I have a beovision 7 32 inch 9334 with vga port, I am trying to connect a laptop through the vga port with no luck, do I press menu and then add it to av1 a spc?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Should be "vga" in menu, switch to that.
Posted on Feb 15, 2014
2 Suggested Answers
SOURCE: we have a bang and
First, try setting your monitor refresh rate at 60Hz using a known-working monitor. (The VGA input of the Beovision 7 is recommended for 60Hz refresh rate). If this fails to produce output from the Beovision 7, it is very likely, your video driver's resolution is set too high for the Beovision 7 to display signal. If you are using the Beovision 7 as your primary monitor, first connect a known-working monitor to the computer and reduce the resolution to 1024x768. Once you have changed the resolution, try connecting the Beovision 7. If you get video signal, increase the resolution incrementally until you find the maximum resolution the Beovision 7 will handle.
IF YOU ARE USING THE BEOVISION 7 AS A SECONDARY MONITOR USING EXTENDED DESKTOP, reduce the resolution on Monitor 2 output to 1024x768. If video appears on the Beovision 7 at that resolution, incrementally increase the Monitor 2 resolution until you find the maximum resolution the Beovision 7 will accept as a secondary monitor.
Posted on Jul 14, 2011
Hi there I have a Toshiba CT - 9969 and want to connect my laptop using VGA? What must I do and where do I switch to VGA on the remote? Thank you
connect to TV using VGA port and select device or mode to PC in tv menu. or using remote
press laptop fn +F4
or see display change button in FN buttons .press with or without FN button . if you use HDMI pls cinnect with HDMI cable and in TV pls select HDMI mode in video mode
There is a row of Function keys at the top of the keyboard on every Toshiba notebook. These give you quick access to some useful functions. To activate them, just press the FN button on the keyboard together with the function key to activate the following commands.
press FN+F4
Nov 16, 2016 | Toshiba Computers & Internet
I'm trying to connect my Panasonic tv42PV30 to my laptop . This is a picture of the back of my TV and the front view . I hope that helps
The TH-42PV30 has a VGA port (that's the one labeled PC). If your laptop has a VGA output, then you need a VGA cable and a 3.5 mm to 2 RCA audio adapter or cable. (Depending on the adapter, you might need a 3.5 MM audio cable or an RCA audio cable.) Connect the cables with the TV and the laptop off. Then turn on the TV and set it to the PC input before you turn on the laptop. For most versions of the Windows OS, once the laptop is on, right click on the desktop (anywhere with no icons or running programs). You'll see a pop up menu. Select the line "Display Settings". Check if the new "monitor" is detected. Then you can set the display settings for dual or single monitor modes. (A few laptops hide this under Graphics Properties in this menu.)
If the TV is not identified, you may need to access the BIOS and enable the external video port. (Depending on the manufacturer of the laptop, you'll need to press F1, <Esc>, F2, F10 or Delete at the manufacturer's splash screen as the laptop starts up. It's easy to miss the timing. Just try again; I usually hit the key multiple times immediately after turning on the system.)
If your laptop doesn't have a VGA port, you'll need a converter for the type of port to the VGA port. Many laptops have HDMI ports; in that case you'll need something like this: http://www.amazon.com/PETHV-converter-3-5mm-Stereo-Converter/dp/B003O55U8K . Note: HDCP content (commercial Blu-ray or DVDs) will not be displayed on any of these converters. You'll need an HDMI cable, audio output cable and VGA cable in addition to the converter. The same steps as above will be needed when you connect the devices.
I hope this helps.
Sep 03, 2015 | Panasonic Televison & Video
Laptop to T.V. connectivity
Hello!
This is my first time using this site, but I will try my best to assist you.
From what I understand, you want to connect your laptop display to your T.V. In turn using your T.V. as a "monitor".
So you were wondering if you could use a S400 to HDMI cable to accomplish this. Unfortunately I don't believe this is possible with that cable. To my best knowledge, S400 ports are only capable of transferring DATA between devices, not VIDEO. A VGA or HDMI cable will accomplish what you want. I don't think your laptop has a HDMI port, so I recommend buying a male-to-male VGA cable.
I looked up your T.V. and it looks it should have a VGA input port. This is what I did for my laptop and 32 inch LCD T.V. when i accidently cracked my laptop's screen.
It may not be High Definition, but you should be able to get fairly decent resolution. Make sure your T.V. is on the "Computer" input channel. (Or equivalent)
I don't recommend buying a VGA to HDMI cable converter as it usually doesn't result in improved quality.
I hope this helps! Good luck!
Jan 21, 2013 | Computers & Internet
We have a bang and olufsen beovision 7 40 inch tv. when we try to connect our laptop through vga port the tv appears blank without any display, tried connecting the laptop through dvi port also. The...
Jul 14, 2011 | Televison & Video
I am connecting the VGA cable but still no signal can u pl help
There are two things to try. One is on your laptop. Hit function 4 on your keyboard. You should pop into a screen that allows you to send signal out from your laptop to the projector. The other is to go into the menu on the projector and adjust it for either the port you are on or set it up for "auto-detect" When the menu comes up it should have a video section and then an input select. Your VGA inputs on the projector should be labeled something like VGA 1, VGA 2 or something like that identifying the ports. Then in the menu select that port. If these two things do not work give me another posting and we can get this fixed.
Feb 25, 2011 | InFocus Proxima UltraLight LS2 Multimedia...
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
How do i connect my tv to my notebook computer
You get a VGA cable from a local electronics or computer store and connect the laptop vga external monitor port *(its the 15 pin D shaped blue port) to your TV's VGA input *(also a 15 D shaped port).
Then, when you want to watch your computer on your tv. Change your TV input to computer and toggle the laptops video output *(usually by pressing the laptops FN key and one of the function keys that has a picture of a monitor on it simultaneously).
That should do it. And, if you want the picture on both displays the FN feature normally gives you that option if you press the buttons again.
Good luck and enjoy!
May 04, 2010 | Protron PLTV-4250 42 in. LCD Television
Help!!! Trying to connect the LCD to my laptop to use as a monitor... Does anyone know how?
just plug the LCD monitor at the VGA port (Blue port) of the Laptop and press Fn+F8 and it will display the screen on the external LCD screen. hope this helps
Nov 03, 2009 | Computers & Internet
How do I connect my Laptop computer to my LCD TV?
Every laptop has at least a VGA (computer video connection) and s-video cable port. A VGA cable is preferred if you want to be able to read text on your LCD TV. Check to make sure that your LCD TV has a VGA connector. It's a port that accepts a 15-pin connection so it's pretty easy to spot if it's there. It's just like a computer monitor cable if that helps. Should be able to find it at any local retail store that carries computers. VGA or RGB cable.
Apr 12, 2008 | Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
