Question about Air Tools & Compressors
I have a titan 640i paint sprayer and i am repacking the fluid section for the first time myself and can't seem to figure out how the piston rod comes apart? In the manual it shows it coming apart so
I think you may have to take that top little cap off some how, i;ve tried but can't seem to get it loose? thanks
  • brian parry Feb 16, 2014
    i got it finally..
  • 2,428 Answers
You likely have titan 440 i .I have a 1991 660 its the same packing kit as the 440 except one has flat valves and the other has balls flat valve is better if you use it a lot like I do but the instuuctions on how to repack the unit are simple .The most expensive part is the pistion 400.00 dollars . Its all nylon and neaprem O rings 60.00 bucks for the kit. The olny way to take it apart is from the bottom and the pistion slides out after the block that houses the packings is removed from the bottom of the unit . Read the repacking insturections again.By comparisition this is the easest pump I have ever had to rebuild and work the best a good little mechine
Posted on Mar 09, 2015
2 Suggested Answers
  • 98 Answers
SOURCE: need to repack pump on graco gm5000 gas paint sprayer
http://www.graco.com/
you can put your model in or if you have a part # you can enter it into one of the fields eventually you will fing a parts diagram for your unit.
Posted on Feb 21, 2010
I have a Titan 640i painter sprayer that is older . Made around 2002 . It will not run . The yellow light flashes but the motor doesn't start. The power source is fine. The pressure is turned up.
If the motor fails to start look for a button (often red) on the motor. This is a reset button for the thermal overload protection most electrical motors of significant horsepower are equipped. Make sure the power is off, push the button to reset, then power on the motor. If the motor still does not start check to see that the mator's shaft turns freely. If not, the mator's armature is frozen due to corrosion or melt down. If the armature turns but the motor still isn't starting, another possibility is that the motor's brushes are too worn or have cracked or fallen apart due to age and/heat. Motor brushes are fairly cheap and normally easy to replace. If you're not a handyman consider taking the motor to an electric motor repair shop to check for continuity and estimate for repair. Hope this helps!
Jun 13, 2016 | Titan 440 Impact Airless Paint Sprayer...
What would make a paint sprayer lose suction while beeing used
Wore out packings You have a little titan
Check to see if you have flat valves or balls flat valves are better but the packing kit is around 60.00 dollars also check the prime knob it also has seals .
The KEY is to always clean the mechine after use and oil the pistion with throught oil and it will last forever if you repack it every 2or 3 hundred gallons or so and use good tips
Mar 01, 2015 | Titan Advantage 100 Airless Paint Sprayer
Hi my titan 400 its leaking from the oil cap area, I reduced pressure and still leaking?!
Hi Kamil,
Your Titan Advantage 400 needs to have its piston seals replaced which is why it is leaking into the oil cup. They are self-adjusting static packings. This is a classic airless wear situation; paint is abrasive. Its easy to do it yourself and if you do, you need to examine the piston; if it is worn or scored it must also be replaced otherwise it will wear out the new packings fast. All the parts to repack it can be purchased in a kit.
Jan 13, 2015 | Titan Advantage 400 Airless Paint Sprayer...
How to repack the sprayer
The packings are static and self adjusting. The repack kit includes the piston so it replaces everything. Just buy the kit and follow the instructions. Try Scott at American Airless on 770 4771337.
Aug 25, 2014 | Titan Paint Sprayer. Advantage 200 Airless...
Does a titan airless paint sprayer require oil
Yes throught oil to be filled at the top of the pistion read on mechine ware
May 03, 2014 | Titan Paint Sprayer. Advantage 350 Airless...
Piston will not move up or down top gets hot
Bring it back to who ever rebuilt it
They left the piston pin off
or worst the gears are strip
Joe
Mar 15, 2014 | Speeflo Titan PowrTwin 12000 Plus Airless...
Piston seal
Hi Agustin,
Sorry that I have not replied before; only just seen your enquiry.
The problem is either the piston seals are worn, in which case paint is likely to come out into the oil cup, or you have a valve problem, either something is stuck in a valve or the valve could be damaged (the seat or ball) Call me at Lion Industries if you need to discuss 01543 251 560
Dec 16, 2013 | Titan 440 Impact Airless Paint Sprayer...
Titan 640i wont prime
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Dec 31, 2012 | Titan 440 Impact Airless Paint Sprayer...
Need to repack pump on graco gm5000 gas paint sprayer
Jun 02, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
222 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
