Question about Cuisinart CMW-100 Microwave Oven
The control panel works but that is it turn table does not turn and no sound from oven
Kitchenaid microwave turn table doesn't work I replaced motor still doesn't work
Is it set to be off via the control panel?
You can download Kitchenaid / Whirlpool owner's manuals, installation manuals, and parts lists here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag here.
Jan 19, 2014 | KitchenAid Microwave Ovens
Turn table wont turn
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 05, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE spacemaker XL1800. the model number is JVM 1842 BD. The turn table has stopped turning. There is a turn table control and that is turned on. how do I go about repairing it? also, wher
The full model number from the tag on the unit would be JVM1842BD001 or JVM1842BD002 without the spaces.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 07, 2013 | Microwave Ovens
The microwave was dropped off a table and the control panel section popped off. it was tested and worked. it was moved to another trailer and now it won't work. the panel is tapped in place, the door...
It sounds like the door is out of alignment with the cabinet. The latch assembly may also be damaged. Do not operate until these issues have been addressed. A door that doesn't line up properly can allow microwave energy to leak past the door.
Jan 04, 2018 | Salton RRMW1 / RRMW1A 900 Watts Microwave...
Turntable not turning--new computer installed at 300.00 -was turning when repairman left-not working again today--
Check your owners manual as some turntables can be turned off by a switch on the control panel. If not, the turn table connections may have come loose from the control board or the motor could have died..
Jun 20, 2010 | Thermador MBBS Microwave Oven
Turn table does not turn The GE Microwave oven woprks very well however the turn table does not turn any more. It is supposed to rptate as it cooks.
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
May 23, 2010 | GE Spacemaker JVM1540 Microwave Oven
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Mar 20, 2009 | GE JVM1631 Microwave Oven
G.E. Profile Microwave Model JVM2070SH01 turn table does not turn.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 02, 2008 | GE JEM25 Microwave Oven
GE Microwave
sounds like either a powerboard or control board is sending erratic voltage or no voltage to the table motor and possibly the light.
May 29, 2008 | Microwave Ovens
Cuisinart CMW-100 Microwave Oven Logo
49 people viewed this question
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
deton8 von Splosion
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
