Question about HP LaserJet 4350TN Printer
I have an hp lj4350 that squeaks only when printing from tray 2
It only squeaks when printing from tray 2. I replaced the two rollers, but that did not help. If I watch from the back, it squeaks when the paper is being picked from the tray
  • mreagan Sep 16, 2016
    After trying to lubricate all moving parts at the bottom of the printer, I finally found the squeak/squawk/howling that occurs mainly when printing envelopes. Open the toner tray and remove all toners. Then look for gears on both sides of the glossy transfer belt. These need to be sprayed with WD-40 or equivalent. However, you need to be extra careful not to get spray on the belt, so fold a paper towel twice and lay over the belt, so as to just expose the gear and spray over exposed area, about two inches from front to back, to where you can't see anymore. Wipe up any excess spay that may accumulate after spraying.
    Champion:
  • HP Expert
  • 312 Answers
There are three rollers. One in the tray and two in the feed assembly. Could be the registration assembly but I have not replaced many of these.
Posted on Jan 31, 2015
SOURCE: hp color laser 2840 paper jam
Quit eating your lunch.
Posted on May 21, 2008
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
checkitright
  • 1362 Answers
SOURCE: My HP LaserJet 2430dtn Paper jam
Try this, make a print from the by-pass tray, does it go OK or jam??
If it jams then there is a problem with the paper feed from the tray.
If it jams then
1-check the drum and see if there is an image on it( you can put a mark on the edge to see if it's rotating, thus eliminating the drum unit)
2-same for the reg roller
3-check for labels ar foreign objects
Posted on Oct 10, 2008
  • 66 Answers
SOURCE: Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Posted on Dec 18, 2008
shadiabed
  • 72 Answers
SOURCE: Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Posted on Jan 08, 2010
My HP 2430 continues to jam on Tray 2 only. Tray 3 and Tray 1 (manual feed) are fine. I have replaced rollers and it continues to jam paper.
Common problem on this printer is for either the drive shaft for tray 2 to come lose or to break. Pull out the tray and try to rotate the roller. If it turns freely then the shaft is broken. The replacement procedure is too complex to describe here. If the roller does not turn freely then likely the pick solenoid has failed.
Oct 12, 2016 | HP LaserJet 2430dtn Printer
4mv won't pick up paper
The feed rollers need to be replaced. The squeak is the worn rollers sliding over the edge of the paper.
Mar 25, 2014 | HP LaserJet 4mv Printer
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
My P2055DN is making a squeaking noise while printing. Not that big of a deal I guess just annoying. I hope nothing major is on the horizon. Please advise if I should worry about this or not. It...
If you are printing invoices from the MP tray the pickup roller might be squeaking against the separation pad (common with this design). Other common squeak is toner cartridge noise.
Jun 21, 2011 | HP P2055DN LaserJet Monochrome Printer
Our HP B8550 is squeaking when it prints. How can we fix this? It has just started doing this.
Hello
Try reinstalling the cartridge or installing another. This cartridge's yield is 2500 pages. When is very used, it could make rare sounds. Always use genuine HP cartridge.
Check the pick-up roller,If the pick-up roller has a very smooth surface, replace it.
First off put a sheet of paper on the manual feeder (tray 1) and do a self test. Does the printer still make the noise. If it does, then it is not the roller in tray 2. Only other way is to put your ear to the printer case and see if you can isolate where the noise is coming from.
There is a fuser assembly in the rear which generates heat so over time bushings can go bad and it will make noise. You really need to isolate it more. If you open and close the toner door the motor will turn for a couple of seconds. Do you hear the noises then?
Jun 10, 2011 | HP Photosmart B8550 Photo InkJet Printer
We have a laserjet 2420dn which prints fine from Tray 1 but constantly jams when printing from Tray 2. It only prints OK from tray 2 when there is ONE sheet in the tray. I changed the pickup roller in...
In addition to the pickup roller, the separation pad in the tray should also be replaced. This pad keeps more than one sheet from feeding at a time. When we do maintenance on a printer we always replace both to stop this from happening. The part number you want is RM1-1298-000. It is used in quite a few different HP printers.
Apr 16, 2011 | HP LaserJet 2420 Printer
Hp 4000N 41.3 unexpected paper size
Clean the sep. rollers one in the paper tray and one inside the paper tray port. Then clean the feed roller. Its behind the sep roller in the paper tray port. You must look close with a flash light. It has 4 D feed rollers. It will rotate down to clean them do not knock the spring off. Use only water on a cloth no alcohol. Steven 818-888-0006
Mar 11, 2010 | HP Office Equipment & Supplies
HP Laserjet 2420 will not print from tray 2
Take out the toner cartridge and paper cassette , turn the printer upside down. The feed roller should not free wheel. Sometimes the roller ends break off,
Jan 28, 2009 | HP LaserJet 2420 Printer
Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Oct 27, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 4350TN Printer Logo
160 people viewed this question
Seeker5211
Seeker5211
