When you push the on/off button it flashes really quick but does not start
    Genius:
  • 1,552 Answers
Something is "fried" -- purchase a replacement.
Posted on Jul 29, 2014
Can you use radio in montero sport 2016 with push button start, while car is off?
YES, if you read the manual it will tell you how to turn on the accessories using the push button. Usually you press the start button 2 times really quick and it wont start, it goes to accessory mode. Be advised that the dash warning will come on and say that you are draining the battery.
Oct 29, 2016 | Cars & Trucks
Lanark spa bath
Not really sure but it sounds like there is a sensor that may not be reading properly preventing the pump to turn on.
Rod @ US Parts Center
May 12, 2013 | Pool & Spa
I am trying to start a cyle and everytime i push the cycle button it does not light up and the quick rinse button comes on and flashes nothing works at all if i push heavy wash it comes on and nothing...
You haven't told me how many times the light flashes, but I will take a guess that this is an error code associated with the water entering the machine being too cool. I believe the machine expects the water to enter at 110 degrees F (43 Degrees C).
To clear the error, press "Heated Dry" then release, then press "Normal Wash" then release and repeat this sequence until all the lights on the machine go solid green. Once this happens, hit ""Cancel" and the machine will reset.
The fix for the root of the problem is to increase the temperature of the incoming water in future (Turn up your water heater temperature a little)
Jul 05, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Adjust the time clock on the 2005 xt660x please
G'Day Dutchgbg
Here is a quick guide to set the clock
1: Push the "select" button and the "reset" button together for at least two secounds.
2: When the hour digits start flashing, push the "reset" button to set the hours
3:Push the "select" button to fix the hours, and the minute digits will start flashing.
4: Push the "reset" button to set the minutes
5: Push the "select" button to fix the minutes, and then release it to start the clock.
regards robotek
Apr 09, 2010 | 2005 Yamaha XT 660 X
Don't have owners manual. I how do I setup the
garage door opener that may be different. But, I believe there are 2 ways to do it. Try pushing the button on the back of your garage door opener by the LED. The light will begin flashing for 30 seconds. During this time, it is accepting new signals. So you have to quickly get in your car and push and hold the button you want to work your door. If the opener accepts the signal, it will flash its floodlight. Then just push the homelink button again to see if it raises/lowers the door.
The second way I don't remember quite so well, but I believe you hold the corresponding button on the homelink until THAT starts flashing, then point your remote at it and push that button. The homelink will flash 3 times quickly if it accepts it. I don't think I've ever gotten this method to work, which is why I'm unsure of the procedure.
I've had new and used cars with and without manuals and the first procedure has always worked. It may take a couple of tries, though
Oct 22, 2009 | 2000 Chevrolet Impala
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
I FROM MEXICO, I DONT HAVE THE MANUAL TO USE MY HDM776DQ-95. PLEASE HELP TO FIND THIS MANUAL. THANK YOU.
I don't have manual either but really pretty simple. I went to www.Healthometer web site and they do not have this model but several others that are similar. To set time push select button and when flashing use the arrow for correct time then push select. Same for year, month and day. When flashing after pushing select, just arrow up or down for year, push select, then month will flash, then day using same procedure. Then hold down 1st button on scale to start height flashing and arrow up or down for that.
Judithrolan@bellsouth.net
May 05, 2009 | Dryers
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
My Canon Pixma MP170 printer is showing error code 5800, What must i do to fix this?.
MP170 (5b00) Ink Tank Full Error Reset
1,power off.
2,hold stop/reset ,hold ON/OFF
2,release stop/reset, push stop/reset twice, quickly, then release ON/OFF
3,wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
4,then push power twice, quickly
5,power off and power on.
Jul 15, 2008 | Office Equipment & Supplies
Flashing quick rinse light on panel
I had the same problem but I found someone wh said that there is a way to reset the dishwasher. I tried it and it has worked so far.
Here is what I did.
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Oct 24, 2007 | Kenmore 15769 Built-in Dishwasher
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
