Question about Canon PC-795 Copier
Service manual how to clean the corona wire
Where do you find corona wires on Brother 7840W printer?
The wire is on the drum (where the toner cartridge fits in). The green or blue piece slide cleans the coroner wire.
Jul 23, 2014 | Brother MFC 7840W Printer
Photocopieur
C - 0100 Charge corona wire winding failure.
C - 0200 PC drum charge,Image transfer/paper separator coronas failure.
Clean the coronas wire and the coronas house using isoprophil alcohol and clean or change the contact combs(a little Cu pieces)
If you enter in service mode and select Counter mode you can reas the trouble code list description.
Apr 26, 2013 | Konica Minolta Minolta Ep4000/ep5000...
When we scan or copy, a long line comes up on the paper
You might need to clean the corona wire. Pull out the drum and cartridge and slide the blue tab on top back and forth. Be sure to return the tab to the home position afterward.
Mar 01, 2011 | Brother MFC-8460N All-In-One Printer
Dark copies, copier pc-6re needs cleaning, no manual
Clean the optical parts (mirrors,lens and lamps),charge corona wire and the transfer /separator corona wires and unir and make a copy.If not good tell me.
Nov 30, 2009 | Canon Office Equipment & Supplies
What is the code to manually clean the corona wire Konica 7165
47 mode output 046 p00p for charge 47 mode output 047 p00p for transfer
Apr 03, 2009 | Konica Minolta Office Equipment & Supplies
Royal copier service code
Royal copiers are kind of old... But I believe that a C710 means that a charge corona wire is arching out or it could be broken. The fix I use to do is to clean the Primary & the Transfer corona wires carefully and pree the reset botton and see what happen. It could be a problem wit the HVTDC, but you may fix it with just cleaning the corona wires.. Good Luck
Nov 07, 2008 | Office Equipment & Supplies
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Cleaning corona wire
there is no corona wire in this machine.
mongrelken.
Jun 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Canon PC-795 Copier Logo
59 people viewed this question
old marine
old marine
