Question about Grandstream GXP-1405
Is it possible to use two headsets for training
We just got this phone system and need to be able to hook up two headsets for training . the headsets that came with the phones didnt work so we got news ones that dont have a spliter Thanks
Plantronics Voyager 500a bluetooth system. was using the lifter, but don't want to anymore, just want to be able to switch phone to headset mode and use the bluetooth. When I hook it up and hit the...
The beeps mean it needs to be repaired or resubscribed.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
If you are using a Cisco phone you could probably plug the headset base into the phone. If it is not you will still need your lifter.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I connected my S11 plantronics headset to my Cisco 7900 at work and can hear, but callers can't hear me
Most Cisco phones have a headset port where you can connect a headset using a special direct connect cable. This allows you to use your headset without touching the handset (receiver). However, when using an amplifier and headset combination, like the S11, you will need to connect through the HANDSET port. You disconnect the handset cable from the phone, connect the S11 cable into that port and connect the handset cable into the back of the S11 amplifier. Be sure to follow the illustrations on the back of the amplifier when connecting the cables. Also, adjust the configuration slide on the left of the amplifier for the best possible dial tone. Remember that in order to access a call or make a call, you will have to lift the handset off the phone and set it aside (switch hook needs to be activated).
Good Luck from Headsets Direct!
Jun 03, 2011 | Plantronics S11 Headset
How do I remove a Plantronics headset and set the phone back up to ordinary headset?
I am presuming that you mean how do you remove the plantronics headset and start using the handset, firstly unplug the headset and put the handset back in to the underneath of the phone- if you are unsure check one of the other phones on your phone system. at the telephone with the handset in its cradle dial TRANSFER 110, using the volume key scroll down until you read 'HEADSET USE: ON' , press the 3rd small button under the screen, your cursor will now be under the word 'ON' , press the volume key and it will say'OFF' now press your TRANSFER key. At www.abbeytelecom.com you will find over 60 training videos relating to the Samsung Prostar phone-system. I have loaded one for you as a sample for future reference
Jan 25, 2011 | Samsung Prostar DCS-24B-LCD Corded Phone
I have metro pcs phone how do i hook up blue tth
I have metro phone made by ZTE I need a code for pairing up the MotorolaH 350 with my ZTE phone what is it?
Feb 15, 2010 | Jabra COMMUNICATIONS BT160 Bluetooth...
Do you know how to program a headset key on a Toshiba DKT phone ? I have added a headset via a Huee card but need a button to go off/on hook using the headset. System is DK56 Thanks
Your headset is incompatible then. Palntronics H51 is used normally and has a seperate box that has on and off and volume and mute. Also DIP switched must be set properly on the box.
Oct 29, 2009 | Toshiba DKT 3010 Corded Phone
Problem using headset - why the handset has to be off hook
Be sure the headset you have is compatible with the Merlin Magix and a 4424 L4D+ phone. You will need to program both the headset status and headset hangup buttons. Headset status will negate the need for lifting the handset. and the hangup button is used to disconnect the call.
Apr 09, 2009 | Avaya Merlin Magix 4424D+ Telephone
NEC DTerm80 phone
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Jun 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Hooking my headset up to my playstation 3..
go to your phone's bluetooth menu and then find the headsets profile in the my devices menu and then delete that profile
Jun 03, 2008 | Plantronics Explorer 320 Wireless Headset
Connect/Program Headset
Sure you can do it. as long as the headset has a plug for the handset your fine. Plug it in and you will have to pick up and hang up the handset as needed. The headset key eliminates you having to pick up and hang up the handset to answer with the headset.
Feb 21, 2008 | NEC DTU 8-1 Corded Phone
Grandstream GXP-1405 Logo
21 people viewed this question
Top Grandstream Lands Phones Experts
ray gallant
spy1309
james laughton
james laughton
Are you a Grandstream Lands Phone Expert? Answer questions, earn points and help others
