Question about Intermec CN50 Handheld Mobile Computer CN50ANU1EN20 Barcode Scanner
Backlight not working - Intermec CN50 Handheld Mobile Computer CN50ANU1EN20 Barcode Scanner
How do you fix a Samsung 55" Television with no picture but good sound?
The symptoms you described would indicate the backlights are not working.
The 2 main reasons are the backlight inverter board has gone or the backlights have blown!
Since you have replaced the inverter board with a new working one then this would point towards the LED backlights.
Apr 02, 2016 | Samsung Televison & Video
LED TV - replaced power board but still no backlight? LED backlights do not seem to work.
yes the led backlight for whatever reason is not functioning and that is the root cause of your problem. Unfortunately to find a replacement led backlight is tough as the backlight is normally fixed with the lcd panel and has to match the voltage and all that stuff with motherboard. and if that doesn't match you might short the tv itself. this case is as good as getting a replacement lcd panel.
Feb 17, 2016 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
My keyboard backlight no working is a dell studio 1735
cielimar61,
To turn on the backlight on the keyboard follow the steps below. The keyboard backlight LED can be accessed through either the Quickset Utility or Windows Mobility Center depending on the installed application.Once this is open click on the Keyboard Backlighting section. Make sure the keyboard light is turned on.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 26, 2013 | Dell Studio Computers & Internet
Sony cyber shot dsc-t10 backlight not working
Yes, the backlight is a separate part. It can be removed from the LCD and replaced.
The following video shows how to replace the backlight in a Sony camera.
http://www.desmontalo.com/?p=275
Apr 01, 2012 | Sony Cyber-shot DSC-T10 Digital Camera
Iphone screen backlight not working. What to do?
If the backlight on your Iphone is dead, you need to replace it. This does usually happen if it received a sharp drop or exposed to liquid.
Check out the following link for your repair options
Repair Backlight on Iphone 3g
Jan 09, 2010 | Apple iPhone Smartphone
Screen back light is one important thing in the phone, and will be of great use during power break downs or shortages. It was about a month ago that I noticed my back light not working properly, and I think this might had happened probably because of exposure to some sort of liquid or dust. I thought it would be good to show it in a reputed showroom, as it is good to repair and handle costly things from good places only. That is how I finally ended up repairing my phone from the clinica iphone service centre.
Dec 02, 2009 | Apple iPhone Smartphone
W2242T's backlight not working...
You can buy backlight fluorescent bulbs on eBay.
Jul 04, 2009 | LG W2242TQ-BF 22 inch Monitor
Backlight is off
You either have a bad LCD or bad backlight board. The backlight on your screen is no different than a light bulb. If it burn out it stops working, if these is no power to the backlight your screen will have an image but no backlight to see the image.
Jul 03, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Intermec CN50 Handheld Mobile Computer CN50ANU1EN20 Barcode Scanner Logo
98 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
