Question about Ovens
How do I change oven element in chef EOC614S - Ovens
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Shacklock chef manual
Usually (with oven unplugged) the burner will tilt up and is held in by a screw or 2 and has 2 wires attached (normally push on terminals). Have you read these with an ohmmeter to see if they are bad? The oven elements need the back cover removed and you will see the element connection and maybe a screw (if the screw isn't on the inside). It too should be checked for continuity before buying new ones.
Dec 06, 2013 | Ovens
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Brand : Chef Cordinate series - Coronet versatile\...
What is the name of the part that holds the element from the bottom of the oven
May 21, 2010 | Ovens
Oven not heating
If your oven is gas, like it says up top, then your ignitor is bad...
Check out this tip...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 07, 2010 | Magic Chef 9122 Gas Single Oven
No power to Magic Chef Electric oven
I'm not familiar with this oven, but it ought to have protection against this kind of exciting burn-out.
This could be a fuse: find it and replace it, or it could be a circuit breaker: look for a reset button.
As I said, I don't know this oven; this attempt to help is based on the general idea that it ought to have some built in protection.
Dec 11, 2009 | Magic Chef 9815 Electric Single Oven
I have a magic chef range/oven. For the last few months, it has taken longer and longer for the oven to heat up to temp. Now it won't get more than 90 degrees or so. What is the problem??
Turn off the power to the range. Remove the bake element from inside the oven. Be careful not to let the wires go back into the oven cavity. Take a volt/ohm meter set for ohms or continuity and test the bake element leads. If you get no reading replace the element. If you do get a reading,replace the temperature sensor in the oven.
Oct 08, 2009 | Magic Chef Ovens
Unable to find pilot light for m,ajic chef oven
its electronic ignighters is it plugged in and have you tried turning it to light new ones dont have piolets
Jul 13, 2008 | Magic Chef Ovens
Ovens Logo
46 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
