Question about KitchenAid Food Processors
Is there a 110 volt Sunbeam piemaker - KitchenAid Food Processors
Sunbeam SFP 809 operating instructions
similar instruction can be found at https://www.sunbeam.com.au/Root/Specifications/InstructionBooklet/LC6250_ib_1.pdf ...i hope it help
Apr 13, 2014 | Sunbeam Food Processors
Parts sunbeam 14021
Found several Sunbeam parts on eBay.
Dec 26, 2013 | Sunbeam Food Processors
The motor popped when I first used it. I had a US version (110 volts) and plugged it into Australian plug with adapter at 240 volts. Any ideas?
All the adapter did was enable you to put 240VAC straight into your 110/120VAC coffee maker. You needed a step down transformer to drop the voltage from 240 to 120 VAC. This is not what you wanted to hear but you have damaged your coffee maker substantially by using the wrong voltage. Also the US version is designed for 60 HZ power vs AU 50 Hz power unless stated otherwise on the input power data plate.
Damage that has probably taken place:
1. Motor PN 8211837
2. Relay and Switch assembly PN: 8212011. .
3. Capacitor PN 8211608
Cost to repair... will be close to total replacement value due to shipping costs & customs of replacement parts
Thanks for choosing FixYa,
Kelly
May 13, 2011 | KitchenAid KFP750 Food Processor
Will not seal .. have you a local repairer in Coffs Harbour area
Contact Sunbeam, you may need to replace the lid. I have given you the link below.
http://www.sunbeam.com/Splash.aspx
Nov 23, 2009 | Sunbeam Food Processors
I need a new blade for a Sunbeam, Oskar Jr, Chopper Plus.
Hi, new blade for sunbeam can be found on amazon, click here and take a look: Amazon com Sunbeam blade. I hope this was helpful. Cheers
Oct 17, 2009 | Sunbeam 4817 Oskar Food Processor
Looking for information on the Sunbeam Home Vacuum Seal Packaging System Model V5500 & a Recommended Retail Price $. Tried to find info on the Sunbeam Web Page but to no avail. Maybe I should buy another...
If you're in Australia the model number is VS5500. You'll find product information here http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1572 with RRP AU$250
There's also a newer model which I own, the VS6600 http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1603 with RRP AU$250. I find this one has better features e.g. lets you just seal by itself, useful when closing the end of an open roll to make a packet.
For owners manuals go to http://www.sunbeam.com.au/Pages/Support/ManualSearch.aspx and use either of the model numbers above as a search reference.
Mar 25, 2009 | Sunbeam Food Processors
Sunbeam oskar mixer
Look at this link...
http://www.householdappliance.com/food_processor_parts.html
It might help you.
Jul 10, 2008 | Sunbeam 4817 Oskar Food Processor
Food Processors Logo
20 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Shehu Pro
Shehu Pro
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
