Question about Samsung UN40D6000 TV
Dual image with lines on samsung un40d6000
Tv was working fine one second and I turned my back to see that it was displaying 2 images offset from each other with lines running through them.
  • 163 Answers
SOURCE: Scrambled Image at random intervals
it sound to me like a power supply problem, but in this tv most be a ribbon cable one, any way you need a tech, regular people cant do nothing in this case....good luck
Posted on Aug 11, 2006
Coldcut
  • 1554 Answers
SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Posted on Mar 08, 2008
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
roety
  • 585 Answers
SOURCE: Samsung LNS4041DX/XAA White horizontal lines
Hi my name is Roety,
I can help you with your issue ,
If the lines are present on every input you most likely have a bad screen. We usually replace the mainboard first because its cheaper .
Check part prices at encompass.com login as a guest
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Dec 01, 2009
  • 73 Answers
SOURCE: Picture on Samsung LCD LNT5271F is blurred
Try reseating the LVDS cable.It runs from the main signal board to the T-con board at the top of the panel.
I have a double image on my Model Samsung UN40D6000 tv S/NSNZ2ZFCEB502294V.
Good morning
Try Menu and find picture there, adjust contrast, brightness,and sharpness. I would start there.
kolbrub
Sep 28, 2015 | Samsung Televison & Video
Samsung TV Displaying Dual Images. It appears as 2 of the same images offset from each other. There are also some lines in the images. Talked to samsung and they wanted to send a tech but I simply can't...
Overlapping video signals are generally adjustments made when turning various pots on the rear circuit board. You may need the service manual to follow the directions on how to reset and stabilize the picture. If you cannot be your own technician; you have no choice or other options.
Feb 26, 2014 | Televison & Video
TV has recently began displaying 2 images slightly offset from each other with lines. I absolutely love this tv plz help!
you have a digital problem..ive narrowed it down to 2 boards..the Main Bd..and the Tcon board..here are the purchasing details
http://www.shopjimmy.com/samsung-bn95-00496b-t-con-board.htm
http://www.shopjimmy.com/samsung-bn94-05038b-main-board-for-un40d6000sfxza.htm
looks like the main board is on backorder..id replace that first..its most suspect..lemme know how it goes
Feb 14, 2014 | Samsung Un40d6000sf 40" 1080p Hd Led Lcd...
Monitor image became offset to the right. How to fix this?
Have you tried telling the computer that you want a single display and not dual?
Dec 19, 2013 | ASUS VW192S Monitor
My samsung CLP-670ND is printing 4 separate images (one of each colour) offset by approximately 2mm.
It sounds like the image stabilization/calibration has not been completed properly, remove 3 print cartridges ( any) switch unit back on and wait for display to ask for other cartridges, - insert when asked and allow the machine to complete the calibration, alternatively use the menu function and look for image stabilization under diagnostics and activate.
Oct 11, 2013 | Samsung clp-670nd laser printer
This RCA L26HD31 TV has always worked fine in other respects... but when I try to connect my pc's hdmi cable to it for use as a monitor, I just get "unusable signal". When this TV was made, hdmi...
Make sure you have set the laptop's display properties to as low a resolution as possible (also make sure the screen refresh rate is 60 hertz) and turned it off before connecting it to the television. Turn the television on first and set to the correct input either hdmi 1 or 2. Then turn on the laptop. When it has booted up hold down the function key and the dual monitor key (either F5 or F8) for 15 seconds for an image to appear on the screen. When you have an image you can play around with increasing the laptop's resolution.
Apr 27, 2011 | RCA L26HD31 26 in. LCD HDTV
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Horizontal Span across 2 screens - now displays multiple offset background image
you have tried differrent setting in your video resolutions, what you need is just return to your default settings
Nov 29, 2007 | XFX GeForce Fx5700 (128 MB) Graphic Card
Samsung UN40D6000 TV Logo
59 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
