Question about HP LaserJet 3800n Printer
HP m401 printer - HP LaserJet 3800n Printer
2 Suggested Answers
BaronVonNuke
  • 1915 Answers
SOURCE: I have hp lj m401 error 78.How to fix this since always showing in the panel of the printer http://www.fixsumo.com/
78 does not show in the manuals as a valid error. The link you attach is for error 79. 79 is a critical error usually related to memory failures. Disconnect the printer from the computer and power off and on. If it comes to ready it might be corrupt print job. If it still has a 79 error then you may have a bad memory chip but if you have no added memory it will be the memory built in to the formatter that is bad and that would mean replacing the formatter.
Posted on Dec 10, 2014
HP LasrJet Pro Printer will not except correct password to router.
who set the password on the Satellite router? login into the router find out what password is. check the printer to make sure they the same. also are ip addresses the same?
Apr 02, 2018 | HP Computers & Internet
My hp m401 will not acknowledge my router's password
My hp m401 will not acknowledge my router's password.
my guess is you mean, you are using wifi
and wifi fails right?>
you use the passphrase and its no good.
and its the router blocking you NOT the PC.
The PC asks to connect and the router allows or disAllows.
2 things need to be be correct,
I will assume you are at home.
1: the home router broadcasts a SSID. (name)
you connect to your SSID not your neighbors.
2: then your PC must be using the same encryption mode.
wep or wpa or wpa2. only you our your ISP set this up.
only you know what that is. (or ISP does)
3: then the passprhase is last. and must match.
if you bought your router only you know that and set it up
if your ISP put that router there, ask them.
if all this is too hard use 1 Ethernet cable from PC to rounter
10x more easy /and more ROBUST.
Hp laser jet pro 400 m401 printer 59.A0 error
SOURCE:HP color laser jet printer is displaying error
Developing disengaging motor error. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow
above steps if problem not resolved then call hp engr for 4th step.
I Hope It Works.
Sep 15, 2017 | HP Office Equipment & Supplies
did you read the HP page, on your M401 page.
and read the trouble shooting guide there,
all error codes are there, to read 24./7.
or ask here and they will point to the page. for you.
https://h30434.www3.hp.com/
Jun 19, 2017 | HP Office Equipment & Supplies
HP laserjet pro m401 dne does not print
you replace toner cartridge 80 a then ask questions
Feb 20, 2017 | HP LaserJet Pro 400 M401DN Laser Printer
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
How do I fix the error code 52 on my HP printer?
The correct solution is to replace the scanner with the correct M401 model not one from an older HP. The scan speeds could be different, the motors could be different which would make the formatter think that the motor was turning too slow.
Jun 11, 2015 | HP LaserJet Pro 400 M401DN Laser Printer
Dec 09, 2014 | HP Office Equipment & Supplies
How to update the map
Connect it to your PC using the software provided in the box
Nov 12, 2013 | Mio Moov M401 GPS Receiver
Please send me a user and software manual for mio m401 gps system thanks
hi,
In case you're still looking for one: http://eu.mio.com/media/specifications/pdf/Moov_M300_M400_English_Manual_WEU.pdf
Oct 20, 2010 | Mio Moov M401 GPS Receiver
HP LaserJet 3800n Printer Logo
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
