Question about Citizen Watches Citizen Eco-Drive Black Nighthawk Mens Watch - CA0295-58E
I recently purchased the men's Citizens Eco Drive Nighthawk ca0295-58e (black). Upon receipt of the watch, I set the date and time. Since originally setting the watch on the 7th of this month, the dat
Purchased from eBay
  • Meagan Jenkins
    Meagan Jenkins Feb 14, 2014
    The post above was cut short. Please see full post below...
  • Meagan Jenkins
    Add a CommentI recently purchased the men's Citizens Eco Drive Nighthawk ca0295-58e (black). Upon receipt of the watch, I set the date and time. Since originally setting the watch on the 7th of this month, the date has only moved to the 9th (placing the watch 5 days behind). The second hand is not ticking. The chronograph ticks in 2-second intervals. The minute and hour hands have moved. I read that sometimes if the watch's battery has an insufficient or depleted charge, that it may require up to 150 hours of charging to restore. Would this be the cause of the second hand not rotating/ticking?
Just purchased the men's Citizen's Eco Drive Nighthawk (Black) ca0295-58e and the second hand on the watch is not ticking. I previously set the date and the hour and minute hands have moved, but not much....
Put the watch in any form of light for some time. Sun is best but not necessary. When the second hand stops running, it is a sign that the capacitor is low. The eco drive is a solar powered watch. When exposed to light, it converts the energy from the light and stores it in an internal capacitor which is really a battery that will last about 20 years.
Nov 09, 2017 | Citizen Watches CITIZEN Mens CA0295-58E...
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
I have a men's Citizen Eco-Drive WR 200. Why does my digital time accuracy differ by 2 mins from the analog setting? Thank you, Wayne
The analogue time can be set to agree with the digital time by following their instruction manual.
If you go to http://www.citizenwatch.com/COA/English/settings.asp and follow the instructions, you can download the ones for your watch.
Sep 28, 2010 | Citizen Eco Drive Chronograph Perpetual...
HOW DO I SET MY CITIZENS ECO DRIVE WATCH I PURCHASED A LIMITED EDITION CITIZENS ECO DRIVE WATCH 0240-2500
You can get a set of instructions from their web site "citizen.com", select "technical support" and the "setting instructions" and then enter the details off the back of your watch.
You will then be able to download instructions.
Jan 30, 2010 | Watches
Date setting.
Go to the "www.citizenwatch.com" site, select you area.
l
Select "technical support"
Then "setting instruction"
Enter your model number.
Dec 30, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
I have a citizen eco drive skyhawk im having trouble seting the time. can you help me.
Go to Citizens web site and find your model. You can down load the instruction manual there.
Jan 18, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watch wont work
Hi please read your instructions, if you do not have any, go to citizen web site, where you can download free of charge the instructions
Nov 24, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Watches Citizen Eco-Drive Black Nighthawk Mens Watch - CA0295-58E Logo
Top Citizen Watches Watches Experts
alwaysreddy
Bill Boyd
Are you a Citizen Watches Watch Expert? Answer questions, earn points and help others
