Question about Bose 3 2 1 GSX System
System Display shows bose3-2-1 - Bose 3 2 1 GSX System
  • 30 Answers
I assume your display shows Bose 321 and refuses all commands?
Your problem is not very well described. Often when something like this happens you may be able to "reset" the system by removing the AC cord from the power and after a count of 10 putting it back in. Normally the display will start with showing the Bose 123 text on the display and will subsequently go dark. After that you can switch the unit on and it should work. If it does not, call Bose, sometimes just updating the software solves this type of problem. Ask for an update disk. Normally they send that free of charge to your registered home address.
Posted on Mar 06, 2014
How can i unlock screen on motorola droid bionic because i forgot passcode?
This might help
Droid Bionic Stuck on too many unlock attempts Verizon Wireless Community
  • Power the device off.
    • Press and hold the Power button then select Power off
    • If the device isn't responding Remove / replace the battery
  • Press and hold Volume down and Volume Up, the press Power
  • Display shows Available boot modes
    1. Normal powerup
    2. Recovery
    3. AP Fastboot
    4. BP SBF Flash
    5. BP Only
    6. AP BP USB Bypass
    7. BP Tools
  • Use volume down to scroll to "Recovery", press Volume up to select
  • Once display shows Android triage screen, press Volume up & Down at the same time
  • Display shows Android Recovery
  • Options are:
    1. Reboot System now
    2. Apply Update from SDCard
    3. Wipe data / Factory Reset
    4. Wipe Cache partition
  • Use volume down to scroll to Wipe Data/factory Reset, press power to select
  • Display shows Confirm Wipe of all user data - This can not be undone
  • Use volume down to scroll down to YES - Delete All data - Press Power to Select
  • Device will perform format wipe
  • Display then shows Android System Recovery
  • Ensure reboot system now is selected then press the Power button to select
Oct 16, 2015 | Motorola Cell Phones
Not playing NTSC DVDs
I can see if there is an unlock code for your device
Apr 21, 2008 | Yamaha DVR-S150 DVD Player
Lines ring to a certain group and I need to change a phone from group 73 to group 72 - how can I do this?
From Ext 10 or 11>
Dial feature 00>
Hit the left intercom button twice>
The display will show "System Programming"
To remove the Ext. from group 73
Dial #502>
The display will show 'Group"
Dial 3 for group 73
The display will show "Extension"
Dial the Ext # of the phone that needs to changed
Dial 2 to un-assign the Ext from Group 73
To add the Ext. to group 72
Dial #502>
Dial 2 for group 72
Dial 1 to assign the Ext to Group 72
Dial Feature 00 to exit System Programming and save the changes
Be sure to ask me if you need more information
Mar 16, 2011 | AT&T Lucent MLS-12D Phone
My system is not showing display but monitor,cpu all are working but it is not showing display
hi pavantheloca
I think the display settings in your computer system prevents the monitor displays.
try to press f8 when you start the computer and then choose to enable vga mode
regards
Jan 17, 2011 | Intel D946GZIS Motherboard
Changing the alarm code on the gaurdtec 500 series alarm
For a guardtec 593
Programming User Codes
(Master code only)
system.
1) With the display showing ' Un ' enter a Master code
2) The display will show ' SE '
3) Press NO five times, the display will show ' Uc ' (flashing).
4) Press YES, the display will show ' U- '
5) Enter the User number you wish to program (1 to 7) followed by YES
6) The display will show ' Co ' Enter the required code (4, 5 or 6 digits) followed
by YES. (Entering 000000 will delete an existing code).
7) The display will show ' t- ' enter the code type from the following list
1 = Set Only 2 = Main User 3 = User 4 = Master followed
by YES. A full description of code types is given on page 3.
8) The display will show ' Uc ' (flashing)
If you wish to program other User codes return to step 4
Or
To return to the Unset condition press 0
this is for the led version.
Aug 27, 2010 | House Brand Intrud Alert House Home Alarm...
When I press my power button 3 or 4 time (on off) or some time more then display show in monitor. when I press 1st time then the pc start but no display show in monitor. when I off it and then again on it...
CHANGE CMOS BATTERY OF YOUR SYSTEM IT COSTS 10 RUPEES ONLY. ERRORS WILL GONE AFTER CHANGING THIS BATTERY. SYS WILL START IN SECONDS AND F2 ERROR WILL DISAPPEAR
Mar 29, 2010 | ASUS P4PE2-X Motherboard
Rerecord the outgoing announcement
Hi, Press feature 9 8 3, display shows: Log: QUIT RETRY OK, enter system coordinator mailbox and password ( default is 102 0000 ), press OK, display shows: Admin MBOX AA OTHR, Press AA, display shows: Auto Atdt Admin GRTG TABLE LINES, Press GRTG, display shows: Greeting Admin GRTG AA, press GRTG, DISPLAY SHOWS: Greeting: RETRY OK, enter greeting number ( 1 to 20, usually 1 is the Main Greeting ), press OK, display shows: Greeting < X >, RETRY PLAY REC, press REC, at the sound of the tone record your greeting, press OK to end recording, display shows: Accept greeting? RETRY PLAY OK, press OK when you are satisfied. Good Luck
Aug 16, 2008 | NorStar M7324 Telephone
Reset clockdue to power outage.
hi, this worked for me
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will show hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
this has to be done fro the main phone system
hope it helps
Jul 09, 2008 | NorStar M7310 Corded Phone
NORSTAR m7310
To Log Into System Programming:
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
Press: NEXT Display will read: "B. General Admin"
Press: SHOW Display will read: "1. Sys speed dial"
Press: NEXT Display will read: "2. Names"
Press the SHOW Display will read: "Set names"
Press: SHOW Display will read: "Show set:__"
Enter the extension number of which you wish to change the name Display will read: "<##:name>"
Press the CHANGE softkey
Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
Press: NEXT (if you fail to do this step, the name will not be saved!!!)
Press the RLS key
Hope this helps!
Jun 17, 2008 | NorStar Meridian M7310 Phone
Change the time
Depending on the software of the Norstar it is connected to, you would log in to the key system by using Feature **23646 and then follow it up with the administration password.
If this is a pre 1.0 system, i.e DR5.1 do the following. If not, go to the bottom and click on the link and find the manual for the system your phone is connected to. Generally the system coordinator guide will have what you are looking for.
Setting the date
Begin with the display showing
l.Sys speed dial
1. Press [NEXT] (second key from the top on right for a 7310) twice.
2. The display shows 3.Time and date.
3. Press [SHOW] (first key on the top on the right for a 7310)
The display shows the time, for example, Time 01:00.
- All times and dates must be entered using numerals. For
example, February would be entered as “2”.
- The time may be entered in either 12 or 24-hour format. If the
display is in English, and the hour entered is less than
thirteen, the display prompts you to specify “am” or “pm”.
Press [Show] This will open the time change function. Simple rule. If you want to modify a value, press [CHANGE] and you'll get a cursor. Once you're done with that entry, press [NEXT] to go to the Minutes, press [CHANGE] etc...
I have also included how to change the date below.
Press [Next].
The display shows the date, for example, Date 31 Mar 91.
4. Press CHANGE (softkey under screen). The display shows Year: 88.
5. Set the year.
a. Press CHANGE.
A cursor replaces the number on the display.
b. Enter the year using the dial pad.
For example, press a a to enter the year 1990. ?
c . Press [Next] The display shows the month, for example Month: 01.
6. Set the month.
a. Press [CHANGE]
b. Enter the month using the dial pad.
For example, press 02 to enter February.
c . Press [Next].
The display shows the day, for example Dar: 01.
7. Set the date.
a. Press CHANGE
: A cursor replaces the number on the display.
b.” Enter the date using the dial pad.
For example, press 14.
Apr 03, 2008 | NorStar M7324 Telephone
Bose 3 2 1 GSX System Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
