Question about Vehicle Parts & Accessories
Does any one know how to remove the extended cab chevy 2010 rear door panel
The rear door handle has some form of a s type bar through it which I can't seem to remove I have to remove the door panel to get some bad dents out that some one kicked in
    Master:
  • 499 Answers
Remove the screw from the bottom of the handle then twist the handle off . next remove the small square cover that was behind the handle . there will be a screw , which you need to remove . remove any other screws in the panel and it should pop off .
Posted on Feb 14, 2014
How do I replace inside door handle passenger side on a 2011 GMC Terrain?
Search Results
    How To Install Replace Inside Door Handle Chevy Equinox ...
    ? 9:02
    https://www.youtube.com/watch?v=cY6asyM2R6g
    Feb 2, 2012 - Uploaded by 1A Auto Parts
    How To Install Replace Inside Door Handle Chevy Equinox 05-09 1AAuto.com .... found your tutorial on fixing my driver's side door handle for my 2006 Equinox. .... Door Handles Chevy Equinox 2010 2011 2012 GMC Terrain ...
    How To Install Replace Inside Door Handle 2007-13 ...
    ? 9:05
    https://www.youtube.com/watch?v=QonKLwhk2CE
    Apr 2, 2015 - Uploaded by 1A Auto Parts
    http://www.1aauto.com/interior-door-handle-driver-side-front/i/1adhi00417 1A Auto shows you how to repair, install, fix,change or replace a broken or snappe... ... 10, 11, 12, 13 Chevy Silverado, Tahoe, Suburban and GMC Sierra, Yukon Denali ...2007-2011 Tahoe Yukon Suburban Escalade Vent Section ...Missing: terrain
    How To Install Remove Rear Outside Door Handle 2007-13 ...
    ? 10:02
    https://www.youtube.com/watch?v=7ZUTqqEzpZg
Feb 08, 2016 | GMC Cars & Trucks
I have a 1993 Chevy s10 extended cab Chevy an my
The lock is likely rusted and you will have to remove the inside door panel to get to it and spray it with PB Blaster and hope for the best. Work the outside handle and see if it opens up. Good luck.
Oct 13, 2014 | Cars & Trucks
Rear passanger door on ford f-150 extended cab is stuck and won't open. what to do?
THE BAR THAT PULLS THE LATCH OPEN HAS PROBABLY CAME OFF INSIDE THE DOOR. HAVE TO REMOVE PANEL FROM DOOR AND REPAIR ROD
Jul 14, 2012 | Ford F-150 Cars & Trucks
1999 Dodge Ram 2500 changing front-to-rear hydraulic brake line
It will be a lot easier to do with the bed removed. It will also save time. So unfortunately yes that is true.
Jan 29, 2010 | 1999 Dodge Ram
I need to replace the rear door handle on a 2004 F-150 extended cab . I don't know how to remove the door panels.
there are clips holding on around the perimeter,and a couple screws around the handle after the power switch assembly is opened up with a flat blade.there is a screw inside there on most fords
Sep 01, 2009 | 2004 Ford F150
Westin nerf bars
Send them back and get the extended cab bars. if you have doors behind the passenger and driver seat it is the extended cab. If you don't want to do that, if you know a welder, they can weld them on for you.
May 23, 2009 | 2008 Ford F-150
Rear door won't open
You can get the panel off with the door closed. I just took mine off because of the same problem. The top portion is only connected with some clips inside the panel. Take the screws out of the rear side window first. The panel will pop off if you gently pry with a flatbar. under the panel are three screws. Remove the screws and lift up on the bottom panel. It comes right off. Find the cable that goes to the top latch and pull it. It should release and you can replace the door latch assembly. Mine were both broken and I am in the process of fixing them.
Mar 21, 2009 | 2001 Ford F150 Styleside SuperCrew
2001 GMC Sonoma Extended Cab door handle broken
You should replace the handle with an aluminum version. The best one I have found is sold on eBay for 12 dollars.
Look for the one sold by
mike8756.
It is easy to install, does not require removing any panels. Th first one I replaced took me about 1/2 hour. I hae done several since for friends and now takes about 15 minutes.
Installation instructions are here:
http://www.thirddoorhandle.com/installation/index.html
Good luck.
Tom
Jan 27, 2009 | 2001 GMC Sonoma Extended Cab
Broken inside door handle-1996 Chevy Silverado Extended Cab
On almost all GM's there will be a screw in the recess that the handle sits in. After removing this screw, gently wiggle this cup out of it's hole and there should be a metal rod attached to the back of it with a small clip. Unclip this and it's out - installation is the reverse. Just don't lose the clip or let the linkage rod fall down inside or you will have to remove the door panel. It shouldn't take five minutes to replace and most parts stores now carry GM door handle assemblies. Good Luck!
Jan 11, 2009 | 1999 Chevrolet Silverado 1500
Chevy S10 extended cab third door latch broken. Is this something I can replace myself? I've removed the two hex-star screws, but am afraid to pry off housing and causing further damage. Handle is...
This is a very easy fix, I ordered a new metal one off of ebay came with instructions and was very easy to do.
Search CHEVY S-10 THIRD 3RD DOOR HANDLE 1996-2005 GMC SONOMA
on ebay, the sellers name is s.gifenigma326 very easy to work with cost 15 bucks, shipped on time.
Jan 06, 2009 | 2000 Chevrolet S-10
Vehicle Parts & Accessories Logo
102 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
