Question about Ovens
Replaced oven thermostat still overheating - Ovens
2 Suggested Answers
  • 174 Answers
SOURCE: OVEN OVERHEATING
thermostats are not the sane. make sure cooling fan is working as this is more likely to cause the oven to cut out
Posted on Jul 23, 2010
Oven overheating
Your thermostat is STUCK. Replace. Your 'tripping mains' is your clue that your power is over loaded. Have an electrician check your boxes to make sure all is ok AFTER fixing stove.
Mar 03, 2014 | Electrolux EOC6690X Pyrolytic Electric...
Temperature lights stays on an oven is overheating
From the symptons described, I would say that the thermostat is faulty that controls the oven temperature, normal procedure is replace the faulty thermostat.
Nov 30, 2010 | Baumatic B904SS Stainless Steel Electric...
OVEN OVERHEATING
Jul 23, 2010 | Electrolux EOD6390X Electric Double Oven
Oven overheating ,even on very low degrees. Its a Teka
In most cases of ovens overheating, it is usually due to the oven thermostat being faulty.
The usual solution is to replace the thermostat.
Mar 10, 2010 | Ovens
Oven thermostat not cutting out
If the temperarure cannot be controlled, then I am afraid the only solution is to replace the main oven thermostat.
Hope this nhelps.
Dec 20, 2009 | Hotpoint Ovens
Oven is overheating by 110 degrees
used the info on the website to troubleshoot the issue. Determined it was the thermostat. Replaced it. Seems to work fine. Could not have done this without the illustrations showing where to find the thermostat and oven sensor. Great help.
Dec 10, 2009 | Kenmore Ovens
The oven turns off after 30 mins
Is the clock re-setting and flashing? Either the fan is failing and the oven is overheating, or the thermostat is faulty and the oven THINKS it is overheating. It is a fail-safe kicking in, momentarily cutting power to the oven to avoid lasting damage.
Set the time on the clock and the oven should be okay to go again, but if problem repeats, replace the fan and/or the thermostat - it is difficult even for an engineer with all his equipment to diagnose which of the two is at fault, but its about all there is to go wrong on a gas oven.
Apparently!
Jul 01, 2009 | Whirlpool RBD305PD Electric Double Oven
Electric fan oven overheating
It sounds like the thermostat is faulty, make sure the sensor is not detached inside the oven compartment, as this will affect the thermostatI if it is. If o/k, then the only option is to replace the thermostat. If it is fan assisted, then make sure the fan is working o/k as well.
Please leave a rating for my comments.
Thganks.
Mar 01, 2009 | Equipex PZ-330 Electric Single Oven
Neff U1422 oven overheating
Hi
Yes it does sound like faulty thermostat.
You will have to remove the oven from the oven housing, and remove the top cover, and possibly the front console.
Then you will have trace the sensor back to the main oven, and unfasten sensor in oven
You will probably have to remove the rear
panel as well to get the thermostat sensor out.
One other possibility is the sensor may have become detached inside the oven, this will then affect the oven temp.
Good luck
Hope this will prove helpful.
Nov 22, 2008 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
11 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
