Question about Cuisinart CMW-100 Microwave Oven
Nothing working Control panel works but that is it . The turn table doesn't turn and no sound from oven. I checked the fuze and is good
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
Microwave oven doesn't work but light turns on
It sounds as though you have a defective electronic control pad.
May 03, 2012 | Frigidaire Microwave Ovens
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
Can,t turn the over the stove lighting on
Replace the bulb. If that doesn't work, the "Membrane switch" under the plastic film control panel is damaged. There is no good way to fix them. Contact hotpoint to see if they still have replacement panels available for this model. If not, either live without the light or replace the whole microwave.
Sep 24, 2011 | Hotpoint RVM1625 Microwave Oven
Galanz Microwave Model WP1000AL30 doesn't go on when the item buttons are pushed?
Does microvave button makes sound and when you start push button does the turn table moves.If yes for sound ,and no for turn table then you might have door switch which is either doesent latching or might broke.
open oven (be sure to discharge capacitors).
check its closing properly(the switch)
and use DMM to check resistance that it doesn't show OL
thanks
please rate my work
Sep 20, 2011 | Microwave Ovens
I have a Gold Star Model MV-1500MG over the range model microwave oven. Everything works except it will not heat and the turn table does not turn. While it is running everything sounds normal but does...
Hello, does the control panel light up? If it doesn't then probably the fuse has shorted. Now, if the front control panel does light up. There a number of thing going on. Door closer switch is working.
The mega-tron tube is shot or something is going on the micropressor. Now, if the mega-tron is shot. Buy a new micro wave oven and allways to recycle used appliances. GB...stewbison
Aug 22, 2011 | Goldstar MV-1526 Microwave Oven
Turntable not turning--new computer installed at 300.00 -was turning when repairman left-not working again today--
Check your owners manual as some turntables can be turned off by a switch on the control panel. If not, the turn table connections may have come loose from the control board or the motor could have died..
Jun 20, 2010 | Thermador MBBS Microwave Oven
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
Microwave Oven model #JVm1850wd002 turn table does not operate or
Take off the case. You'll see two prongs on the door. If they are out of adjustment.And don't trip the contacts. nothing will work. Theres nothing mech on the turntable, the micowaves make it turn. Just make sure it turns freely,and is clean.
Dec 29, 2008 | GE Microwave Ovens
Cuisinart CMW-100 Microwave Oven Logo
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
noel
noel
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
