Question about Whirlpool WMH1162XVS Microwave Oven
Why my goldstar microwave looks like dead?
It looks like dead
How do i change the light in my MS-133SE GOLDSTAR MICROWAVE
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Feb 16, 2011 | Goldstar MV-1501 Microwave Oven
Well, i got this microwave from a friend when i moved to my own appartment, and i kinda need the manual for it. as it's really hard to understand.
Call Goldstar at this number and see if they can get your manual for you.
Tel: (800) 243-0000
Fax: (256) 772-8987
I will look again if they can not help you.
Now mind you Goldstar is actually LG. The LG Group was a merger of two Korean companies, Lucky and GoldStar, from which the abbreviation of LG was derived. You may end up having to contact LG for a manual.
Thanks for choosing FixYa,
Kelly
Nov 11, 2010 | Goldstar MV-1501 Microwave Oven
Goldstar Microwave - Digital display is dark & does not operate
I would suspect the oven cavity thermostat is open.
We have a similar model's service / repair manual and have uploaded it to our site here for free download to help you with disassembly & troubleshooting.
To order Goldstar / L.G. parts, visit Encompass. Since l.G. / Goldstar does not list part numbers in their manuals, you'll probably have to call Encompass toll-free at at 866-779-5835.
Jan 28, 2010 | Goldstar MV-1526 Microwave Oven
TOTALLY DEAD
CHECK THE FUSE ON CONTROLL BOARD, CHECK THE CONTINUITY OF THE LOW VOLTAGE TRANSFORMER.
May 02, 2009 | Microwave Ovens
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Need glass plate for 24 year old Goldstar microwave model ER4010
The original part number was 2B70335A then it was 30QBP004, but these are no longer available.
Jan 14, 2009 | Microwave Ovens
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
Goldstar MV1502W
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter lead sagainst the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 20, 2008 | Goldstar MV-1526 Microwave Oven
Help-
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor (and fuse).
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer (and fuse).
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
For parts, you can contact LG at 1-800-243-0000 or http://us.lge.com/support/support.jsp
If that doesn't work, please feel free to contact me directly via http://tinyurl.com/yzjozk and I'll help you find a replacement part.
Mar 05, 2008 | Goldstar MA-780M Microwave Oven
Goldstar MA-1164M Microwave oven connected to 220 volts
We see this a lot. The problem is on the control panel assembly, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Jan 26, 2008 | Goldstar MA-1164M Microwave Oven
Whirlpool WMH1162XVS Microwave Oven Logo
23 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
