Question about Bosch SHE68P05UC 24 in Builtin Dishwasher
Dishes used to come out pretty dry, suddenly everything is very wet after cycle. I
Am using rinse aid and propping the door open a bit after cycle. The water is heating properly so that's not it. Any ideas?
  • Kim Hawley
    Kim Hawley Feb 15, 2014
    Cleaning out water intake valve did the trick! Thanks so much, fast and easy fix
You may want to check the water intake valve. Lots of times it will get clogged with gunk and not open or close properly so the dishwasher never rinses properly. If that is the case just clean it out and it should solve the problem. Also, the celluloid could be shot which is causing it to not work at all and then you need to replace the water intake valve completely. I hope this helps....
Posted on Feb 14, 2014
  • 641 Answers
SOURCE: Dishes and inside the washer are not drying
Make sure that the drain hose is connected as per manufacturer instructions, and that there isn't a direct run down from the sink u-bend to the machine. The rinse agent effects dishes dry but has nothing with the water remaining in the machine. Good luck!
Posted on Sep 15, 2007
  • 677 Answers
SOURCE: streaks and film on glasses
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Posted on Apr 10, 2008
  • 677 Answers
SOURCE: Bosch SHX46A dishwasher
  • 901 Answers
SOURCE: All of a sudden the dishwasher water is not hot
Check the heater. Heater control circuit.
Posted on May 28, 2010
d-wash
  • 40 Answers
SOURCE: cloudy dishes
new product designed for this problem. Free samples available!
CloudyDishes.com
Posted on Oct 09, 2013
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
When we take the dishes out they are all wet
Choose the hottest rinse cycle first Economy cycles don't work properly Make sure you have rinse aid in the dispenser. Make sure the machine is heating properly too. An aid do drying is to open the door of the dishwasher just when the cycle finishes steam should come out and the water in the cabinet will condense to the walls and dry the dishes. some top end models do this with a push rod..... believe it or not (Miele) go to my website for a detailed explanation about drying www.appliances.cjb.net you can contact me from there too for further follow up good luck
Mar 01, 2011 | Dishwashers
The dishes are still wet after "drying" overnight?
With the energy efficient dishwashers today it is very important to use rinse aid for proper drying. The rinse aid will help sheet the water off of the dishes prior to the dry cycle. If you do not use rinse aid you can expect poor dry performance.
Next to the detergent cup in the door is the rinse aid dispenser, be sure it is full. You only need to fill it about once a month. There is also a product called "Turbo Dry" that you can use in the rinse aid dispenser, it helps dry even plastics very well.
Next be sure you have selected heated dry on your options.
Sani Rinse will also help as it heats the water before the dry cycle.
Let me know if you have questions.
Aug 01, 2010 | Whirlpool DU1055XT 24 in Builtin...
Does not seem like the dishwasher is drying like it used to. After it has gone through its entire cycle the is steam condensation on all the dishes and the inner door. Previously, at the end of cycle...
Have you run out of Rinse Aid ?
This has a large effect on drying as well as how clean the dishes come out. Rinse aid [breaks up] the water dispersion, so at the end of the final rinse, the water just falls off the dishes, takes the sediment with it. So with the heat of the final rinse, & less water left on the dishes, they dry better.
Dec 12, 2009 | Kenmore Dishwashers
The dishes are pretty wet as is the inside of the dishwasher after a regular run. will a rinse agent fix this?
Rinse aid will help.The Bosch dishwasher uses the captured heat from the water to dry the dishes.turn on your dishwasher ,wait 20 mins and open door .Does steam come out?if yes rinse aid should do trick,if not water is not heating and you probably have a bad e.control (common problem)est repair cost in Boston area $229.. Hope this helps ,please rate my response :)
Dec 08, 2009 | Bosch Evolution 800 SHE68M05UC Stainless...
Door is wet with condensation at the end of the cycle although dishes are dry
this problem should be under dishwashers not washing machines! however this is caused by lack of rinse agent this aids the drying process and removes moisture from crockery check levels if ok try using detergents with salt and rinse aid combined may be dispenser is not working properly.
Sep 26, 2009 | Bosch Classixx WFL 2066 Front Load Washer
When the wash cycle is done, the dishes are wet
It seems that the newer dishwashers are worse at drying dishes than their tupperware melting predecessors were. They have all been tuned down, and do dry less. The only thing that you can do is to set your machine for the hottest wash, power dry and use a rinse agent that provides a sheeting action. Some folks use white vinegar as a supplement to their rinse aid, which has the added bonus of killing mold. Water also stays attached if the water has laid down minerals as noted by cloudy glassware. If this is the case, a dishwasher filter (dishwasherfilter.com, $70) might help. We try to wash hot, with a power dry and use a rinse aid/vinegar. Then, when the cycle is complete, but the dishes are still hot, we open the dishwasher, and "jiggle" the racks to get the excess water off of the glasses, and leave the dishwasher open about 2" at the top, so the dishes will continue to air dry. This has been an effective method for us.
Best regards, --W/D--
Aug 03, 2009 | Siemens Dishwashers
Wet dishes; steam does not escape
Hi, Most dishwashers do not have steam vents! there are several reasons for poor drying in a d/washer! The first one is to see that you have rinse aid in the machine as this aids drying! Next if you have rinse aid then is it being put into the machine when it needs it? Also you must bear in mind that the dishwasher need to heat on the last rinse to create the heat to dry the items which use the steam to dry them. Check the rinse aid first and see how you get on....
Let me know.......
Aug 01, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Doesnt dry dishes
The heater on this unit only comes on twice, once in the wash cycle, and again in the Sanitary rinse. During the drying cycle all that happens is a vent opens and a fan comes on. The fan removes the hot moist air from the unit and the dishes dry off. If your water is not hot enough, this is why your dishes are still wet. Rinse aid also helps to sheen off the excess water as well.
Sgt 48
May 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
Model LD1403W1
Are you using a rinse aid like Jet Dry??  All dishwasher manufacturers now require that you use rinse aid for drying dishes at the end of the cycle.
Dec 29, 2007 | LG 24 in. LD-12BW5 Free-standing...
Bosch SHE68P05UC 24 in Builtin Dishwasher Logo
89 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
