Question about Panasonic PT-AE300U Multimedia Projector
Pt-ae900u projector Vertical blue lines are being displayed by my projector, paired together.No idea what the cause could be. They're displayed when nothing is plugged in and when something is, on both the VGA and HDMI ports.
  • 17 Answers
SOURCE: Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Posted on Jul 17, 2008
SOURCE: Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Posted on Feb 08, 2009
Mr_Wizardtex
  • 205 Answers
SOURCE: PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Posted on Jul 07, 2009
electronios
  • 126 Answers
On the iris unit, mechanism stops moving and needs cleaning and greasing, but for best results must be replaced.
Posted on Feb 23, 2010
SOURCE: Panasonic PT-AE2000U All three HDMI Ports stoped
WOW. I just experienced the same thing. None of my HDMI ports are working, though component is fine. I've had my unit since November 2007 and had no problems until this. I think the HDMI board has gone bad and will require replacing.
Posted on Jun 21, 2010
My acer projector flickers after 10 minutes and very hot air comes out from its vents, making it difficult to stand near it and it also show vertical lines.
the projector flickers after 10 minutes ,it seems that the lamp ballast is failing
shows with vertical lines, it seems that the LCD panels are failing or the panels cable not be tightly plugged (panel-cable plugs into the mother board)
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 12, 2014 | Panasonic PT-AE900U Multimedia Projector
I own a panasonic pt-ae900e i have notice a thin uneven green transpairant line in the middle of the screen lamp time 1987 hrs
Experience:
There is three LCD (liquid crystal display) in your projector when one LCD faulty he display a line some time flickering line one or two lines. Due to other two LCD is working well so this line is looking transparent. If BLUE LCD faulty than the line color is very light green or yellow.
Second option is this that your projector lamp life is near to end and after 2000 hours projector is very dirty inside and need service.
(service of LCDs and other parts of projector is a very technical job and I don't know you can do it or not)
Jan 16, 2011 | Panasonic PT-AE900U Multimedia Projector
Red horizontal lines across the screen i have a pt-ae900u
Check out this solution for the same problem:
http://www.fixya.com/support/t305560-even_spaced_vertical_lines_across_whole
I was successful with this hint.
Jul 08, 2009 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U projecting black vertical lines on image
Hate to tell you this, but the PC board in the projector is gone. Had the same problem with my 3 year old AE900. Sent it to panasonic and the engineer told me i needed a new board. The PC board along with a new dynamic iris (which i already knew i neeeded) was going to cost £672 (inc labour). It wasn't worth fixing as you can buy a new 200 for about the same price.
If you still have your warranty - then your sorted. Have to say the Panasonic engineers who are based in Cardiff were very helpful when diagnosing and explaining the faults.
Dec 02, 2008 | Televison & Video
Bulb not coming on?
Hi - You can download the manual by clicking the link underlined in blue below:
PT-AE900U
Most likely the air filter needs cleaning. See page 55
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 13, 2008 | Panasonic PT-AE900U Multimedia Projector
Vertical lines
Hi burton29
This is a common Mainboard failure with all makes and models of Projectors.
Will unfortunately either have to be replaced or repaired by a certified technician.
Thanks for using Fixya
May 13, 2008 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U
Very confusing posting !
RGB input for DVD Player ?
HDMI input missing ?
Apr 13, 2008 | Panasonic PT-AE900U Multimedia Projector
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE300U Multimedia Projector Logo
15 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
