Question about Matsunichi 500GB USB 3.0 USB 2.0 Compatible External Slim Hard Drive White
Hard is not working but light is working
Windows xp dont view that
  • etrc_new Apr 10, 2014
    Hi Lucie Blais Dupont, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? In what way doesn't Windows see the hard disk drive ? Does a little square symbol appear at the bottom right of your screen in the coloured bar there when you connect it up ?
How to install winxp to laptop dell inspiron 910. dell inspiron 910 no hdd but 8gb flash drive
A clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base:
313348 (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup program To perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
Post back if it is not working we will be happy to help you.
Thank you.
Cheers!!!
Jan 09, 2011 | Dell Inspiron Mini 10 Notebook
Netbook hard drive problem
Please login to the Computer with the Windows Operating System. Now, open the Disk Management window. Click on Start and select Run. In the Run command box, type Diskmgnt.msc and press Enter.
In the Disk Management window, you can view the 66 GB allocated space for Ubuntu. Right click on 66 GB space and select format. Now, you will get free space for Windows only.
Jun 30, 2010 | Acer eMachines eM2501162 Netbook
How to create bootable cd?
The following items are required:
  • A copy of the original Windows CD/DVD or ISO.
  • A copy of the Boot Files (Downloaded Below).
  • A minimum of 1GB available hard disk space for CD's.
    A minimum of 5GB available hard disk space for DVD's.
Create a folder called OS on your hard drive (C: is used in this example).
In this folder create two sub-folder called BOOT, and ROOT.
Copy the entire Windows 2000/XP/2003 CD (or extract the ISO) into folder ROOT.
1.) Download boot file. (bootfiles-from-tacktech-website.zip ~1.34KB)
2.) Extract the BootSector file (boot.ima) from bootfiles-from-tacktech-website.zip
into the folder C:\OS\BOOT
Start Nero Burning ROM.
Select File > New... from the menu.
1.) Select CD-ROM (Boot).
2.) Select Image file from Source of boot image data.
3.) Check Enable expert settings (for advanced users only!).
4.) Set Kind of emulation: to No Emulation.
5.) Set Load segment of sectors (hex!): to 0000.
6.) Set Number of loaded sectors: to 4.
7.) Set Platform identifier: to Intel x86 compatible.
8.) Press the Browse... button.
Locate the BootSector file (boot.ima) in the folder C:\OS\BOOT.
Click the Open button.
Click on the ISO tab.
- Set File name length to Max. of 31 chars (ISO Level 2).
- Set Format to Mode 1.
- Set Character Set to ISO 9660 (standard ISO CD-ROM).
- Check the Joliet check box.
- Check all Relax ISO Restrictions.
- Check Allow more than 64 characters for Joliet names.
Click on the Label tab.
Remove the check from Also use the ISO 9660 text for Joliet.
Enter the Volume Label into the ISO 9660 and Joliet text boxes.
Click the More fields button.
- View Windows 2000 CD Labels (TTID# 269)
- View Windows XP SP0 CD Labels (TTID#226)
- View Windows XP SP1 CD Labels (TTID#283)
- View Windows XP SP1a CD Labels (TTID#312)
- View Windows XP SP2 CD Labels (TTID#342)
- View Windows XP SP3 CD Labels (TTID#422)
- View Windows 2003 Server RTM CD Labels (TTID#292)
- View Windows 2003 Server SP1 CD Labels (TTID#355)
- View Windows 2003 Server R2 Disc Labels (TTID#387)
Enter in the Volume Label into the System Identifier, Volume Set, Publisher,
Data preparer, Application
text boxes under ISO 9660 and Joliet.
Click the OK button.
Click the Burn tab.
- Check Write.
- Check Finalize CD (No further writing possible!).
- Set Write Method to Disc-at-once. (We have had Track-At-Once work as well.)
- Click the New button.
- Locate the folder C:\OS\ROOT.
- Select everything in the folder and drag it to the ISO compilation panel.
Note: Some files are not show in the following image.
- Click the Write CD Dialog button.
Click the Boot tab.
- Verify the settings. Correct if needed.
- Click the Burn button.
Wait for Disc creation to finish.
Click the Done button.
Process completed. You're done.
Regards
Pcs365.8
Jun 01, 2010 | Microsoft Windows XP Home Edition
Blue light flashed on the portable hard drive for a couple seconds.How do I know if all files were transfered? Nothing on screen showed up? I have a HP laptop.
If your portable hard drive was set up as the "H" drive, go to My Computer (in Windows XP), or Computer (in VISTA), select your "H" drive and view your files (if there).
Jun 10, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
HP Pavilion ze5500 - Laptop won't recognize hard drive.
Hi. Once I had this similar problem with a HP Pavilion dv9000. "No Operating System"; "Windows Recovery Console cannot continue because there's no HD present..press F3 to Exit". No progress with Safe Mode nor Command Prompt, etc.
Then I went to the Bios, change tab to "System Configuration" and change the "Sata Native Support" to disable, whitch says that by changing to disable the HD would work better if the Operating System are Win2000 and Win9x.
Hit "Safe and Exit" and the computer started normaly!
I relly don't know how or why. It just work.
I don't know if would work for Linux (mine had Windows XP) and don't know the Bios view of your laptop. But you can explore and give it a try.
Hope this helps.
God Bless You!
Jan 06, 2009 | Computers & Internet
Xp pro not all of my gbs
it could be multiple problems :
first your system doesnt has the software to display more gb,normally there is a software that comes with the hard drive to install it, if you dont have it, you can google the website of hard disk company for it
eg seagate maxtor have their s/w which is free downloadable
secondly your system needs to be configured to display the new drive, go to systems tool administrative tools computer management tool options and u can view the hard drive and format it or create new partitions to display it
let me know if this works
second
Jan 04, 2009 | Microsoft Windows XP Professional
Lost everything on my laptop as soon as i open it
I dont think you lost everything. Do you see any green power lights and do you hear the normal hard drive and fan sounds when booting up ? If you do and still wont boot up to Windows then reboot and keep tapping on F8 to safe mode and select "last known good configuration". You can also perform system restore.
If you dont hear anything at all, no power and you dont see any green power lights then you may have to plug into another known good power outlet. check that your power connections (including the power adaptor) are secured and if on a strip power off and on. If that doesnt work, try another power adaptor. If those doesnt work
remove the laptop battery and just plug in the adapter.
If youre concern about your personal files you can always take out the hard drive, piggyback it to another hard drive on a known good PC and retrieve the files.
Jan 04, 2009 | Microsoft Windows Vista Ultimate Edition
Makes repeated beeps, doesn't seem to work
There is a high possibility that the Hard Drive has Crashed. The beeping sound is an indication. You can try to connect it to another computer just to check if the other systems can still detect the Hard Drive. You can try to connect it to a Windows XP system and a Windows Vista System just to check the difference. If other system still can't detect it, you may be looking at Hard Drive Failure.
**Note : If you can see the Hard Drive under My Computer, you can check Disk Management to be sure (Disk Management gives you the list and the info on all storage devices on the system, formatted or unformatted.). If you can't see the Hard Drive inside Disk Management, You should call Simple tech Support for replacement if Hard Drive is still under warranty.
How to access Disk Management :
1.
Click Start, click Run, type compmgmt.msc, and then click OK.
2.
In the console tree, click Disk Management. The Disk Management window appears. Your disks and volumes appear in a graphical view and list view. To customize how you view your disks and volumes in the upper and lower panes of the window, point to Top or Bottom on the View menu, and then click the view that you want to use.
**Note : There is no Software that can recover files from a crashed Hard Drive, In that first place, shich ever software that is, it will not be able to detect the Hard Drive anyway. There is one company that is credible to retrieve data from crashed Hard Drives (If your pictures / Files are that valuble to you).
Check out this link or call 800 440-1904 :
(Company is Drive Savers - Expert in retreiving data of Hard drives ) :
http://www.drivesavers.com/solutions/raid-nas-san.html?gclid=CLD3hdfX15YCFSIgDQodrWMu3g
Nov 02, 2008 | Computers & Internet
Viewing my photos
Probably the problem is with your PC.The operating system XP can detect a camera automatically and operates with your camera.If u dont have XP u have to install the camera using the cd comes with the camera.
Mar 23, 2008 | Photography
Hard drive not being recognized
dear ramroot
enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
trying to connect your ext. Harddisk again
oke
cropp
Mar 17, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Matsunichi 500GB USB 3.0 USB 2.0 Compatible External Slim Hard Drive White Logo
21 people viewed this question
Top Matsunichi Computers & Internet Experts
Roger Currier
Roger Currier
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Matsunichi Computer and Internet Expert? Answer questions, earn points and help others
