En21645e remote The button labels have all faded and are not visible
    Guru:
  • 135 Answers
Either buy new labels with adhesive
or print them with label printer (ask a firend to help you)
or just buy a new remote ( or a substitute one)
Posted on Apr 17, 2014
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
The source won't clear on the screen and stays visible while watching
On the remote you should have a button labeled display. Hope this helps.
May 25, 2011 | Televison & Video
I have a small elemet tv with a en21645e remote control. My grandson did something to the remote and now I only get the local channels not cable channels although I have cable hookup
The little tyke has most likely pressed the INPUT button on the remote control and switched the TV away from the external input setting required for watching cable TV.
You did not state the model number of the TV and some TVs function differently with regard to the selection of external inputs, but you should be able to return to watching cable by pressing the INPUT button slowly but repeatedly until you can see the picture from the cable channels again. The INPUT button is located in the top right corner of your Element remote.
If an input selection menu appears on screen when you first press the menu button, use the arrow keys to highlight another input, then press ENTER to select it. I can't tell you which will be the correct input as I don't know the model number of the TV and it depends on which type of cable you are using to connect the TV to the cable box. You should try each input in turn until you are able to see the cable channels again. Please make sure the cable box is switched on when doing this!
If you are still having difficulty, please reply to me from within this page with the model number of the TV and the type of cable you are using to connect the cable box to the TV. I will then be able to provide exact instructions for switching your TV back to the cable input.
Hope this helps.
Regards,
BElectric
Jan 28, 2011 | Element Televison & Video
Net command is stuck on the screen. The highlight jumps from one device to the next non-stop. I've unplugged and reset but nothing will get the net command off the screen neither with the controls on the...
YOU HAVE DEFECTIVE FRONT TACTILE BUTTONS. IF YOU PULL THE FRONT SPEAKER GRILL OFF YOU CAN UNPLUG CONNECTOR LABELED ZF AND IT WILL REMOVE THE BUTTONS FROM THE CIRCUIT. THEN YOU WILL BE ABLE TO USE REMOTE AND TV SHOULD FUNCTION PROPERLY. IF THE CONNECTOR ZF ISNT VISIBLE IT WILL BE BEHIND THE SMALL PANEL IN BETWEEN THE SPEAKERS. IT WILL BE A WHITE CONNECTOR WITH ABOUT 6 WIRES OR SO.
Dec 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
TLP 2844-Z is faded on the right half when it prints
It probably needs a print head adjustment or calibration.
Here is a link for the user guide,(it takes a minute to load and display) you will find cleaning and diagnosing tips :
http://www.systemsprintmedia.co.uk/downloads/ZEBRA%20TLP%202844Z%20MANUAL.pdf
If your zebra label printer is not feeding to the next label correctly it may need to be calibrated. Follow these steps to calibrate the printer:
  1. Turn off printer and have media loaded (on older Transports, with no ON/OFF switch, remove battery).
  2. Hold feed button down, and turn printer back on (on older Transports, re-insert battery) while holding down the feed button.
  3. When the light starts flashing, release the feed button.
  4. Printer light will turn green and advance a few blanks.
  5. After printer stops advancing and prints the internal information, press the feed button one time.
  6. You will get another label with the “Out of Dump” message on it.
  7. Printer is now ready for use.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 21, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Ink is fading on my qx50
Dymo Labellers don't use ink, they are thermal printers. When the print fades it usually means the batteries are running out.
Jan 24, 2009 | Dymo LetraTag QX50 Thermal Label Printer
LIGHT BUTTON BROKEN
I had the same problem with two remotes. Replacements are either hard to find or very expensive, so with nothing to lose I opened it up. There's a circuit board inside, and the rubber buttons are all connected together in one grid or mat. Each button has a corresponding copper square on the circuit board. I immediately saw that the square for the light dimmer button had a dark smudge, presumably from the rubber button.
The smudge was easily cleaned with a q-tip and denatured alcohol. Put it back together, and the button works!
Note, there are two screws that hold the remote housing together, but just one was visible on my unit. The other is below the sticker (with the FCC info). I was able to access the screw by simply pressing the screwdriver through the sticker.
Jul 07, 2008 | Minka (RC588TW) Remote Control
Video Label
There's a "Display" button on your remote.  Push it.
Mar 29, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Printing fade at the midle of the page
Build up on the printhead, printhead pressure, or worn platen roller...
Apr 26, 2007 | Zebra Stripe S600 Thermal Label Printer
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
