Question about Yamaha Winter Sports
Engine missing my 2006 vk professional 120 genuine runs at idol fine and will run at all speeds fine. Except, after a a few kilometers the sled will missfire when you slow back down from mid speed to an idol and will sometimes backfire but then run fine again at all speeds and the process will start again...Also, all electricity to the headlight, dashboard components, grip and thumb warmers, tail light/break light, reverse beeping, radiator fan has been lost. Please help. Sled has only 8xxx ,miles on engine and mostly groomed trail driven! Thank-you, Andrew
    Problem Solver:
  • 18 Answers
Take it to Dealer.
Posted on Oct 12, 2014
Headlights work fine. Why are all gauges/ electronic dash out?
Electrical issue - no headlights, tach, etc - HCS Snowmobile Forums
www.hardcoresledder.com > ... > REV Chassis
Feb 2, 2009 - 12 posts - ‎2 authors
There is no voltage at the harness with the relay at all. ... Previous Sled(s): 09 f1k SP,07 f8 SP,fusion 600@900 ... We havea 2006 600sdi and everything works but the headlights. ... relay is good, But this just happend to me sled starts and runs fine ... As soon as I rev it up the dash, tach, headlamp go out.Missing: 600headlights ‎electronic
06 fusion 600 bad volt regulater [Archive] - JohnDee.com ...
www.johndee.com > ... > Discussion Board > Tech Talk
John Dee
79 posts - ‎8 authors
I believe I have a bad voltage regulator going out on my sled. lights are diming and ...I'm under the impression that polaris has replace the old regulator with a new ... They are way down under the oil tank, brake, and all that stuff, up tight ... While riding, my sled had dim lights, no hand warmers, gauges would go in and out.Missing: 600headlights ‎electronic
Polaris Fusion 600 HO LED tail lights - YouTube
? 0:31
https://www.youtube.com/watch?v=oG2BWF4xVKg
Sep 28, 2011 - Uploaded by Trent Robinson
Most Fusion 600 HO owners at some point have issues with their ... This makes sense but the electrical system is AC on this sled AND people complain of the brake indicator on the dash stays onall of the time. ... Not sure on the indicator, mine works fine. ...2006 Polaris Fusion 900 that we are parting out.Missing: 600headlights ‎gauges ‎electronic
battery light blinking with full battery - TrackShare.com
www.trackshare.com/forum/showthread.php?t=32645
Jan 01, 2016 | Polaris 2006 Fusion 600 HO
My transmission slips a few kilometers run
your transmition may have bands slipping or sticking soliniods , need to get it serviced at auto trans shop .
Mar 28, 2014 | 1996 Mitsubishi Galant
2007 vk professional running hot,engine light on,codes 21,84 on
I have the book but I cant find the codes.
So find out if your rad fan is coming on. If it does then pull out your thermostat and place it in a pot of water and see at what temp it opens at. The open temp should be stamped on the thermostat.
If it is stuck closed or opening to slow, replace stat.
Mar 15, 2014 | Yamaha 2006 VK Professional
Sled gets to 155 deg and shuts down
Change the thermostat,is the water circulating?
Feb 23, 2014 | Polaris 2006 SwitchBack FST
Have a 1992 toyota corolla 3 speed auto, that shakes when stopped at a stop light, and when you take off it runs fine. changed plugs cap and rotor and still does it..
Check your engine idol. It could be that your idol speed is set to low. It should probably run at between 800 and 1000 RPM. If it is not then your idol is to low.
Jan 03, 2011 | 1992 Toyota Corolla
Cobalt not running at low rpm.......
All are possibilities but EGR valve makes the most sense. It's famous for causing poor idling and/or stalling at low RPMS. Best of luck.
Greg
Jun 18, 2009 | 2006 Chevrolet Cobalt
Check engine light on,idols rough,fine at all other speeds.
I decided to check the idol air control valve,when I removed it I found the problem right behind it. The P C V valve hose was just about into where it fastens to the intake,the other end was bad also. Cost me aout $6.00 Where auto parts stores were telling me parts would cost two or three hundred $$.
Jan 20, 2009 | 2001 Ford Escort ZX2
Winter Sports Logo
473 people viewed this question
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
bazzz7071
bazzz7071
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
