I have an American Standard Freedom 80 single stage. the Furnace works fine and so did the a/c previously. i live in southern ca. its lunch time and 80 degrees.i turned on the a/c the system sounds normal but no cold air. any suggestions would be appreciated. Thanks
SOURCE: I have an American Standard Freedom-80 Two stage
If your system worked prior to installing the new thermostat, then you may have to change how your thermostat is wired in the rear, as I encountered the exact same problem in that regard. Beyond that, if you have a blinking light, chances are it may be a problem with the furnace itself. After you are confident the thermostat is wired properly, if you still get a flashing light, then you have an internal problem with the furnace and will have to get a repairman out to investigate the code given by the flashing light.
Posted on Jun 08, 2010
SOURCE: I have american standard freedom
The igniter must have failed. replace the igniter.
Posted on Dec 20, 2010
walterkunesk
  • 683 Answers
SOURCE: I changed the furnace filter
does anything happen, i door that you removed might have a kill switch on it so if the door comes off or is not installed right the furnace wont light, let me know and maybe i can help. wally
Posted on Mar 10, 2011
  • 413 Answers
SOURCE: I am trying to install
Should be like this:
Y from furnace goes to Y on thermostat (yellow)
C from furnace goes to C on thermostat (usually blue)
G from furnace goes to G on thermostat (green)
W1 (first stage heat) to w1 on thermostat(white)
w2 (second stage heat) to w2 on thermostat (black)
Doesn't sound like you have a heat pump but if you do "o" will also have to be connected which is the reversing valve.
Posted on Jun 21, 2011
  • 1033 Answers
SOURCE: I have a American Standard
Hello, The only time pvc is allowed is if the Furnace is 90% or greater in effiecency, the combustion gases are cooler due to the fact that two heat exvhangers are used. One pipe will be you air intake and the other the exhaust and they can be routed through the roof or sidewall. If the Furnace is 80% then you must use double wall vent pipe and have it connected to either a liner in a chimney or routed through a roof but pvc can not be used.
Posted on Aug 28, 2011
American Standard Freedom 80 single stage fires up... runs and blows heat for a few minutes then shuts off but then 5 minutes later it repeats the cycle. Any ideas? I have replaced the filter.
A 5 min run time tells me that it is overheating. Probably a dirty evaporator coil, or a loss of airflow due to blower issues. Or even a high temp safety that is opening prematurely? Tstat is calling for heat so its doing its job. It could be overheating or a fault at any of the components in the furnace. 90 percent of the time its a dirty blower wheel, EV. coil, or a missing filter that's so dirty its cutting off the airflow. Hope this helps!
Mar 01, 2017 | American Standard Heating & Cooling
I have a American Standard furnace Freedom 80 Mod# AUD080C936H3 and am looking for a manal or can you tell me how the exauhst is done. Can I use PVC
Aug 28, 2011 | American Standard Heating & Cooling
I am trying to install a thermostat and I am not sure where to put all the wires... it is for american standard freedom 90 two stage - furnace and air conditioning
Jun 21, 2011 | Heating & Cooling
I changed the furnace filter on my american Standard Freedom 80 filter and now my burner won't light.
Mar 10, 2011 | American Standard Heating & Cooling
How doI replace the motherboard on a American Standard Freedom 80?
Hello, to replace the intergrated control board on your furnace you need to turn off main power to your furnace, then label the wires so you will know where they go on the new board. Then just take the old board to a hvac supply store and they will give you a replacement and just connect the wires to it and turn on Furnace.
Mar 02, 2011 | Heating & Cooling
American Standard Freedom 80 - 9 blinks - Ignition issue
I will try to help. Your furnace has to have a good ground before the igniter will work. The draft fan starts purges for a few seconds and the ignitor is supposed to come on. If not check to see if the contacts on the air switch on draft motor are closing. If you ahve changed the ignitor that is not your problem. Another possible problem is the baord that feeds the ignitor. But check the air switch first Rus. Keep in touch.
Nov 19, 2009 | Heating & Cooling
Manual J Calculations for Residential house 1018 sq. ft. American Standard unit
without actually doing a load calc it would just be an educated guess.Good choice in equipment though.
Aug 06, 2008 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
