaporator fan it doesn't work it Just move 1/3 of revolution and when that happens the temperature control indicators blinks, but if I help the fan works Just one cycle, and then the same, some I replace the fan motor and the same happens , I have to help the fan to works but Just last one cyle, works perfect untill need to start again and Just try to start the fan but I have to help the fun at least 5 times and work but only one cycle, what is wrong?
fridgetech
  • 473 Answers
SOURCE: Fridge too cold
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Posted on Oct 10, 2007
SOURCE: Samsung side-by-side RS2545SH with several problems, possibly related
never buy a samsung appliance because you can not repair them. the company would like for you to buy a new one . my fridge the rs265labp freezes up in the fridge section and i have to take it apart once a month to defrost it. but i did find that if you keep a couple of boxes of baking soda in it and replace them often it helps to make the time between defrosting longer. hope this helps someone. i hope that samsung either goes out of business or straightens up
Posted on Jun 29, 2009
BIKER T
  • 909 Answers
SOURCE: Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
Posted on May 23, 2010
  • 906 Answers
SOURCE: Kenmore 596.72913200 refrigerator cold, freezer cold but not freezing
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
SOURCE: Evaporator fan new but not working on samsung rs267lash
Manny MANY unfortunate customers who bought this **** from Samsung have problem.
Specifically the Freezer cold but fridge side no lower than 55deg problem.
It is a known defect that Samsung has not taken ownership of. I have the same problem with the same model as many.. if you search the net. Iv'e been trying to find a designated website for repairs for this problem. Please post website with solution if anyone finds it. Thanks
Posted on Aug 28, 2010
My refrigerator isn't cooling well. The freezer isn't freezing at the top only the bottom.
if it's just cold at the bottom and warm up top it sounds like you have a bad evaporator fan motor in the freezer side,when you open the freezer door do you hear the fan blowing?if not bad fan motor,this happens when the fan motor is bad because heat rises and cold air sinks.part number : 2259385 and it's around 60 to 70 dollars
Nov 19, 2013 | KitchenAid Superba Architect KSCS25INSS...
We have a Kitchenaid superba side by side. The freezer is working fine, but the refrigerator isn't cold. I have vacuumed the coils at the top of the model, but didn't solve the problem. I can...
The cooling normally comes from the freezer side, through cooling tubes. There should be a fan either blowing or sucking the air through these cooling tubes. So the first thing you should do is verify that the evaporator fan is turning and then see if you feel air flow in both compartments. If you have air flow in the freezer but not the refrigerator side, then the cooling tube must be blocked.
Most of the time the blockage is ice or frost, and you will need to open up the inner back panel of the freezer to get to the cooling tube. Look for an opening under the evaporator. Suggest a hair dryer to defrost the tube.
Jul 15, 2011 | KitchenAid Refrigerators
We have water but not cold and no ice is being made
It sounds like the inside fan is not circulating cold air.
This could be either the evaporator coil has iced up or the fan motor has stopped operating.
Try defrosting the freezer, if things improve then the problem is in the defrost cycle. a technician can help you with that
Mar 31, 2011 | KitchenAid Superba KSRG25FK Side by Side...
My Kitchenaid refrigerator stop freezing. It still gets cold on both sides. But the freezer does not freeze anymore. I was told that it was the coils need cleaning, so I blew them ouy with my air...
It could be a freon leak, or the compressor is not staying on.  If you can hear a clicking sound coming from the back every couple of minutes, your compressor overload is kicking off.  More than likely you either have a freon leak, or a defective compressor. Check the warranty on your machine as many manufactures warranty the sealed system for much longer than the rest of the refrigerator.
Nov 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Refrigerator KSRB25FHSS04 is not
replace the fan first then you may want to defrost it to get any ice off the evaporator since the fan quit
Oct 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Apr 24, 2009 | Refrigerators
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer too cold frosty, and refrigerator section too warm
Sounds like a defrost problem if the evaporator is frozen over. If it's just Ice blocking air transfer on a top freezer model, then it's a blocked defrost drain.
Sep 10, 2017 | KitchenAid Superba Architect KSCS25INSS...
Fridge not getting cold enough
listen for the compressor running in the back at the bottom. when you hear that running, open the freezer section. do you hear a fan blowing inside the freezer? if not, the evaporator fan motor is jammed with ice build-up or it's bad. hope this helps.
Nov 01, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
