Question about Minolta X-700 35mm SLR Camera
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
I recently got a minolta x700, it appeared to be working, the shutter would fire and the film advance lever was working fine even without film or batteries, then when i was going through the functions, the lever stopped advancing and i couldnt release the shutter (it was loose). So i flipped it over and twisted the coin slot on the right side, it sounded like the shutter fired, but now the lever is stuck! And the coin slot wont budge. I have a project due, and i have no money to take it to a shop. What can I do?It happened when i was trying out batteries ( the right kind just low on power) and i was trying the different modes
  • Nick Rottkamp
    Nick Rottkamp Feb 03, 2016
    The same exact thing just happened to me. And I'm wondering if you eventually fixed the problem. and how?
    Champion:
  • 254 Answers
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
atdlee@netzero.com
Posted on Feb 26, 2014
3 Suggested Answers
SAFFOTO
  • 77 Answers
SOURCE: Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
Posted on Jun 15, 2009
  • 302 Answers
SOURCE: Film Advance levar wont work. Milnolta x-700
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
Posted on Oct 11, 2009
What happened when your were testing out batteries and changing the modes? Your question is unclear.
I look forward to hearing a followup question.
Thanks,
BAX
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
Advance film lever not working
If there's film in the camera it could have reached the end of the roll and you were unaware or it didn't indicate it. Try to rewind the film and use the rewind button on the bottom of the camera. Try pushing the button in anyway and advancing the wind lever. if this isn't the problem then the internal gear is jammed or broken and the camera needs service.
Jan 27, 2014 | Minolta X-700 35mm SLR Camera
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
Film advance stuck and metering problem on Minolta X700
Hi, i have the same problem, do you fix it?, can you give me the solution please?
Thanks, my mail is dg_alex_vargas@hotmail.com
Jan 27, 2010 | Minolta X-700 35mm SLR Camera
Aug 05, 2009 | Minolta X-370S 35mm SLR Camera
Film Advance won't work on Minolta X-700
changing the batteries have no effect on film transport, just a coincidence. take the bottom cover off and check the white plastic gear on the film take up side of the camera. if it is broken your X700 may not be repairable as no new parts are available.
push the re-wind button in and try to charge the shutter again. remove film first. if it still just goes part way then a gear is stripped. try to find a camera repair shop that may have good used parts available.
Jul 18, 2009 | Minolta Photography
Minolta X-9
Mar 22, 2009 | Minolta X-700 35mm SLR Camera
My daughter just got a used Minolta 700-X. We are trying to load the film, but the advance lever won't advance to load the film after we put it in. Can you help?
Are the batteries good ,is the battery cap and contacts clean? Can you fire the shutter? Move select off auto and try to release the shutter. If the shutter fired off auto and will not fire on auto with good batteries. Either the shutter or flex circuit must be replaced. There are no new parts avail. for the X700.
One other item for the X700. check to see if the shutter fully traveled on the last shot.
Dec 07, 2008 | Photography
35 mm, Minolta X700
Is the re-wind button stuck in? If so it can be released by moving the take-up sprocket manually. If that did not work there is a broken take up gear. This was a common problem with the X700, a white plastic gear was used at the bottom of the take up spool mechanism that just was not strong enough especially when trying to get just one more shot from the roll of film. No new parts are available.
Sep 20, 2008 | Photography
Film advance lever
No problem.
Most film cameras can do that, for quick advancement.
atdlee@netzero.com
Dec 21, 2007 | Minolta X-700 35mm SLR Camera
Minolta X-700 35mm SLR Camera Logo
543 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
